Display turns off despite having changed settings
ssmith123
The display on my laptop shuts off after (roughly) 10 minutes of inactivity, despite having changed all of the settings to 'never'.
Is there a simple solution to this that I am unaware of, or is this a more serious issue with my laptop?
Any help would be much appreciated as this is becoming increasingly inconvenient.
Thanks!
TechnoMage
Active Member
Since you're giving NO information about your computer, or what OS you're using, that makes it difficult, at best, to advise you.
:cool:
    Win-8.1/Pro/64
    Home Made
    AMD 8 Core
    Gigabyte, Ultra Durable, GA-970A-DSP3
    Crucial, 8GB
    AMD Radeon HD 5450 (2 GB)
    On Board
    24" LG
    Sandisk, SSD 120GB, 8TB Seagate backup drive
    Antec Earthwatts, 650
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
Thorsen
Make sure in the "Change advanced power settings" that sleep is also either turned off or to a higher number of minutes. I think sleep and hibernate and all those will turn off the screen as well. I am not sure about hard disk options, but that might also turn off the screen when the hard disk is turned off...
    Win 8.1 64
    Lenovo Y50
    Intel i7-4720HQ @2.60GHz
    LENOVO Lenovo Y50-70 Touch (U3E1)
    8.00GB Dual-Channel DDR3 @ 798MHz
    Integrated Intel HD Graphics 4600 (Lenovo) Dedicated 2MB NVIDIA GeForce GTX 860M
    Realtek High Definition Audio
    Western Digital 1TB Black HDD/SSD Hybrid Drive WDC WD10S21X-24R1BT0-SSHD-8GB
hydranix
Could be a BIOS setting, but like Mage said, you need to provide make, model, OS, and other relevant information.
    Kernel 4.x
    i5 3570K
    P8Z77-V LK
    G.skill Ripjaw Z 2133MHz 9-11-10-28
    GTX770 4GB Dual BIOS
    Audigy 4 Pro
    32" SAMSUNG HDTV
    1920x1080 progressive
    10TB total
    3 RAID arrays
    3 single disks
    Corsair HX750
    Corsair R400
    Corsair H100
    Logitech G510
    Logitech G5
    ~900mbps (~115MB/s) down, ~10mbps(~1.5MB/s) up
    Firefox & Chromium
    Common Sense
ssmith123
I will have a look at the sleep and hibernate settings and see if that makes any difference. Thank-you :)
