Changed RDP listening port, not 3389 wont work
DOYAM
Changed RDP listening port, now no ports work
I just built a new HTPC, put Windows 8.1 on it, had RDP working fine for days. Even out of my house with port forwarding. Once I got everything where I wanted it, the last step was to change the port for security. I changed the registry Port Number (at HKEY_LOCAL_MACHINE, SYSTEM, CurrentControlSet, Control, Terminal Server, WinStations and RDP-Tcp), to a 5 digit number starting with 13 so its within the limits (also, I used to use the same port previously with Windows 7). Restarted and I could not connect. It did not work. So I tried putting it back to 3389 and its broken now too. I have a laptop on 8.1 also and changed it at the same time, now I have the same issues. I have tried everything I can think of. Check and even turned off the Firewall, used netstat -a and it seems to be listening on the correct port.
It seems to me there is something else at play here. Can anyone help me? This is at a bad time since I have leaving town for a few days and need access, I have to use VNC.
Help please.
FYI, I posted this exact same question here and have gone through some diagnostic steps to no avail: https://social.technet.microsoft.co...tworking#45858022-e0f2-442d-80cc-c24c20f3b2e7
amir77a
Did you configured your router and your Windows firewall ?
    Win 8.1 Prof.
    Asus N55-JV
    Core i7 (4700HQ)
    8 Gigs
    nVidia GT750M
DOYAM
Sorry for the late reply. As I mentioned I had it working great before and I have configured my firewall and router. The router does not matter as I am only trying to get it working inside my network right now.
play2mefish
Did you remember to use the correct port when requesting a remote desktop connection: 192.168.1.10:3391 ???
Make sure the firewall is configured to listen and accept connections via the new port.
    Windows 8 Pro
    ASRock 990FX Killer
    AMD FX 8320
    ASRock 990 FX Killer
    32gb
    Gigabyte GTX 750i
    Realtek (Stock on MB)
    ASUS 27 HD Monitor & a 37" LCD HD TV Screen (For movies)
    1 250 GB SS hard drive for OS
    1 1TB hard drive for data / mirrored to a second 1 TB hd.
    650W
    No name tower
    Enermax Liqtech 240
    Logitech
    Logitech
    Dnload 10.48 Upload .48
    IE 11 and Chrome when IE doesn't work
    F-PROT
Ztruker
Space coast of Florida
The default RDP port is 3390, not 3389. Try that.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
DOYAM
Thank you for all your input. I just tried to change it using 3389, 3390 and 3391. I am pretty sure the default RDP port is 3389 but it doesnt really matter. I changed it in regedit as I described above, I changed it in the router's settings as well and I turned off the firewall to make sure that wasnt it. I am doing all this remotely via TightVNC so I know how to configure these things. It like when I changed that listening port, it broke some other setting and I cannot put it back.
Ztruker
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
DOYAM
Thank you guys for your help again. I think this was my mistake and I was not clicking "decimal" when I changed the port. It was on "hexidecimal". It works now.
Ztruker
Yeah! Glad you have it working.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
