disabling / removing Metro GUI (works for current developer release)
jimbo45
Hi all
This is a copy of a post I made in the W7 Forums but I've been pointed to this Forum (never even knew there was a W8 one yet !!)
I've just been playing with the developer edition of W8 download
link in the news section of the Forum.
if you are like me and HATE those
horrible square tacky icons that make this OS look more like a mobile phone than
a desktop / workstation OS then this neat little trick gets back to the more
"Claassical UI" windows look.
Once I've disabled the Metro UI I actually
quite like W8 and it seems snappy enough on my system even as a VM.
To
disable the Metro UI and keep the ribbon, etc, simply rename
c:\windows\system32\shsxs.dll to something else and reboot.
This might
only work for the current developer build but it suits me for the
moment.
I always prefer totally uncluttered desktops with the minimal
information on them at startup.
I hate the android phone default start up
screens -- I'm using an HTC phone.
Nothing wrong with the phone but not
everybody wants or needs zillions of apps on their screen !!!.
To any MS
developers --remember this OS will also be used as a workstation / laptop OS so
please don't turn it into a tablet only or "Iphone" look alike OS. Some peole
like dynamically changing icons ("Metro apps" - why can't they just call them
MOBILE apps which is essentially what they are) but others don't want them
--leave some user choice. !!!!
Cheers
Jimbo45
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
Tom
Thanks for that tip, Jimbo. I'm sure that the GUI will be useful on a touch interface, but it's worse then useless in a workstation/desktop environment.
    Win 7
    i7 860
mikedl
Removed by request
Might as well stick with Win 7 then ...
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    Laptop 17", Gateway 20"
    1440x900 (x2)
Tom
From a GUI perspective, I agree. However, 8 is being promoted as offering improvements in performance, security, privacy and system reliability, along with a decrease in the the memory footprint needed and faster boot-up and shut down speeds. All good stuff for the desktop, and good news for laptops.
It's a new O/S, with - I hope - improvements, tweaks and changes that will make it useful for all sorts of platforms. If all I was interested in was the GUI, I would stick with XP. That's obviously a silly stance to take however.
    Win 7
    i7 860
zx81
I hope Microsoft will not overlook the fact that most people don't use or want to use touchscreen based computers.
Best regards,
zx81
    Windows 7 Home Premium x64
    Dell Inspiron 1720
    Intel 1720 Core 2 Duo 2.00GHz,800,2M
    4GB 667MHz DDR2 SDRAM (2x2048)
    NVIDIA Geforce Go 8600M GT 256MB DDR2
    SigmaTel
    17.0" Widescreen WXGA+ (1440x900) TFT with TrueLife
    1440x900
    2x160GB 5400RPM Serial ATA
    Logitech
Angelo
I found this batch script to work really good to remove the Metro UI without rebooting, while still preserving the new taskbar and the such. Save as KillMetro.bat and run as admin:
Edit: Uh, the below script doesn't actually turn off Metro, it enables the classic Start menu but ALSO allows Metro to be invoked. Anyone have a better script?
@echo off
ren C:\Windows\System32\shsxs.dll shsxs.dll.bak
tskill explorer
echo Wait a second...
ping -n 2 127.0.0.1>nul
ren C:\Windows\System32\shsxs.dll.bak shsxs.dll
Here's the same script, but to turn it back on:
@echo off
tskill explorer
The renaming in the above script is not really required if the KillMetro.bat above is used to disable Metro UI, it's more of a fail-safe.
    4 GB
    Nvidia GeForce 460 GTX 1GB
davehc
I have created two specific users, one Metro and the other non metro. It takes seconds to logout and in again.
    Use several different computers during a day, so specs are irrelevant.
Capt.Jack Sparrow
BSOD Kernel Dump Analyst
@echo off
tskill explorer
@echo off
tskill explorer
Here is a tool that does that Download Metro UI Tweaker for Windows 8 1.0 Free - A simple means of customizing the Metro interface of Windows 8 - Softpedia
    Windows 7
logicearth
Turning Metro UI off per-user:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\RPEnabled set to 0
Then log off and back in.
Then for the rest of the system, login UI, etc:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\RPEnabled set to 0
Restart.
No changing DLLs needed...The registry (and Group Policy) is the supported way.
    Windows 7/Windows 8
whs
I agree that the Metro UI is kind of "alien" for the PC. But if you cut it out, you are missing a lot of fun and end up with a lesser system than Win7.
    Vista and Win7
    5 SSDs and 12 HDs
vrosa
Tech Addict
Good idea !
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
mikedl
Removed by request
Try out Classic Shell.
I haven't tried it out on a single monitor (I use two) but, to me, it's the best of both worlds.
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    1440x900 (x2)
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
DMHolt57
I found this to be the best for laptop or desktop... be sure to set your user tile image before disabling, or you are stuck with the white generic user outline on the logon screen.
MetroController
http://winaero.com/comment.php?comment.news.17
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
whs
Hmm, may be an overkill to set the regkey from 1 to 0 or 2. Go to
Right click on the RPEnabled and click Modify
Set to 0 or 2 (with 2 you keep the new Task Manager).
    Vista and Win7
    5 SSDs and 12 HDs
    Lumia 1520 phone
whs
Shawn. my comment was not intended as a criticism of the tutorial. It was meant as an answer to post #16. I just thought that downloading a program for such a trivial operation is a bit heavy handed. But maybe some people are not comfy manipulating the registry and prefer some tool where they do not know what is really happening.
Btw: recently I noticed watermarks in your tutorials. Have people been "stealing" your snips? That once happened to me many years ago with one of my first tutorials on Shadow Explorer. Half a dozen forums and blogs (and very well known ones) used my snips to spread the news. Some even without the reference.
    Vista and Win7
    5 SSDs and 12 HDs
Wolfgang,
Oh no mate. I didn't take it that way at all. No worries. Besides, I always welcome constructive criticism anyways. Anything to help improve the tutorials so that they may help better is always welcomed.
I wast just posting to let folks know that the tutorial was updated for what you pointed out to make it easier to do using the context menu addition from the tutorial. That's all. :)
I agree. I don't much care for using 3rd party programs when not needed to be able to use Windows 8 own built-in features or options to do it. The tutorial just uses a simple .vbs file to make the registry changes with when using the context menu.
Yep, I always use watermarks on our images at our VF, SF, and EF sites. This way, if any one uses the images at their site, everyone will know where they came from.
    Lumia 1520 phone
