CPU Temp Problems - 30-40% usage
messagetyper
Every time I open task manager my CPU usually says it has 68-88 processes going on, and is usually sitting at 35-40% usage, sometimes even reaching 50. Is there a fix to this? The process that seems to be taking a lot is this "Service Host: Local System", is it safe to end this?
The CPU that I'm using is an i5 4590. OS would be Windows 8.1 Pro x64. Thanks.
    i5 4590 3.30 GHz
    4GB
    Zotac GTX 750 Ti 1GB
    1366 x 768
