can usb drive be opened without affecting c drive?
70
my flash drive shows some virus so i am scared that when i open it then the virus will be transmitted to the c drive and make my pc slow. so is there any method that i can open the drive virtually in my pc and remove and delete those affected files? please help
    windows 8 pro 64-bits
    1GB AMD
znod
2,156
Generally, it would be possible to scan the device without opening. Check out what your AV program can do. What are you using for AV? I looked at Windows Defender; looks like it will scan all locations unless some are excluded. I'd want to be sure though.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
Just open up defender by going to charms, search, type in defender, select defender, select settings tab, then go to the advanced tab on left hand side, tick box to "scan removable drives", save changes...insert your usb drive and run defender.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
70
kaspersky 2013 int security.....my usb has some folder having name with some script.such as chinese and some symbols showing size 8 GB ,,,,so what is this? have u ever experienced such virus
    1GB AMD
znod
2,156
Not sure what it is. Haven't experienced it. Can you scan it specifically in Kaspersky. Try it, but be sure all is OK before letting anything on it loose.
    EVGA 570 SC
    Gateway
    Dual Boot:
topgundcp
San Jose - California
2,847
First you need to turn off Autorun. Autorun is a Windows feature that automatically executes using what instructed in a hidden file called Autorun.inf resided in the root folder of your Drive(s) and hackers use this to spread viruses to your PC.
Win+X -> Run
and type gpedit.msc
Administrative Templates >Windows Components > Autoplay Policies
, double click "Turn off Autoplay", Next is click Enabled, and then select All drives so that you can disable Autorun on all drives.
Next, Set your folder Options to show Hidden File then plug in your USB stick, look in the root folder, if there is an Autorun.inf , edit it with notepad to find out what is being instructed to run then delete it, if there's an executable file or a vbscript etc.., you will need to delete those also . In addition, check the root folder of all Drives connected to your PC.
To learn more about autorun, Please read this article:
Is autorun really that evil, and if so, how do I turn autorun off?
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
znod
2,156
Great info.
    EVGA 570 SC
    Gateway
    Dual Boot:
