Can't connect to this network (wifi problems)
Glock
hey guys, new here. been having this problem for over a month now, I think it happened when i switched from windows 8 to windows 8.1.
Try connecting to wifi network, it takes a long time and finally I get a "can't connect to this network"
I have extensively used google with no luck. I have no problem connecting at home, but at work it is now impossible.
Again, I'm new to this forum, if I am missing some information for you guys I appologize in advance and will post what you guys need.
thanks,
Paul
    windows 8.1
ectech
Banned
Hi Glock,
  • Please copy & paste the following into notepad.
  • Code:
    netsh wlan show all >%userprofile%\Desktop\Network.txt
    sc query dhcp >>%userprofile%\Desktop\Network.txt
    sc query dnscache >>%userprofile%\Desktop\Network.txt
    sc query wlansvc >>%userprofile%\Desktop\Network.txt
    ipconfig /all >>%userprofile%\Desktop\Network.txt
    netsh advfirewall show global >>%userprofile%\Desktop\Network.txt
    netsh winhttp show proxy >>%userprofile%\Desktop\Network.txt
  • Save the file as "Network.bat"
  • Right click the file and select Run as Administrator.
  • This will create a file called "Network.txt" on the desktop.
  • Copy & paste the contents into your next post.
    Windows 8.1 Enterprise
Glock
Hi ectech,
I have made the file on my laptop (currently at work, using my co-workers mac) if I can find a USB stick to transfer the file to this computer I will post asap. Worst off I will be able to post once I get home and have a connection on my personal laptop.
thanks for the patience,
Paul
    windows 8.1
Glock
Since I was on another computer, I had to manually type into my laptop what you originally asked me to copy/paste. Had no USB stick/internet connection (stupid me) so I hope I typed everything in correctly and here it is:
The following command was not found: wlan showall.
SERVICE_NAME: dhcp
TYPE : 20 WIN32_SHARE_PROCESS
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: dnscache
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: wlansvc
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Windows IP Configuration
Host Name . . . . . . . . . . . . : MASHEEN
Wireless LAN adapter Local Area Connection* 15:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 86-A6-C8-56-5A-7C
Wireless LAN adapter Local Area Connection* 12:
Physical Address. . . . . . . . . : 84-A6-C8-56-5A-7D
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 2230
Physical Address. . . . . . . . . : 84-A6-C8-56-5A-7C
Global Settings:
IPsec:
StrongCRLCheck 0:Disabled
SAIdleTimeMin 5min
DefaultExemptions NeighborDiscovery,DHCP
IPsecThroughNAT Never
AuthzUserGrp None
AuthzComputerGrp None
AuthzUserGrpTransport None
AuthzComputerGrpTransport None
StatefulFTP Enable
StatefulPPTP Enable
Main Mode:
KeyLifetime 480min,0sess
SecMethods DHGroup2-AES128-SHA1,DHGroup2-3DES-SHA1
ForceDH No
Categories:
BootTimeRuleCategory McAfee Personal Firewall
FirewallRuleCategory McAfee Personal Firewall
StealthRuleCategory Windows Firewall
ConSecRuleCategory Windows Firewall
Ok.
Current WinHTTP proxy settings:
Direct access (no proxy server).
    windows 8.1
Glock
I just tried that, but with no luck. still cannot connect. anyone else having this issue? ive used google extensively and cannot find any answers to this problem. so frustrating.
    windows 8.1
Glock
Just got back home. Did it at work last night, here it is sir:
Wireless System Information Summary
(Time: 2013-12-29 11:05:18 PM Atlantic Standard Time)
============================== SHOW DRIVERS ===========================
Interface name: Wi-Fi
Driver : Intel(R) Centrino(R) Wireless-N 2230
Vendor : Intel Corporation
Provider : Intel
Date : 2013-08-22
Version : 15.10.3.2
INF file : C:\WINDOWS\INF\oem48.inf
Files : 3 total
C:\WINDOWS\system32\DRIVERS\NETwew00.sys
C:\WINDOWS\system32\DRIVERS\Netwfw00.dat
C:\WINDOWS\system32\drivers\vwifibus.sys
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
Authentication and cipher supported in ad-hoc mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA2-Personal CCMP
IHV service present : Yes
IHV adapter OUI : [00 80 86], type: [00]
IHV extensibility DLL path: C:\WINDOWS\System32\IWMSSvc.dll
IHV UI extensibility ClSID: {1bf6cb2d-2ae0-4879-a7aa-a75834fbd0e3}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
============================= SHOW INTERFACES =========================
There is 1 interface on the system:
Description : Intel(R) Centrino(R) Wireless-N 2230
GUID : fb703a78-4582-453a-9a6d-01ee986be829
Physical address : 84:a6:c8:56:5a:7c
State : disconnected
Hosted network status : Not started
=========================== SHOW HOSTED NETWORK =======================
Hosted network settings
Mode : Allowed
SSID name : "DIRECT-4z-MASHEEN"
Max number of clients : 8
Authentication : WPA2-Personal
Cipher : CCMP
Status : Not started
============================= SHOW SETTINGS ===========================
Wireless LAN settings
Show blocked networks in visible network list: No
Only use GP profiles on GP-configured networks: No
Hosted network mode allowed in WLAN service: Yes
Allow shared user credentials for network authentication: Yes
Block period: Not Configured.
