Having the same problem in win7, 8.1 and 10, all 64bit
I get this problem in win 7, 8.1 and 10. The cursor doesn't behave exactly the same on each platform, but is very similar.
However I can make this problem happen at will on win 10.
On win 7, the cursor beeps upon movement, and movement is slow and jerky and beeps on each "jerk". Unable to click on anything but keyboard control works perfectly.
On win 8.1, it is similar to the above but only after clicking does the beeping start.
On Win10 there is no beeping, untilI move the mouse and click for a while, but all other symptoms are the same.
On win 7 and 8.1 the problem seemed to be intermittent, maybe happened once every few days, sometimes weeks would go by without the problem.
On win 10 I can reproduce the problem at will currently, and here's how:
I have a powered USB 3.0 hub, 14A, 12 port + fast charge port. This is plugged into a USB 3.0 rear port on the mobo, and all seems to be working correctly. Plugged into this hub, is the following:
- Saitek pro combat pedals.
- Thrustmaster Warthog throttle and joystick (2 devices).
- TrackIR Proclip (power only)
Note the hub is metal, and is grounded.
The hub has a power switch, that also isolates the hub from the PC, so is disconnected when not powered.
Causing the problem to start is a simple as turning on the USB hub, or boot with it turned on (in windows 10) and then turn it off. The mouse lag begins until I restart the machine using the keyboard. Upon shut down, the system will seem to hang at the "shutting down" notice and needs a reset/5 second power switch press.
From prior use this might also be the situation in previous versions of windows, but it is not as predictable.
System specs:
- Asus Maximus VII Impact (miniITX) motherboard (+ all bundled devices)
- Intel i7 4790k cpu @4.4GHz (no overclock)
- 16GB Corsair Dominator Memory (2400) (xmp timing profile)
- Corsair AX860i psu + Corsair Link (internal usb dongle)
- USB 3.0 hub powered 14A, switched
- TM Warthog stick and throttle
- Logitech g910 keyboard (w software)
- Logitech g9x mouse (w software)
- Turtle beach atlas Titanfall headset (usb dongle attached to front usb 3.0 port)
- EVGA Nvidia Titan X SC GPU
- 2x BenQ XL2720Z & 1x BenQ XL2720T moitors attached via display port
Win7 build prior to upgrade showed the symptoms above with the following differences in hardware:
- Intel i7 4770k @4.6GHz (oc)
- 32GB Corsair OEM memory @ 1866 (oc)
- Asus Z87 Pro
- Sound Blaster ZxR
