Solved Deleting Fonts
jacksparrow
I installed some chess fonts and now i want to remove some of them, but no matter what i do, i simply cant delete them.The message pops up and says "the fonts are in use". I know the fonts are not in use but that doesnt solve the problem.I have only one user account and i sign in as an administrator.please help
    2GB
    Toshiba 1TB
    5mbps
    Avira
topgundcp
Hi,
To remove Fonts using regedit
Be warned, you break the registry you break PC, you are to blame no one else. So please be careful.
Press "Windows Key"
type: Regedit
For Windows 8 64bit
Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\ Windows NT\CurrentVersion\Fonts
For Windows 8 32bit
Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts
Then select the fonts you want to remove on the right hand side and simply press "Del"
font will now be gone.
Hope this helps !!!
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Windows key + R to get Run.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
jacksparrow
Thanks for your kind reply friend.But seriously, i am not gonna try this out for 100kb fonts.why MS doesnt let us simply delete it? Anyways, thanks for the good info.
    2GB
    Toshiba 1TB
    5mbps
    Avira
