Solved Classic Shell Explorer Toolbar?
Dubbledoo
53
Hello again.
The loss of the Classic Shell toolbar in Windows Explorer is still puzzling me.
I've been through all the Classic Shell options (I think!) and messed around with Windows Explorer, but after installing 8.1 the toolbar seems to have disappeared.
I used to have all the View buttons pinned to the bar and I'm really missing it. I know they can be put in the Quick Access Bar, but it's not as usable/fast as the Classic Shell version (the change as hovering I also find very annoying).
Any Ideas folks?
EDIT: Just realise I hadn't checked the version I was using. It's 4.0.4 and re-checking the developers site I've now realised that they're up to 4.0.6 ------ Could this be the issue?
I seem to remember that 4.0.6 was not yet stable, or have I dreamt that - I think I probably have :think:
    HP Pavillion
You mean this:
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Dubbledoo
53
Ah right, but for me the option's not there. I've updated to 4.0.6 and gone through all the settings again.
    HP Pavillion
Ivo
158
First, make sure you have installed the Classic Explorer component (not just the start menu). Second, look at these troubleshooting steps: Classic Shell: FAQ
And third, I see you have some other bars installed. Sometimes Explorer gets confused when there are multiple bars. Go to the registry, open the HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser key and delete the ITBar7Layout value.
    Windows 7
Dubbledoo
53
Thanks Ivo. You are a star. That worked perfectly. :thumbsup:
    HP Pavillion
