Do Windows 8 Licenses work the same way in a Surface Pro?
theimporter
Hi there,
I got a Surface Pro last month. It had a 8GB partition for the system's default restoration which I transferred to an SD card before merging that space with my C: drive.
Considering the unreliability of SD cards and the fact that this will be pointless past June 30th because I won't be able to get updates if I install 8.1, I was looking into other alternatives. Although I did back my partition with Clonezilla after I was done installing everything, it would be nice to be able to do a fresh install if needed. Since I do own a Windows 8 license, I should be able to install Windows 8.1 from a disc (I have external DVD drive) using my key code that I discovered after running Belarc Advisor.
Anyone has any idea if this would work?
jimbo45
Hi there
If it's an RT system --then no. The newer surface pro's which are Windows will work exactly like windows --if you change the built in version that came with the device (you'll have to disable protected boot first) then a retail copy will install OK. Backup though just like you would a regular PC. It will also work just like a windows PC regarding updates etc.
For RT all bets are off - and that whole RT system doesn't actually look very long for this world either.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
strollin
Old Guys Rule!
@Jimbo - Surface Pros, regardless of which generation, all run full Windows. It's the non-Pro models that run RT.
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet)
    Home built i7-8700K, Hp Envy x360 EVO Laptop, MS Surface Pro 7
    3.7Ghz Core i7-8700K, 11th Gen Core i7-1165G7 4.7Ghz, 10th Gen Core™ i5-1035G4 1.1Ghz
    ASUS TUF Z370-Pro Gaming, HP, MS
    16G, 8G, 8G
    AMD Radeon RX580, Intel Iris X Graphics, Intel Iris Plus Graphics G4
    ATI High Definition Audio (Built-in to mobo)
    Dual Samsung U32J59 32 inch monitors, 13.3" display, 12.3" display
    3840x2160 (Desktop), 1920x1080 (laptop), 2736x1824 Pro 7
    500GB ssd boot drive with 2 & 10TB Data (Desktop), 512GB ssd (laptop), 128GB SSD (tablet)
    Corsair CX 750M
    Antec 100
    Coolermaster CM 212+
    IBM Model M - used continuously since 1986
    Microsoft IntelliMouse
    665Mbps/15Mbps down/up
    FireFox, MS Edge
    Defender on all
    Retired in 2015 after working in the tech industry for 41 years. First 10 years as a Technician, the rest as a programmer/software engineer. After 1 year of retirement, I was bored so went back to work as a Robotic Process Automation Consultant. Retired for 3rd (and final) time in 2019.
NoelDP
Three-Toed Sloth
The Surface Pro is a Standard Windows 8 Pro installation, as I understand it - complete with the BIOS Key and everything.
    Win7 64-bit and Win8 32-bit in VM (+ others in VM)
    Asus K52F
    i3
    8GB
    it's an i3 :)
    Conexant (rubbish - or it may be the speakers)
    1366x768
    whatever I can get - G3
