Creating Wifi hotspot using SECOND wifi adapter
akashhhhh
6
So, there are many articles out there that will show you how to use cmd prompt to create a wifi hotspot (eg: this article http://www.eightforums.com/tutorials/52910-internet-connection-sharing-create-wifi-hotspot.html)
However, is there anyway to do this with TWO separate wifi adapters? That is, use one adapter to connect to your router and the other to act as the router? Some articles seem to indicate this is the ideal setup but no one seems to specify how to control which wifi adapter is used to create the wifi hostpot in command prompt.
Thanks for any help.
If I can get the basics to work, the next step is to try to integrate a VPN so that I can basically use my PC as a VPN router (but with no physical ethernet connection).
    Tahiti LE
broe23
Retired from the grind
Central IL
3,468
It is no different than bridging an Ethernet and Wifi adapter.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
