tinydoh
It works!
Download from the link, then extract it to a folder.
Open device manager, right click on the Creative needing the driver (or "Unknown Device") and choose Update driver software...Browse my computer...Let me pick...Have Disk...Browse
Now navigate to the extracted folder and double click on wdma_emu.inf.
Hit ok then next and it will install. It's good because the drivers are all from 5/5/2010 - you don't want to be dealing with very old Creative drivers on 7 or 8. By the way, this will also work well for XP, Vista and 7.
Any issues at all, let me know and I'll fix it up.
Enjoy! You're welcome.
Free File Hosting, Free Video Hosting, Online File Hosting. Large Files and Images up to 5GB - YourFileLink.com
It works!
Amazing, you're a true wizard, thanks a lot!
Cheers mate
    Windows 8 CP
Amoklaw
Microsoft had this driver on their server but it is not for your EXACT hardware id so that is why they did not give it to you with Windows Update.
I fixed it so it works for you. Extract my download to a folder.
Right click Multimedia Audio Controller as before in the device manager. Choose Update driver software. Browse my computer. Let me pick. Have disk. Browse.
Now find wdma_emu.inf in the folder you extracted to. Click on it. Hit next then ok and it will install.
Creative.zip
If that alone does not install for you like that, then copy/paste my attachment contents from the below link over the .inf in that above extract folder first:
I just want to say thanks to GMan ^^
You save my life :D
GMan
Banned
lol Life is good when you're living. :) Have fun. You're welcome.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
dj777
GMan...help...same problem as everyone else, but I'm running 64 bit
PCI\VEN_1102&DEV_0005&SUBSYS_00331102&REV_00
PCI\VEN_1102&DEV_0005&CC_040100
    Windows 8 x64
    hp pavilion d4890y
GMan
Banned
Hi, welcome.
This is not the best solution at all, since you definitely should be running 32 bit with that card. Creative drivers are notorious and the older, the worse they are. You can try installing the top driver shown here and hope the machine remains stable:
Microsoft Update Catalog
It is possible for me to make a 2010 driver easily install for you, but then you'd have to do one of three things so it works:
1) Disable driver enforcement at boot every time from the menu.
2) Disable driver enforcement permanently
3) Sign the driver files
Let me know how it goes with the driver above or if you're sure you know which of the 3 choices you are going to do if I make something for ya.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
mattfly
Hi, welcome.
hi guys
recently i moved to 64 w8 and drivers provided by some clever guy (thanks a lot, gman:)) work perfectly under that system. the only missing thing is mixer in audio creation mode. but most probably is my lazy in finding it. i use daw to create music so that stuff is not especially needed for me.
GMan
Banned
Awesome. Which do you use? My main one is Cubase 5.12, but I also use Sonar, n-Track Studio and Sound Forge for things.
I'm looking forward to MOTU finally releasing Digital Performer for Windows this Spring.
You're welcome.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
mattfly
what the coincidence;) also c 5.1 and sonar. there is interesting thing in sonar: you can use different cards for input and output. but i wouldn't like to bend the subject of thread. it'd be nice to talk to you about it somewhere anyway:) any idea??
krohm
Closed as requested
tried all of the above, not working for me... although it is not listing sblive as my soundcard in device manager...
not sure what to do from here...
    Windows 8 x64
mattfly
hi, krohm. this is something i got also. try to follow this thread from the start. there is a lot of info about such problems. it's a pity that gman is... temporary ill, he had solved most of issues, if not all. good luck!
krohm
Closed as requested
unbelievable microsoft would not support one of if not the largest sound card company on earth, WTF... wtf !!!!!!!
i dont have sound on my computer ! WHY. WHY
anyone can help me with this it would be greatly appreciated.
    Windows 8 x64
krohm
Closed as requested
excuse the rant the frustration got the better of me,. but here i am several days in to reinstalling win8 and have lost sound. i have no idea how i had it in the first place on win8! what did i do... ! anyways if anyone can help me further / offer suggestion would be appreciated,...
    Windows 8 x64
jarekwodnik
run drivers pack from creative web with compatibillity mode windowsxp sp3, i did that and it's OK sound card's working now
    windows 7
krohm
Closed as requested
didnt work, same problem..
could anyone assist ,... the card is not dead was working before i format reinstalled.. really dont know what to do , basically none of the softwre seems to be supported in win8. ! really a bit lost here... dont want to have to go buy another sound card
    Windows 8 x64
bobkn
Danbury
You've got it backwards. Microsoft doesn't usually write drivers for third-party hardware. Why doesn't Creative offer official support for the Win8 beta releases?
I got the latest Win7 drivers for my X-Fi Titanium (not HD) to install using the "troubleshooting" option, set to Win7. After that, the auto-update feature gave me the Creative control panel and some other software.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    16 GB Gskill DDR3-2133
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Corsair Force GT 120GB
    WD Cavair Black 1.5TB
    PC Power & cooling Silencer 750
    Silverstone FT02B-W
    Noctua NH-D14 w/ PWM fans
    cheap Logitech USB wired
    old 5 button Microsoft USB optical
    6Mb cable
krohm
Closed as requested
well microsoft isnt supporting it either. nor is creative continuing to support their hardware on a new os. unbelievable on both counts
ive tried all it still doesnt work.
    Windows 8 x64
Airbot
Super Moderators
    LCARS
    Monkey Trainer Extraordinaire
    My toilet habits are a private matter, thanks.
    She finds stuff to do.
    Not that I can recall.
    XXX rated
    Huh?
    Monitors are lizards.
    I haven't found one yet.
    Sure isn't easy driving.
    Again, toilet habits are a private matter.
    Pending
    2 ice cubes.
    Nar, it has other key friends.
    Cat
    Warp 9.9
bobkn
Danbury
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Silverstone FT02B-W
    6Mb cable
m4tthall
June 28, 2012
X-Fi Beta drivers for Windows 8.
Creative Worldwide Support
Did this work for you? I am having problems. The sound isn't working in the RP but it was working for the CP. I have tried downloading and installing from that link as well. I get SBXF_PCDRV_WIN8_BETA_US_2_18_0015A.exe run it (tried admin/compatibility mode) but it just says "Setup is unable to detect a supported product on your system". I know for a fact I have the Sound Blaster x-fi XtremeGamer.
Any help would be most grateful
    Windows 8 RP
