Can I add Network (Ethernet and WIFI) icon to taskbar?
pcumming
30
I have been searching but have not searched perhaps as far as I should
In my Windows 8 taskbar on the right there are a few items I can select and customize but see no selection for network icons.
I am using Windows 8 with Start8 product add-in.
I can see speaker icon, skydrive icon, troubleshooting icon and so on......
This is an HP Envy 15t laptop.
I can get to Charms to show up and select Devices.....among other things
Thank you in advance
Peter
24,084
Hello Peter,
You should be able to turn on the Network icon for your taskbar in your System Icons settings below.
If you mean the Charms bar (black bar on right that slides in), then click on the Settings charm to see the Network icon at the top right corner of the bottom section.
If you like, here's a shortcut below that opens directly to the Networks flyout.
Hope this helps, :)
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
pcumming
30
Thanks, I did not try the Customize option from the Start Menu but will try that.
I did try the right side of the taskbar that shows the same screenshot as yours with the "Show ICONS and NOTIFICATIONS" and did not see a Network selection
Will look again later
Thanks so much
peter
