Solved Couldn't find sound card and there's no sound
sophiewhy
2
Hi. I actually uses a macbook and bootcamp windows 8.1 in it. On windows 8.1, i tried listening to music but there's no sound coming out. i check the audio but there's a detection that the sound is playing but weird, not a sound can be heard from the video i was playing. It will only produce sound when i plug in external speaker. It means that, if i dont have a speaker and just on a video, no sound will come out even though there's a detection. What should i do ? :(
    Mac Boot camp with windows 8.1
chris1neji
124
You can attempt to experiment sending sound to various outputs. Please go to Control Panel > Hardware and Sound > Sound .
While under Playback tab, do a right click on any white area make sure "Show Disabled devices" & "Show disconnected devices" are checked. Take a screenshot of it and please upload it to us.
Since you are here try right clicking on all of the devices and selecting Test option for each device.
If you are able can you please double check Device Manager ? Press :orb: + R (On your keyboard at the same time. Then type devmgmt.msc
Tutorial on how to upload files and pictures (I recommend using the sniipping tool)
Screenshots and Files - Upload and Post in Seven Forums - Windows 7 Help Forums
    Windows 8 Pro 64-Bit
    N/A
    AMD FX 6300
    GYGABYTE GA-990FXA-UD3 Rev 3.0
    24GB DDR3 (4GB/4GB/8GB/8GB)
    Sapphire HD 6850
    Integrated (Realtek HD Audio)
    3 X 19" monitors
    4580 x 900
    WD 80GB
    WD 640GB
    WD 1,000GB
    WD 4,000GB
    Rosewill Hive-650
    Antec 300 V2
    Stock Cooling
    Saitek Eclipse II
    Logitech G402
    D: 60Mbps U: 5Mbps
    I also have a hub for 6 extra usb port AC powered.
    Microsoft LifeCam 720P
    HP LaserJet Pro M1212NF
    2 x 8 Port GB Switches
    1 X Netgear Router Netgear WNDR3700 v2 W/ DD-WRT
    and Much more
