Solved Constant BSOD in 8.1 Pro every 10 minutes, REGISTRY_ERROR
sonora
Hi, I’m getting constant BSOD approximately 10 minutes after booting 8.1 Pro (fresh install)
The BSOD restarts the computer and always mention REGISTRY_ERROR.
Please find more information in the attached file.
Thanks!
Hi Sonora & Welcome to the forums ^_^,
I have analyzed your dump files and below has been provided an analysis of the latest dump files as the rest of them are almost same :-
**************************Tue Sep  2 18:16:47.787 2014 (UTC + 5:30)**************************Loading Dump File [C:\SysnativeBSODApps\090214-3453-02.dmp]
Windows 8 Kernel Version 9600 MP (8 procs) Free x64
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
System Uptime: 0 days 0:01:12.458
Probably caused by : ntkrnlmp.exe ( nt! ?? ::NNGAKEGL::`string'+2a2d6 )
BugCheck 51, {1, ffffc001ec147000, 9d6f5f14, 1ea}
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000051]REGISTRY_ERROR (51)[/url]
Arguments:
Arg1: 0000000000000001, (reserved)
Arg2: ffffc001ec147000, (reserved)
Arg3: 000000009d6f5f14, depends on where Windows bugchecked, may be pointer to hive
Arg4: 00000000000001ea, depends on where Windows bugchecked, may be return code of
	HvCheckHive if the hive is corrupt.
BUGCHECK_STR:  0x51
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID:  0x51_nt!_??_::NNGAKEGL::_string_
Below is a list of 3rd party drivers present on your system :-
e1i63x64.sys                Wed Mar 20 13:07:29 2013 (51496739)
intelppm.sys                Thu Aug 22 14:16:35 2013 (5215CFEB)
dump_storahci.sys           Thu Aug 22 17:10:39 2013 (5215F8B7)
iwdbus.sys                  Fri Mar 14 03:29:14 2014 (53222A32)
igdkmd64.sys                Sat May 17 09:47:35 2014 (5376E2DF)
http://www.carrona.org/drivers/driver.php?id=e1i63x64.sys
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
http://www.carrona.org/drivers/driver.php?id=iwdbus.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
Please follow the below steps, one step at a time :-
  1. It appears that the Registry Corruption is causing the BSOD. Do you get the BSOD when the PC boots in safe mode? Please follow this **GUIDE** to run System File Checker. This should fix up the problems. Please note that it might take a while to complete. If the crash occurs before it is finished, see if you can run it from the safe mode or through an installation media.
  2. If the problem is still not solved then please run ChkDsk according to this **GUIDE**.
  3. If still not fixed then please run the Hard Drive Diagnostics according to this **LINK**.
Let me know how it goes ^_^
Thank you very much for your help blueelvis, here are the results:
- I run System File Checker and got this message:
“Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.log windir\logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not supported in offline servicing scenarios”
- I found no problems in drives.
- Although It was a fresh install, I found a couple of restore points that were created automatically and I was able to restore Windows.
- I run System File Checker again and obtained the following:
Windows Resource Protection did not find any integrity violations.
I haven’t got any BSOD since restoring Windows.
Thanks again for you help!
Hi Sonora ^_^,
I am glad to hear that the issue has been resolved. Would you please mark this thread as SOLVED?
