Solved Classic shell
notsosavvy
I just updated to windows 8.1 and cannot get the classic shell to work. I have downloaded it but was not asked which form I wanted and so far there is no start button. I cannot find the program anywhere. Also I cannot get avast to open. Is this another glitch in windows?
XweAponX
You probably have to uninstall it and re-install it.
If AVG can't open, is it still there? There is a new strain of Sirefef that has been floating around last week that prevents certain files from being downloaded, they vanish the moment they hit the hard drive. It takes over Windows Defender.
Try this:
http://kb.eset.com/esetkb/index?page=content&id=SOLN2895
See if it lets you download to the drive. If Not, go into Program Files, and change the name of the Windows Defender Folder to "Windows Defender Virus" or "-Old" or something, then try saving the file again.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
Did you install Classic Shell for 8.1 or for 8 ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
XweAponX
A-HA. if he updated, it would be the 8 version. Yah just update the app, download the new version.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
Ztruker
Had the Classic Shell problem on a Win 8 X64 upgrade to 8.1. Uninstalled and reinstalled it several times, never get the Classic Shell Start Menu icon. If I click on the Start button that comes with 8.1, nothing happens. Press the Windows key and I do get the Classic Shell start menu.
On my Toshiba laptop, I upgraded from Win 8 Pro X86 to 8.1 pro X86 via the store. Classic Shell was already installed on Windows 8.0. After the install, Classic Shell is still installed and works correctly. I did not have to uninstall.
No idea why the difference. So far have not been able to get Classic Shell start button working on the X64 system.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
notsosavvy
Ok, Avast is no where to be found.I had it on windows 8 but now it is gone. Classic shell is showing in the apps but there is no button in the left corner. I'm not a HE I'm an 83 year old grandmother. LOL It is always fun when no one knows that. I really would like my start button back. Not sure I can find the Defender, but I'll try.
notsosavvy
Went back and re downloaded classic shell I now have the button on the left. Yeah !! I cannot find the Defender files. Where do I look for that?
Ivo
OK. So you are saying that pressing the Win key opens the classic start menu. That means Classic Shell is installed and running. Open the Classic Shell settings from the start screen and either reset them (from the Backup button at the bottom) or poke the settings to find which are misconfigured. You can also save your settings to XML file and attach it here.
    Windows 7
RobNJ
Happened to me, too. Did the re-downloaded it, and clicked install, all my settings were where I had left them.
    Widows 8.1
    ASUS G750JX-DB71
    2.4 GHz Intel Core i7
    16 Gb
    Nvidia GTX770M
    Firefox/Chrome
Ztruker
Ivo, I've done all that. Also uninstalled and reinstalled the latest, no help.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
xpclient
Classic Shell tester
Make sure you are downloading Classic Shell from the correct website (www.classicshell.NET) and not ClassicShell.com
    Microsoft Windows
    I do the testing and give feedback on User Experience and ideas for Classic Shell.
Ztruker
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
arachnaut
I put Classic Start Menu in the Startup group to get it to automagically appear.
    Windows 8.1 Pro with Media Center (64-bit)
    Custom-build
    Intel Core i7-2600K @ 4.3 GHz
    ASUS P8P67 PRO Rev 3.0
    16 GB G.SKILL Ripjaws X DDR3 SDRAM DDR3 1600 (4 banks 4GB DIMM DDR3 8-8-8-24 5-32-12-7 1T 1.5V)
    NVIDIA GeForce GT 440
    Firewire Focusrite Saffire Pro 14
    LG W2353V
    2 of Seagate Barracuda XT ST32000641AS (2TB ea.);
    1 of Seagate Barracuda Green ST2000DL003 (2TB);
    1 of Hitachi Deskstar HDS722020ALA330 (2TB);
    2 of Seagate Desktop ST4000DM000-1F2168 (4TB)
    Corsair AX850 Gold
    Cooler Master HAF 932 Advanced
    ThermalTake Silent 1156
    Logitech K520
    Logitech M310
    7Mbps
    Chrome
    Kaspersky
    Event Studio Precision 6 powered audio monitors;
    Boston Acoustics CS Sub 10 Powered Subwoofer;
    NI Kore controller;
    NI Maschine controller;
    M-Audio Axiom 61 keyboard controller; expression pedal; sustain pedal;
    ... and tons of audio software ...
    I also keep two USB 3 thumb drives (A: and B:) attached with boot recovery and security stuff that I can boot into from BIOS in case of emergency
Ztruker
Can't do the xml now as the problem is fixed. The owner of the computer installed Classic Shell 3.6.8 and all is well. Npo idea why the latest 4.0.2 did not work correctly.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
