Solved Changing background color and accent color
mallen
32
I am try to change the background color and accent color. I used to be able to go to "settings", then ""change PC settings" and it would have an option for "personalization". The only way I found to get to that was search for "accent".
23,516
    3 x 27" Asus VE278Q
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Cliff S
Missing my GIF avatars:(
Bamberg Germany
2,390
Right click on desktop and personalize will show.
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    ZOTAC GAMING GeForce RTX 2080 Ti AMP! Extreme Edition
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7490
    Sound system: Philips Soundbar HTL2160 w/subwoofer
23,516
Mallen,
If you have Windows 8.1, then you'll need to use OPTION ONE instead. Be sure to do it from your Start screen and not from your desktop. This location is critical.
OPTION TWO is no longer available in Windows 8.1.
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
23,516
Did you open Settings while on your Start screen?
It will not be there if you open Settings while on your desktop.
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
Cliff S
Bamberg Germany
2,390
#8
Brink means here.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
23,516
#10
Great news. :)
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
