Solved BSOD with drive_power_state_failure error
zero123qwe
my laptop is an asus with nvidia geforce 840m and intel core i7-4510u
these recent week, my laptop having significant slow down on top of very long startup and shutdown process
even after i format my laptop,the problem still persist
hope someone could help cause im at my wits end here
thank you
my dump file : https://drive.google.com/open?id=0B8xDo_mT5dmsNEpxU2pFNEdacjQ
ps, sorry for my bad english,its not my native language
Please visit Windows Update and install every update available, it may take a couple of times to get them all, the exception is for Windows 10 update.
Hotfix(s):                 18 Hotfix(s) Installed.
Please fill in your system specs
Please follow this tutorial and download the tool. The tool will give you detailed information about your system specs, please fill in your system specs more completely including PSU, cooling and other used stuff like mouse, keyboard, monitor, case, etc.
The PSU, cooling and other stuff are NOT mentioned in the tool.​
How to fill in your system specs:
picture.php
picture.php
my apologize ,i am new to this site and i was not aware of system specs information requirement in the profile section, anyway
i have written down the specs info in my profile (apologize if the information spec isn't complete as i am not fully knowledgeable about computer and such ) and as for windows update,i have updated it to the latest one
here the new dump file: https://drive.google.com/open?id=0B8xDo_mT5dmsNEpxU2pFNEdacjQ
and dm_log info
Diagnostics Test
HDD TEST
Run SeaTools to check the integrity of your HDD. SeaTools for DOS and Windows - How to Use - Windows 7 Help Forums
Run following tests
  1. Short Drive Self Test
  2. Short generic
  3. Long generic
If the short generic fails, no need for the long generic.
Do not run SeaTools on an SSD as the results will be invalid.
Post screenshots/photos of the test results
Run chkdsk
Disk Check - Windows 7 Help Forums
Upload the chkdsk log :ar: Chkdsk Log in Event Viewer - Read in Windows 10 - Windows 10 Forums
Run HDTune to
  • scan for errors, no quick scan but full scan
  • check the health,
  • benchmark.
It may take some time, but please take the time you need to perform it properly.
When above is done please make screenshots of the following
  • the error scan,
  • the health,
  • the benchmark incl. following
    • transfer rate,
    • access time,
    • burst rate,
    • cpu usage.
sorry for the long wait, finally everything is done, thank you for your patience and helping me btw
so anyway here what i got
Please open an admin command prompt and enter following command
chkdsk C: /r
This command scans for bad sectors, marks them as bad and attempts to recover the readable data. To do this the partition needs to be unmounted meaning that the partition cannot be in use, you would have to reboot. When asked if you would like to schedule to check the volume press Y and reboot.
It can take a couple of hours for the command to finish, please let it run and do NOT interrupt it, interrupting may make things worse like causing the OS become unbootable or something.
It may look like nothing is happening or it is freezing or something, please do nothing as the system is checking the volume.
This is not a permanent fix, only a temporary one. This fix gives you extra time to backup your data and replace the drive
From the looks of the results it is possible that your drive can fail soon.
Yes, the problems that will occur if not acted a.s.a.p. can only be delayed for some time but not resolved.
With 'the problems' I do not only mean BSODs, but eventually a drive that is unbootable.
well that sucks for me, anyway thank you for your help, you were very helpful and cooperative , thank you and goodbye
