Disc goes to 100% busy for extended periods.
Mosaix
First, apologies if this is the wrong place to post or if this has been discussed before.
I'm running 8.1 on a laptop with 8gb memory. I have a 120gb SSD as c: and a 1tb disc as d:
About a week ago there were some windows updates installed. Shortly after my d: started going 100% busy for extended periods (up to half an hour) as shown on task manager and the system slows considerably. Strangely, during this period task manager also shows zero read speed and zero write speed, as if there is no actual activity.
This happens (but isn't limited to) after reboots. I've tried stopping various processes (virus checker, dropbox etc) but this makes no difference. My c: SSD operates perfectly.
Thanks in anticipation.
    PCSpecialists
Mosaix
An update.
I've been looking around forums (including this one) and came across the suggestion of disabling the Sensor Monitoring Service (SensrSvc). I tried this this morning (use msconfig and reboot) and so far there has been no repetition of the problem.
Fingers crossed.
Update: False hopes. It started again about 30 minutes ago. :(
    PCSpecialists
JHough
Pittsburgh
103
Have you tried using performance monitor to pinpoint the applications using the disk?
    Microsoft Windows 8.1 64 Bit
    Toshiba C55Dt-A5106
    Processor AMD A6-5200 APU with Radeon(TM) HD Graphics, 2 Ghz, 4 Core(s), 4 Logical Processor(s)
    Toshiba PSCFWU-02C031
    4GB
    AMD Radeon HD 8400
    Realtek High Definition Audio
    Laptop and DELL E193FP
    1366x768 1280x1024
    Toshiba MQ01ABD075
    DVD Writer TSSTcorp CDDVDW SU-208FB
    Logitech Wave 2.4 Cordless or Laptop Standard PS/2 Keyboard Enhanced
    Logitech M1100 Performance Laser Cordless Combo or Logitech G500
    Upload/Download 91/11Mbps
    IE 11
    Norton
    Toshiba System Settings V1.1.2.32001
    BIOS Version Inside Corp., 1.60, 11/15/2013
    EC (Embedded Controller) Version 1.20
    Hardware Abstraction Layer 6.3.9600.16500
Mosaix
Thanks for your suggestion. Performance monitor shows the system about 97% idle whilst the disc is busy. Many, many other processes are utilising the other 3%. Note that this is whilst there are no applications loaded. I've stopped everything I can think that could be using the disc.
I've not had the system long and there's practically nothing on this disk so I suspect that it must either be the operating system or a faulty driver, especially as the problem only started after a windows update.
    PCSpecialists
