Dimming and Battery Life
joshh33
I just upgraded to windows 8 from 7 on my HP Envy15 with an i7 but i had a few things it said i need to re-install after i upgrade, HP Battery Management was one of them, which i though i re installed but im not sure if it worked because it still tried telling me i needed to update it after i installed it and my battery life seems terrible now...
The big one however is that i can no longer dim or brighten my screen with my F2 or F3, it wont brighten or dim through power management or even when you swipe left and go into settings.. the screen is stuck on one brightness and this might be whats killing my battery. I read a few things and some said i need to update my drivers or downgrade them, i have no idea how to do this or if you guys know of any other way to fix this problem, its really frustrating me though so please HELP, thank you!
ashleyg
    Windows 8.1 Pro, 32-bit
    Compaq nc8430 notebook
    Intel T2500 2GHz 2GHz 32-bit
    4GB
    SoundMAX Integrated Digital HD Audio
    1680 x 1050 (yes!)
joshh33
Yeah i tried what they did and it did not work at all.. they just found some little thing that seemed to work when they plugged in thier Bluetooth keyboards, i installed the same software they mentioned but it did nothing.. the problem still persists, i cant chang emy screen brightness in anyway, not through power management or through mobility center, its stuck at one brightness..
