Create an external drive from a hard driveHard drive crash
Davjen457
2
Hard drive crash enquiry
My hard drive recently crashed on my desktop running XP and due to the discontinuation of support for XP, I decided to upgrade with a new motherboard, memory, hard drive etc., now running Win 8.1, which has been working fine so far. My problem is that there is data and pictures on the old hard drive which I would like to recover. Can someone advise whether it would be practical to re-install the failed drive along side my new HD in my desktop and reboot as normal and then try and access the failed drive like an external drive? I have already tried booting from the failed drive alone which did not get past the BIOS stage before switching off. Any suggestions would be helpful.​
    Windows 8.1 Pro 64
    Intel i5-4670
    Gigabyte GA-Z87X-UD3H
    8Gb
    3 TB WD NAS drive
    Corsair RM550
    AOpen
    BT
    NIS
MilesAhead
Eclectician
2,130
IIf the drive is Sata I or II then you can get a USB 2.0 Docking Station for around $20. Plug it in the USB port and slide the drive in. See if you can read it. If it doesn't work the dock is still handy to have.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
alphanumeric
slightly off center
Gold Member
You could hook it up internally as a slave. If it hasn't failed mechanically or become corrupted it should be viewable in Windows explorer.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Mark Phelps
1,041
IF you can't simply read from the drive, then it's time to try some data recovery apps.
Based on my experience at doing this successfully, my suggestions are the following:
1) Download and install the trial version of RecoverMyFiles from Runtime Software in MS Windows.
2) Right-click the RecoverMyFiles shortcut and select "Run as Administrator"
3) Select the option to Recover a Drive
4) You will get a list of drive, scroll down to find the one for your USB stick or memory card
5) Select Automatic Driver recovery, press Start button
6) It will run for a while but when done, will show a directory tree in the left pane. Do NOT interrupt it.
7) When done, browse the folders in the directory tree -- and be SURE to check the filesizes of the files you want to recover. If the filesize is zero, the file is trashed and you will NOT be able to recover it.
If the files look OK, you will need to contact Runtime Software to purchase a license for the recovery. You won't have to reinstall the app; instead, they will email you an activation code which you can use to turn on the recovery feature.
According to their website, the "standard" version of the app is $70 USD. They also have a Pro version for $99 dollars, but if you go to the website below, you can compare the features and (at least for me) the extra cost wasn't worth it:
Purchase Recover My Files data recovery software
Your data ... your money ... your choice.
