Disk usage spikes when nothing is running
golden430
Looks like your only recourse is to make sure that your bios is up to date and do a clean install. Back up your data first.
that's what i think .. but if it is an hardware issue the problem will continue.. I'll do a clean install on june 25th since i have a lot of work and backups to do.. I'll tell you the results. Thnks ;)
    windows 8.1
Nuccii
What are your power options set to, balanced, high performance or what?
In Task Manager/Performance please post a screen shot of the C disk and Memory.
Still in Task Manager/Performance, click Resource Monitor and see what is going on there when it spikes.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
golden430
I used resource monitor as well as process explorer
That disk usage you see in the pic is with the pc idle
    windows 8.1
Nuccii
Go to the Seagate support and verify that the driver is up to date and while your there. Also run the S.M.A.R.T. diagnostic tool from their site.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
Vincenzo
In Resource Monitor, once you select the Disk tab, the top window will tell you what processes are using the disk activity, and the bottom window will tell you what file it is.
    Windows 8 Pro
leonhardwetten
And while you are analyzing your Disk usage,
do a run-down of which network-links are coming over your WiFi network.
As it seems that your Disk-spikes are corresponding to your Network activity.
check the ip adresses with http: // db-ip.com
Regards.
    Windows 8.1 (355 + Auto-Update)
    Toshiba U500 17E
    Intel Core 2 Duo T6600 2.2 Ghz
    4 GB
    NVIDIA GeForce G210M
    180Mb/s
    Internet Explorer 11.0.7 (auto update)
    Norton Internet Security
golden430
Regards.
it's true, but what's causing that ? it's weird .. anyway, what do u want me to do ? i didn't get what you said ..
    windows 8.1
RolandJS
Are there any utilities that monitor any and all deletions [regardless of who or what caused]? What about Indexing? I have learned to vastly trim what Indexing does and to trim what folders my Resplendence's Undeluxe watches.
    2 Acers & 1 Antec[?]
    i7 in 2 Acers, i5 in desktop
    Desktop w/Gigabyte
    Two w/16GB, 1 w/8GB
    Laptops GameWorthy; Desktop maybe GameWorthy
    flatscreens; 2 are BluRay worthy
    1368x768; 1600x900
    1TB internals; 2 ext usb WD 1TB HDs
    what's PSU?
    Regular plus external fans
    desktio w/PS2
    desktop w/PS2
    DSL middle level [160?]
    from Netscape 0.9 to FF 36
    well-balanced, well-configured mult-layered defense is best
    From MS-DOS 3.3, MS-DOS 6.22, from Windows 3.1 to WFW 3.11 to Windows 95-98SE, now to Windows 7 Pro.
    Security for now: Windows 7 Firewall, Emsisoft AM, MSE [scan-only], SpywareBlaster, Ruiware/BillP combine
