Solved Cyberpower box
Greenguru
View attachment 61492Cyberpower box
I have been getting Blue screen since the first day really have no clue, Window 8 has asked to do a repair many times and when finally did it my office software got uninstalled with the antivirus was removed also and other Apps ,this was not a fix to the "frown face screen" :( The file has many dump files .
Just wondering if I can please be advised Thanks for your time Greenguru
    Greenguru
    Cross-hair II
    AMD Phenom II x4 940 3.1ghz
    Cross-hair II
    8 gb
    quadrofx 5800 + onboard nforce 980a/780a sli
    in box Cross hair
    x3 generic
    recommended
    wd, samsungmaxtor
    MS
Kari
Old geek, new tricks
Team Member
Please follow the posting instructions on top of this page to get assistance in your BSOD issue.
    HP ENVY 17-1150eg
    6 GB
    1600*900 (1), 1920*1080 (2&3)
    50 MB VDSL
    Maxthon 3.5.2., IE11
    Windows Defender 4.3.9431.0
Arc
Team Member
BugCheck 1A, {41792, fffff6800036a470, 200000000, 0}
[COLOR=#ff0000]Probably caused by : memory_corruption ( ONE_BIT[/COLOR] )
Followup: MachineOwner
Test your RAM modules for possible errors. Run memtest86+ for [hl]at least 8 consecutive passes[/hl].
If it start showing errors/red lines, stop testing. A single error is enough to determine that something is going bad there.
Let us know the results. If possible, a camera snap of the memtest86+ screen before closing the program would be good.
Greenguru
Uploaded picture
:rolleyes:thanks running ASAP Oh my long test, Guess I'm sending it back to manufacture spoke to the techs they said try to re install the OS Do anyone thing it will help or should i change ram thanks for all your time GG
    Greenguru
    Cross-hair II
    Cross-hair II
    8 gb
    in box Cross hair
    x3 generic
    recommended
    wd, samsungmaxtor
    MS
Greenguru
Test your RAM modules for possible errors.Run memtest86+ for [hl]at least 8 consecutive passes[/hl].
Hello again,
900 errors 10 in first 15 minutes and I let it go, so from here should i just change out memory, I have 8 GB other here just little less. thanks for the help and your time gg
    Greenguru
    Cross-hair II
    Cross-hair II
    8 gb
    in box Cross hair
    x3 generic
    recommended
    wd, samsungmaxtor
    MS
