Connecting Surface RT to PC
livewire
Is there no way of connecting the Surface RT to a PC through usb to drag files from one to the other? :think:
    windows 8.1 Pro
    Intel 3770K i7 Ivy Bridge oc 4.5 GHz
    Asus P8Z77 Premium
    32GB Corsair Platinum
    Nvidia GTX 780
    Crucial 512GB SSD
    2x 3TB Seagate
    Corsair HX850
    Corsair White Graphite 600T
    Corsair H80i
    Roccat Isku
    Roccat Kone XTD
2xg
Hi everyone!
Hello,
Yes, there are two options for you, create a Homegroup by following this Tutorial from Microsoft.
Or....a must convenient way is to use Skydrive, and you may access your files remotely anywhere and anytime.
Hope this helps. :)
    Win 8.1 Enterprise
    Lenovo
    Intel i5
livewire
2xg thanks but they are like 8gb files. I'm just stunned you cannot connect via usb and just drag files across. I suppose I will have to buy a thumbstick when I get time
    windows 8.1 Pro
    Asus P8Z77 Premium
    Nvidia GTX 780
    Crucial 512GB SSD
    2x 3TB Seagate
    Corsair HX850
    Corsair H80i
    Roccat Isku
    Roccat Kone XTD
2xg
Hi everyone!
Homegroup might work for you, it can be a little hassle setting it up or buy a reasonable Network Attached Storage (NAS) so that you may store more files. There's a wired (connected to your router's ethernet port) or wireless NAS to choose from.
    Win 8.1 Enterprise
    Lenovo
    Intel i5
