I recently got a new Corsair Carbide 500R White case to replace a NZXT Tempest EVO, which the power switch jammed on and a front panel wire came off of. THE 500R's front panel wiring and fan connector's I could use some help with.The case's front panel power switch has power sw printed on it.The reset switch, hdd led and power led all have nothing printed on them.Also, which fan connector goes where [3 3 pin connectors.The top one is maybe 2-3 inches long The bottom one seems to fit the 200mm. side panel's fan.The middle one Iassume connets to the mobo.Thts how Ihave them now.Top oe unhooked, middle to mobo and bottom to side panel fan.Corsair's documentation stinks and is basically just a parts list.I'm not getting my pc to work. Not even using the mobo's power or reset button's. I've also tried my spare TX750 psu and still nothing my mobo speaker also meled while using zx1250w psu.Any help is appreciatedCorsair's forums told me tofill out a rma for the cas.I've tried that over 15 timesand it obviously doesn't work through i.e. on my xbox 360.I've also tried emaing them through gmail and outllook on the 360.Gmail doesn-t do it.Outlook.com worked and I received a confirmation.Haven't heard anything else from [email protected] HELP IS GREATLY APPRECIATED.P.S.Upgrading toCrosshair V Formula-z mobo next month.EVERYTHING WORKED IN OLD CASE UNTIL BUTTON JAMMED.
- Windows 8.1 Pro w/Media Center x64
- Computer type
- PC/Desktop
- System Manufacturer/Model
- self built
- CPU
- AMD FX 8350
- Motherboard
- Asus Sabertooth 990fx r2.0
- Memory
- G-Skill Ripjaws-X DDR3 2400 16 gbs.
- Graphics Card(s)
- MSI N760 TF 2GD5OC
- Sound Card
- on-bord Realtek ALC 889/ALC 892
- Monitor(s) Displays
- ViewSonic VX2250wm-LED
- Screen Resolution
- 1920 x 1080
- Hard Drives
- Samsung 840 Pro 256 gb. ssd. & Seagate Barracuda 7200.14 3.o tb.
- PSU
- Corsair HX-850 watt
- Case
- Corsair Carbide 500r White
- Cooling
- Corsair Hydro Series H-100, 3 120mm. & 1 200mm. case fan's
- Keyboard
- Logitech wired
- Mouse
- Logitech wired
- Internet Speed
- 30 m.b.p.s.
- Browser
- IE 11 & Firefox 26
- Antivirus
- BitDefender Internet Security 2014
- Other Info
- Iomega Pro Series U.S.B. 2.0/eS.A.T.A. 2.0tb. h.d., Seagate Backup Plus U.S.B. 3.0 3.0tb. h.d., Hauppage WinTV HVR-1850 t.v. tuner, Logitech x530 5.1 speaker's, Logitech c615 webcam, Logitech h150 headset, M.S. Xbox 360 wired gamepad & Xbox 360 as W.M.C. extender
