Solved Disk Management reallocation issues.
bucket81
12
So I've been playing around with FreeNAS on another rig, you install the server on a USB drive and run the server form the flash drive. I've decided to go another rout and not use free nas so I went to format the 2 flash drives I was messing with and there are some partitions I can't remove with disk management, and space missing.
Disk 3 should be 4GB large but I can only find the 943 MB
It doesn't give me any options to change the volumes on Disk 4.
any help would be great.:geek:
    Lenovo
    Intel Core i7-3610QM
    •NVIDIA® GeForce® GTX660M 2GB with DirectX® 11
    Asus VE147
    Crucial 128 GB SSD mSata
    Samsung 840 250 GB SSD
    Seagate 1TB
    Apple
    Logitech G700
frozwire
8F Rookie
CyberPlanet
79
You can try using diskpart to fix those volume issues or use some third party applications like Easeus Partition Master or Partition Wizard MiniTool.
12
Try easeus partition creator
download.cnet.com/[B]EaseUS[/B]-[B]Partition[/B].../3000-2248_4-10863346.html
    Windows 8.1 Update 1
    Custom Made
    Intel i3 2100
    Intel DH661W
    4+2GB
    1 GB 6670 GDDR 3
    Samsung SyncMaster SA300 18.5''
    1366x768
    WD 1TB Sata
    Cooler Master 500w
    iBall
    Logitech K200
    Logitech
    256Kbps
    Antivirus Sucks
topgundcp
San Jose - California
2,847
You don't need to use any third party software. Just use diskpart.
Run Admin command prompt and type: diskpart then follow the screen shots below:
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
bucket81
12
Diskpart did the trick thanks guys.
    Lenovo
    Asus VE147
    Seagate 1TB
    Apple
    Logitech G700
topgundcp
2,847
Glad we could help and please mark it solved. Thanks
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
