Control Panel
lostsoul62
Banned
I'm reading this book and it shows me what the control panel looks like in Windows 8 but I sure can't get to it. My control panel looks just like the one in Windows 7?
    XP Vista, Windows 7 & 8
    AMD 955 & Intel E6550
    I-Inc 28"
    A lot
    15 Megs
imacken
I'm sure that came from the DP. All that is now under 'More PC Settings' available at the bottom of the screen when you view the Settings charm from the Metro Start screen.
    Windows 8 Pro
Jav
Go to start and write User, switch to Settings and open Users.
There you have it now, enjoy :)
It is a bit different from picture (order of settings, some settings) as picture is probably from DP.
    Tetris
lostsoul62
Banned
Thanks, it's different from the picture but it the right place.
    I-Inc 28"
    A lot
    15 Megs
Hello Richard,
In W8 CP, that screen has been changed to PC settings now.
If you like, you can still open the normal Control Panel though.
Hope this helps,
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
