Crossfire 7950s lock up computer, hard reset required
johnnyb01
15
Hello,
I am running two 7950s in crossfire on my computer. Anytime I launch a game, my computer just locks up and this hardcore buzzing sound playing right when it crashes, the sound continues while the computer is frozen.
This problem has happened in both Battlefield 3 and Splinter Cell Blacklist. I have enabled Crossfire and Crossfire for applications that have no associated profile. In GPUz, it says my cards are enabled for crossfire.
Any ideas on this? I'm wondering if it's my psu? If I disable crossfire, the games work, but the second gpu is at 0% utilization.
Here are my specs:
Windows 8 64bit
AMD 13.8 beta 2 drivers
ULPS is disabled via MSI Afterburner (and I did restart after)
CPU: 4670k
Motherboard: Gigabyte Z87x-UD5H
RAM: 16GB Gskill
HDD: OS on a 120gb ssd, games on a 2tb WD Black
PSU: 750w Corsair
nenad285
My house
148
Since the games work fine when you disable Cf it seems like it is a driver issue, try downloading the latest 13.10 Driver and see if it fixes your issue.
Driver: 13.10 AMD Catalyst
    Windows 7 Home Premium x64
    Hewlett Packard P7-1017c
    Intel Core i3-2100 @ 3.1Ghz
    Pegatron HP
    Crucial 2x4GB DDR3 1333 MHz
    Sapphire Radeon HD 7850 2GB GDDR5
    Realtek HD Onboard
    HP 2211x
    Hitachi 1TB 7200 RPM
    Corsair CX600 80+ Bronze
    Coolermaster HAF 912
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    30+ Mbps Download; 2Mbps Upload
    Norton 360
    New build with custom parts later in the year
Are you OC'ing the GPU's? What are the game settings set to?
That's what it sure sounds like...when a GPU over clocked, some games just can't handle it or the games settings are set to high.
Another possibility could be a power issue with the PSU with to 2 mentioned games.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
nenad285
My house
148
Another suggestion would be see if there is a new BIOS update available for your motherboard, sometimes a BIOS update may solve these type of issues. Not sure if the OP found a fix since it's been over a month and not even a response.
    Pegatron HP
    Realtek HD Onboard
    HP 2211x
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    Norton 360
