BSOD with StorPort.sys.... possible cause?
lotherius
BSODs with StorPort.sys AND Hal.dll... updated with diags
I've been struggling with a BSOD that happens while my computer is idle.
It has triggered both a HAL error and two storport.sys errors... I think it's actually hit a few more times, because I've found my computer "off" when it shouldn't be, and only an "unexpected shutdown" is recorded with no BSOD information. Have seen a few posts on here with BSOD related to storport.sys also, that don't seem to really find a cause.
EDIT---
I thought it was due to Renesas USB 3.0 drivers, but I uninstalled those and moved my external drives to different non-3.0 ports and it bluescreened again overnight. This time it was Hal.dll that bluescreened, it's been one or the other now 4 times in just a few days, always when the computer has been idle for a long time..
I installed Windows 8 fresh back in January, to get off of the preview now that full 8 is out. It ran fine and without issue until just the last few days.
I've attached the SF Diagnostic Tool logfiles.
    Homebuilt
    AMD Athlon II 440
    MSI 880GMA-E45
    8GB DDR3
    HD6850
    Onboard
    Acer P224w
    1680x1050
    2x500GB WD5000AACS WD RAID
    3x1TB HD103UJ Samsung RAID
    1x2TB HD204UI Samsung
    2x500GB USB External
    Dell XPS 730 1000 Watt
    Dell XPS 730
usasma
Mr. Cranky Pants
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
lotherius
OP Updated with attachment. Had another bluescreen last night/this morning some time. That's been 2 hal and 2 storport.sys errors.
My hard drive configuration is probably related....
I have 2 500GB drives on motherboard RAID as my system drive. 3 1TB drives as Windows Dynamic Disk "raid", 1 2TB standard drive, and 2 external USB drives... lots of opportunities for weirdness.
The Renesas drivers I had were updated for Windows 8, so apparently they were blameless based on that and the fact the last blue screen happened AFTER I removed those drivers.
    Homebuilt
    AMD Athlon II 440
    MSI 880GMA-E45
    8GB DDR3
    HD6850
    Onboard
    Acer P224w
    1680x1050
    Dell XPS 730
usasma
Mr. Cranky Pants
IME hal.dll errors are low-level errors, these include:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS problems (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
Your BIOS dates from 2011. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
This device is disabled. Is this deliberate? If so, why?
Please enable the device and then update it - then you can disable it again if you'd like.
VirtualBox Host-Only Ethernet Adapter ROOT\NET\0000 This device is disabled.
I'd suggest replacing your RAID drivers because of the storport errors (they call RAID functions in the memory dumps). But that's just a guess on my part.
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Windowns systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
I have seen issues with Virtual Box on one or two systems. While not a firm diagnostic, it's something to remember for later on.
ElbyCDIO.sys Thu Dec 16 17:58:13 2010 (4D0A9985)
CDRTools/ElbyCDIO/DVD Region Killer/VirtualCloneDrive (elby CloneDVD™ 2)/AnyDVD
http://www.carrona.org/drivers/driver.php?id=ElbyCDIO.sys
VClone.sys Sat Jan 15 11:21:04 2011 (4D31C970)
VirtualCloneCD Driver by Elaborate Bytes AG
http://www.carrona.org/drivers/driver.php?id=VClone.sys
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[FONT=lucida console]**************************Fri Feb 15 08:37:28.368 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\021513-48141-01.dmp]
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]0 days 6:32:50.579[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiPageFault+260 )[/B]
BugCheck [B]A, {fffffbffffd0172c, d, 0, fffff803fc221e64}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000000A"]IRQL_NOT_LESS_OR_EQUAL (a)[/URL]
Arguments:
