Solved copying files hit by power outage
makhan10
i was copying files from usb to hard disk when my computer was hit by power outage
when light came back, the files were gone, ie the files were neither present on usb nor on hard disk
    win 8.1
    HP Pavilion
    Intel 1.7 GHz i3 Core
    8GB
    500 GB
    8 Mbps
mrjimphelps
"Phelps Helps"
Try using some data recovery software. Here is one that I have heard good things about (although I have never used it myself): EaseUS Data Recovery Wizard - Best Data Recovery Software to Recover All Lost Data.
I suggest downloading this software to another computer if possible; or if that is not possible, download it to a different flash drive than the one that had the files. And when you run the install, install it to the same flash drive that you downloaded it to. My point is, the less activity you have on the two drives in question, the greater will be your chance of having success in recovering the files.
    Linux Mint 18.2 xfce 64-bit (host OS) / Windows 8.1 Pro 32-bit (virtual machine)
    Dell Inspiron 3847
    Haswell
    12 GB
    Acer 23"
    Two hard drives, 1TB each: One for Linux, one for my data.
    IBM Model M
    Firefox, Opera, Internet Explorer
    Sophos (Linux), Windows Defender (Windows)
    I use Samba to share my data drive with the other computers at my house.
