This tutorial will show you how to enable or disable access to the Control Panel, PC settings, and all settings in them for all or specific users in Windows 8 and Windows RT.
Published by Brink
- ByLine
- How to Enable or Disable Access to Control Panel and PC settings in Windows 8 and 8.1
- Synopsis
When disabled, this setting prevents Control.exe and SystemSettings.exe, the program files for Control Panel and PC settings, from starting. As a result, users cannot start Control Panel or PC settings, or run any of their items in them from any other location as well.
This removes Control Panel from:
The Start screen
File Explorer
This removes PC settings from:
The Start screen
Settings charm (ex: "Change PC settings" link)
Account picture
Search results
The Start screen
File Explorer
The Start screen
Account picture
Search results
EXAMPLE: Restrictions message
NOTE: This is the Restrictions error seen if users try to open the Control Panel, PC settings, or any settings in these two.
The downloadable .reg files below will add and modify the DWORD value in the registry keys below,
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoControlPanel DWORD
(delete) = enable Control Panel/PC settings
1 = disable Control Panel/PC settings
2. To Enable Access to Control Panel and PC settings for All Users
Enable_PC_settings_and_Control_Panel.reg
3. To Disable Access to Control Panel and PC settings for All Users
Disable_PC_settings_and_Control_Panel.reg
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve.
7. Sign out and sign in, or restart the PC to apply.
2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Control Panel. (see screenshot below)
3. In the right pane of Control Panel, double click/tap on Prohibit access to Control Panel and PC settings. (see screenshot above)
5. To Enable Access to Control Panel and PC settings
A) Select (dot) Disabled or Not Configured, click/tap on OK, and go to step 7 below. (see screenshot below step 6A)
6. To Disable Access to Control Panel and PC settings
A) Select (dot) Enabled, click/tap on OK, and go to step 7 below. (see screenshot below)
7. You can now close the Local Group Policy Editor window if you like.
- How to Open "PC settings" in Windows 8 and Windows 8.1
- How to Fix and Restore PC settings and "Change PC settings" in Windows 8.1
- How to Download a "PC settings" Shortcut for Windows 8 and Windows 8.1
- How to Open the Control Panel in Windows 8 and 8.1
- How to Set a Default Control Panel View in Windows 7 and Windows 8
- How to Add or Remove Control Panel from Navigation Pane in Windows 8 and 8.1
- How to Create a Control Panel "All Tasks List" "God Mode" Shortcut in Windows 7 and Windows 8
- How to Create a Control Panel Shortcut that Always Opens to Category View in Windows 7 and Windows 8
- How to Create a Control Panel Shortcut that Always Opens to Icons View in Windows 7 and Windows 8
- How to Add a "Control Panel" Cascading Desktop Context Menu in Windows 8 and 8.1
- How to Hide or Show Icons in the Control Panel in Vista, Windows 7, and Windows 8
- 64-bit Windows 10
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Custom self built
- CPU
- Motherboard
- Memory
- Graphics Card(s)
- Sound Card
- Monitor(s) Displays
- 3 x 27" Asus VE278Q
- Screen Resolution
- 1920x1080
- Hard Drives
1TB Samsung 970 EVO Plus M.2,
250GB Samsung 960 EVO M.2,
- PSU
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Keyboard
- Logitech wireless K800
- Mouse
- Logitech MX Master
- Internet Speed
- Browser
- Internet Explorer 11
- Antivirus
- Other Info
Linksys EA9500 router,
Arris SB8200 cable modem,
Lumia 1520 phone
