Connect phone to computer via bluetooth - problem
falkenow
24
Hi,
I´m trying to connect my Samsung Galaxy S III to my new Asus LX302L via bluetooth.
Both have bluetooth vers. 4 and I have successfully connected other units to my phone earlier but now it doesn't work.
I can "see" both units and they are linked together via password but that's it.
After I linked them together, the status information on the computer says "Not connectet" for the phone. The same information is the phone saying about the computer.
All drivers are up to date.
I want to use my phone as a remote using "Unified remote" and I also want to play music via the phone out to the computer speakers. This I have been able to do with my old computer (windows 7) but now it doesn't work.
What should I do?
Best regards,
David
    Windows 8.1 64-bit
midou35000
Coming Over
Canada
532
Hi falkenow And Welcome To Eight Forums,
First Thing we have to check is see if the "Bluetooth Support Service" is running and set to "Automatic" by going to services.msc in the search.
    Windows 10
    HP
    Intel Core i7
    Nvidia Geforce GTX 680
    idfk
    15' 1080p display
    70Mbps
    Google Chrome Canary
    AVAST Premiere 2015
midou35000
Coming Over
Canada
532
Is the service running?:
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
midou35000
Coming Over
Canada
532
Do you see another service that start with the word "Bluetooth" that is not set to atomatic and running?
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
midou35000
Coming Over
Canada
532
#8
What does Kors mean?
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
midou35000
Coming Over
Canada
532
#10
Okay stay with me are you sure your driver is uptodate and tell me where did you check for your bluetouth driver's update?
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
midou35000
Coming Over
Canada
532
#12
On a older version did your driver work properly?
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
falkenow
24
#13
I got this computer just a week ago. I could however connect the phone to my old computer (windows 7).
But I can connect a bluetooth-mouse to this computer without any problem.
    Windows 8.1 64-bit
midou35000
Coming Over
Canada
532
#14
Is your Samsung Galaxy S III Rooted?
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
midou35000
Coming Over
Canada
532
#16
can you try any other phone to connect to ur PC (am sorry if i am annoying you).
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
midou35000
Coming Over
Canada
532
#19
SO its a problem in your PC, okay right click your task bar and click task manager then go to startup tab and enable all the startup items that u are not sure what they are then reboot and see if it is fixed. Maybee there is the bluetooth startup command disabled.
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
