Solved commands not recognized internal/external.. need help!
m18xr2
need some help here this is driving me crazy lol. using windows 8.
I have being using my windows for a very long time and its all setup, only thing that really doesn't work is making customized .bat file and try to run it, always giving me "is not recognized as an internal or external command."
now I have tried the same .bat file and works on another machine on a fresh install but fresh install windows is not an option on this one as I have way too much stuff done already.
this is whats in the a.bat file:
"taskkill /F /IM Steam.exe"
it is a simple straight forward taskkill of a software that would work and I don't need to set path as it is built in default into windows. if I type the full command "taskkill /F /IM Steam.exe" this under ANY directory in windows, any drive, it will kill steam.exe.
however if I were to run .bat file this is what I get:
as you can see above it doesn't recognize the command because it seems theres something or some "unknown letters" infront of t for taskkill. by changing taskkill to saskkill, it also shows those unknown letter is infront of s, so this actually is applying to every single of my .bat file and I am unable to run them. only way again is for me to type out entire command which is quite annoying as I can't make any shortcuts.
also, as you guys can see in the pictures, the slash is replaced with japanese symbol that is because I am using japanese system locale and no, switching back to english default language and locale still doesnt solve the problem..
please help, I am at wits end and can't seem to find any similar issue to mine on google.
solved, look at screenshot below. use notepad++ to change encoding and it'll work. or use the "echo" function below to create a clean .bat file.
    windows 8.1 and server 2012 R2
What happens if you just type in the command instead of running the batch?
I know in command prompt there can be issues with the code page. But I don't know enough about it to advise you. Perhaps another poster will have more specifics.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
hey, if i type just the command it will work. but if i were to create a .bat file then this happen, on every single bat file i create and i seriously have no idea why.
Try changing the extension from .bat to .cmd.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
tried that still no luck. still giving me same results as the screenshot haha.
would this be something to do with windows itself or some sort of service within windows?
Try doing the following from a Command Prompt.
Type echo "taskkill /F /IM Steam.exe" > a.bat and press Enter.
Now run a.bat and see what happens. Trying to figure out if the corruption is occurring on the creation of the .bat file or on the execution.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
holy smoke it worked. what does that command work? "echo "taskkill /F /IM Steam.exe" > a.bat" and what does this mean theres corruption somewhere and do I have to do similar thing for all my other .bat files as well?
this is new thing i did, looks like I might have to do this for every .bat just to make sure it works, still wayyy better than not able to run the file at all. i have a.bat and a.cmd with same information but the new command you made me type is now a.bat, a.cmd is the old one i simply rename the file.
edit: so maybe creating .bat file with notepad.txt and changing extension isn't such a good idea afterall.. is that the cause?
I believe Notepad uses what they call a BOM or byte order mark. Ansi uses single byte characters so that problem doesn't come up. But with multibyte characters such as used in Unicode this can arise.
Try a different editor such as EditPad Lite 7. It is free.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
yea you're right, found the problem is with encoding issue. a.cmd and a.bat have same content but the sizes are different. cmd is like 56 bytes where as .bat was like 26, only half the size. I used notepad++ to compared difference and found it was encoding, after switching encoding solved everything lol.
Glad you got it straightened out.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
Good job, nice to see things fixed.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
thanks guys. i'll post a screen shot for who needs an answer in the future happen to be same issue as I am facing. but if not for your "echo > a.bat" command I would never have gotten one that works, hence never find the right encoding in notepad++ as i didn't have a pair of working/nonworking ones to compare with.
thanks to Ztruker "echo "taskkill /F /IM Steam.exe" > a.bat"