Auto configuration logic is enabled on interface "Wi-Fi"
============================== SHOW FILTERS ===========================
Allow list on the system (group policy)
<None>
Allow list on the system (user)
<None>
Block list on the system (group policy)
<None>
Block list on the system (user)
<None>
=========================== SHOW CREATEALLUSER ========================
Everyone is allowed to create all user profiles.
============================= SHOW PROFILES ===========================
Profiles on interface Wi-Fi:
Group policy profiles (read only)
<None>
User profiles
All User Profile : Jackman2013
All User Profile : Jackman 2013
All User Profile : BELLALIANT013
========================== SHOW PROFILES NAME=* =======================
Profile Jackman2013 on interface Wi-Fi:
Applied: All User Profile
Profile information
Version : 1
Type : Wireless LAN
Control options :
Connection mode : Connect automatically
Network broadcast : Connect only if this network is broadcasting
AutoSwitch : Do not switch to other networks
Connectivity settings
Number of SSIDs : 1
SSID name : "Jackman2013"
Network type : Infrastructure
Radio type : [ Any Radio Type ]
Vendor extension : Not present
Security settings
Authentication : WPA-Personal
Cipher : TKIP
Security key : Present
Cost settings
Cost : Unrestricted
Congested : No
Approaching Data Limit : No
Over Data Limit : No
Roaming : No
Cost Source : Default
Profile Jackman 2013 on interface Wi-Fi:
Profile information
Version : 1
Type : Wireless LAN
Control options :
Number of SSIDs : 1
SSID name : "Jackman 2013"
Security settings
Cipher : TKIP
Cost settings
Cost : Unrestricted
Congested : No
Roaming : No
Profile BELLALIANT013 on interface Wi-Fi:
Profile information
Version : 1
Type : Wireless LAN
Control options :
Number of SSIDs : 1
SSID name : "BELLALIANT013"
Security settings
Cipher : CCMP
Cost settings
Cost : Unrestricted
Congested : No
Roaming : No
======================= SHOW NETWORKS MODE=BSSID ======================
Interface name : Wi-Fi
There are 2 networks currently visible.
SSID 1 : Wi-Fi
Authentication : Open
Encryption : None
BSSID 1 : 00:3a:99:00:c8:f1
Signal : 38%
Radio type : 802.11g
Channel : 11
Basic rates (Mbps) : 1 2 5.5 11
Other rates (Mbps) : 6 9 12 18 24 36 48 54
SSID 2 :
Encryption : CCMP
BSSID 1 : 00:3a:99:00:c8:f0
Signal : 38%
Channel : 11
    windows 8.1
Zaref
i do have the same problem with my lenovo G580 with windows 8 pre installed
after upgrading to 8.1 nothing changed for about 2 days
after that it worked perfectly for me till 4 or 5 days ago
i'm really confused
i wish you can help :)
    Lenovo G580
    Inter Core I5 3210M
    4GB
    Nvidia Geforce 610
    1366*786
    1MBpS
    Avira
    medical student who enjoys gaming
Glock
THANK YOU THANK YOU THANK YOU!
Is there any reason why windows did not prompt me for this driver? I have checked for updates around the clock and it said everything was up to date. Installing now, will try it at work tomorrow and hopefully this will work.
If you are into bitcoins, I would love to send you a small donation (about 50$ worth) for your much appreciated help.
    windows 8.1
Glock
sadly i cannot (i work as a power engineer in a hospital) i'll try to contact the IT guy (if we have one) see if he can perform a bard reset. in a very secluded area up north, hard to get IT guys here.
on a side note, before i started having the original problem i would get limited connection a lot. maybe its one of those days. sorry, and thanks a bunch for the help
    windows 8.1
ectech
Banned
Most public places require you accept the terms of service before connecting to the network.
Open Internet Explorer after connecting to see if their is an agreement page.
Glock
just tried, no agreement or anything. just says "you're not connected to a network"
still on limited connection. if i run a diagnose it says "wifi doesn't have a valid IP configuration"
    windows 8.1
Glock
name is "wi-fi" i have successfully connected since i started working here in March. some days it would go to limited for anywhere from 10min to a day. my co-worker is able to connect as we speak.
diagnostics says wifi does not have valid IP configuration.
    windows 8.1
ectech
Banned
Press :winkey: + X > select Command Prompt (Admin) > copy & paste
netsh wlan delete profile name=*
into command prompt > press enter.
Try connecting to the wireless network again.
The other option it to manually set the IP address. Let me know..