Arg1: fffffbffffd0172c, memory referenced
Arg2: 000000000000000d, IRQL
Arg3: 0000000000000000, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff803fc221e64, address which referenced memory
BUGCHECK_STR:  AV
PROCESS_NAME:  dwm.exe
FAILURE_BUCKET_ID: [B]AV_nt!KiPageFault[/B]
  BIOS Version                  V17.10
  BIOS Release Date             02/28/2011
  Manufacturer                  MSI
  Product Name                  MS-7623
**************************Fri Feb 15 02:02:45.917 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\021513-88795-01.dmp]
System Uptime:[B]0 days 12:15:35.616[/B]
Probably caused by :[B]storport.sys ( storport!RaidUnitReleaseIrp+22 )[/B]
BugCheck [B]D1, {2, 2, 0, fffff88001272422}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D1"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000000000002, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88001272422, address which referenced memory
BUGCHECK_STR:  AV
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]AV_storport!RaidUnitReleaseIrp[/B]
  BIOS Version                  V17.10
  Manufacturer                  MSI
**************************Thu Feb 14 13:45:20.079 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\021413-58359-01.dmp]
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]0 days 0:02:07.776[/B]
BugCheck [B]D1, {2, 2, 0, fffff8800140b422}[/B]
Arguments:
Arg4: fffff8800140b422, address which referenced memory
BUGCHECK_STR:  AV
  BIOS Version                  V17.10
  Manufacturer                  MSI
**************************Thu Feb 14 13:40:58.755 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\021413-65801-01.dmp]
System Uptime:[B]1 days 11:24:10.313[/B]
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
BugCheck [B]A, {fffffbffffd0172c, d, 0, fffff800e2968e64}[/B]
Arguments:
Arg4: fffff800e2968e64, address which referenced memory
BUGCHECK_STR:  AV
  BIOS Version                  V17.10
  Manufacturer                  MSI
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]ElbyCDIO.sys                Thu Dec 16 17:58:13 2010 (4D0A9985)[/B][/COLOR]
[COLOR=RED][B]VClone.sys                  Sat Jan 15 11:21:04 2011 (4D31C970)[/B][/COLOR]
amdsbs.sys                  Tue Feb 21 13:15:43 2012 (4F43DF4F)
[COLOR=RED][B]AODDriver2.sys              Thu Apr  5 05:23:37 2012 (4F7D6499)[/B][/COLOR]
netr28x.sys                 Wed Apr 11 04:25:34 2012 (4F853FFE)
Rt630x64.sys                Mon Jul 30 12:03:12 2012 (5016B040)
usbfilter.sys               Tue Aug 28 21:27:12 2012 (503D6FF0)
LHidFilt.Sys                Tue Sep 18 05:26:53 2012 (50583E5D)
LMouFilt.Sys                Tue Sep 18 05:26:58 2012 (50583E62)
VBoxNetFlt.sys              Fri Oct 26 12:59:41 2012 (508AC17D)
VBoxUSBMon.sys              Fri Oct 26 12:59:41 2012 (508AC17D)
VBoxDrv.sys                 Fri Oct 26 13:00:50 2012 (508AC1C2)
RTKVHD64.sys                Tue Dec  4 08:28:37 2012 (50BDFA85)
AtihdW86.sys                Tue Jan 15 15:41:28 2013 (50F5BEF8)
atikmpag.sys                Sat Feb  2 14:40:11 2013 (510D6B9B)
atikmdag.sys                Sat Feb  2 15:51:55 2013 (510D7C6B)
PROCMON23.SYS               Tue Jun 19 15:24:55 2012 (4FE0D207)
VBoxNetAdp.sys              Fri Oct 26 12:59:42 2012 (508AC17E)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=amdsbs.sys
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=netr28x.sys
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
http://www.carrona.org/drivers/driver.php?id=LHidFilt.Sys
http://www.carrona.org/drivers/driver.php?id=LMouFilt.Sys
http://www.carrona.org/drivers/driver.php?id=VBoxNetFlt.sys
http://www.carrona.org/drivers/driver.php?id=VBoxUSBMon.sys
http://www.carrona.org/drivers/driver.php?id=VBoxDrv.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW86.sys
PROCMON23.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=VBoxNetAdp.sys
    Samsung/NP780
    800x600
