Solved BSOD when starting machine with reoaired graphics card
banger
Hi
I had an MSI GT610 graphics card go faulty, the DVI port started showing artifacts and had a red tint, Manufacturer replaced with a refurbished V2 GT610. At first it booted ok into Windows but clock speeds were wrong (550 instead of 810 and memory clock 600 instead of 1200).
On second boot after boot selection screen went black and artifacts could be seen with all I could see was a counter counting up to 100%. I now think this was a BSOD after examining the System Event Log and finding a mini dump. Can someone have a look at the mini dump and confirm this is either a hardware problem or driver problem. Have replaced the MSI V2 with an Asus GT610
Tim
    MSI MS7360
    Intel E8400 (Wolfdale)
    MS 7360 P35 V1.0
    4 GB
    MSI Geforce GT610
    Realtek Onboard
    Dell 19" Widescreen
    3 x 500 GB Hitachi and Seagate Drives
    Corsair 500W
    Generic
    2 case fans, Artic CPU Cooler
    Logitech G19
    MS Comfort 4500
    19 mbps
    MS Defender
softwaremaniac
A lot of problematic drivers but I'd point my finge4r at the GPU driver or at the GPU itself.
Uninstall or update software related to drivers in red, but focus on the GPU.
I would suggest you to uninstall the currently installed nVidia driver using the Display Driver Utility from this **LINK**. Once it has removed the drivers, reinstall the latest drivers from their website and see if the crashes persist or not.
[COLOR=red][B]nuvvid2.sys Thu Sep 20 10:58:46 2001  (3BA9AFC6)[/B][/COLOR]
[COLOR=#777777][COLOR=#4b0082]nuvvid2.sys[/COLOR] - this driver hasn't been added to the DRT as  of this run. Please search Google/Bing for the driver if additional information  is needed.[/COLOR]
[COLOR=red][B]WinRing0.sys Sat Jul 26 15:25:10  2008 (488B25B6)[/B][/COLOR]
many different programs that center around the  using of the WinRing libraries (RealTemp, Corsair Link2 (known BSOD issues  w/Win8), Razer GameBooster, Fusiontweaker (Google Code), etc)
[URL="http://www.carrona.org/drivers/driver.php?id=WinRing0.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]WinRing0.sys[/COLOR][/B][/URL]
[COLOR=red][B]LGVirHid.sys  Tue Nov 24 02:36:26 2009 (4B0B389A)[/B][/COLOR]
Logitech Gamepanel Virtual  HID Device Driver
[URL="http://www.carrona.org/drivers/driver.php?id=LGVirHid.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]LGVirHid.sys[/COLOR][/B][/URL]
[COLOR=red][B]LGBusEnum.sys  Tue Nov 24 02:36:26 2009 (4B0B389A)[/B][/COLOR]
Logitech Keyboard
[URL="http://www.carrona.org/drivers/driver.php?id=LGBusEnum.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]LGBusEnum.sys[/COLOR][/B][/URL]
[COLOR=red][B]vmlitedrv.sys  Tue Jun 29 19:19:56 2010 (4C2A2B3C)[/B][/COLOR]
VMLite Shared Folders Host  Driver
[URL="http://www.carrona.org/drivers/driver.php?id=vmlitedrv.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]vmlitedrv.sys[/COLOR][/B][/URL]
[COLOR=red][B]VBoxNetFlt.sys Wed Aug 11 19:56:12 2010 (4C62E43C)[/B][/COLOR]
VirtualBox network driver
[URL="http://www.carrona.org/drivers/driver.php?id=VBoxNetFlt.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]VBoxNetFlt.sys[/COLOR][/B][/URL]
[COLOR=red][B]VBoxNetAdp.sys Wed Aug 11 19:56:16 2010 (4C62E440)[/B][/COLOR]
[URL="http://www.carrona.org/drivers/driver.php?id=VBoxNetAdp.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]VBoxNetAdp.sys[/COLOR][/B][/URL]
[COLOR=red][B]VBoxDrv.sys  Wed Aug 11 19:56:16 2010 (4C62E440)[/B][/COLOR]
VirtualBox
[URL="http://www.carrona.org/drivers/driver.php?id=VBoxDrv.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]VBoxDrv.sys[/COLOR][/B][/URL]
[COLOR=red][B]vmlitestor.sys  Wed Aug 18 20:54:14 2010 (4C6C2C56)[/B][/COLOR]
[COLOR=#777777][COLOR=#4b0082]vmlitestor.sys[/COLOR] - this driver hasn't been added to the DRT  as of this run. Please search Google/Bing for the driver if additional  information is needed.[/COLOR]
[COLOR=red][B]vmliteusbmon.sys Wed  Aug 18 21:28:54 2010 (4C6C3476)[/B][/COLOR]
[COLOR=#777777][COLOR=#4b0082]vmliteusbmon.sys[/COLOR] - this driver hasn't been added to the DRT  as of this run. Please search Google/Bing for the driver if additional  information is needed.[/COLOR]
[COLOR=red][B]SASKUTIL.SYS Tue Jul 12  22:24:48 2011 (4E1CAD90)[/B][/COLOR]
SUPERAntispyware driver
[URL="http://www.carrona.org/drivers/driver.php?id=SASKUTIL.SYS"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]SASKUTIL.SYS[/COLOR][/B][/URL]
[COLOR=red][B]SASDIFSV.SYS  Fri Jul 22 01:03:16 2011 (4E28B034)[/B][/COLOR]
[URL="http://www.carrona.org/drivers/driver.php?id=SASDIFSV.SYS"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]SASDIFSV.SYS[/COLOR][/B][/URL]
RTKVHDA.sys Tue Jun 19 10:49:44  2012 (4FE03D28)
Realtek HD Audio Codec Driver
[URL="http://www.carrona.org/drivers/driver.php?id=RTKVHDA.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]RTKVHDA.sys[/COLOR][/B][/URL]
ALSysIO.sys Mon Mar 4 18:25:20  2013 (5134D900)
CoreTemp driver
[URL="http://www.carrona.org/drivers/driver.php?id=ALSysIO.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]ALSysIO.sys[/COLOR][/B][/URL]
eudskacs.sys Fri May 10 06:04:01  2013 (518C71B1)
Easus Total Backup
[URL="http://www.carrona.org/drivers/driver.php?id=eudskacs.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]eudskacs.sys[/COLOR][/B][/URL]
eubakup.sys Fri May 10 06:04:05  2013 (518C71B5)
EASEUS Todo Backup; CHENGDU YIWO Tech
[URL="http://www.carrona.org/drivers/driver.php?id=eubakup.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]eubakup.sys[/COLOR][/B][/URL]
EUBKMON.sys Fri May 10 06:04:25  2013 (518C71C9)
EaseUS Todo Backup driver
[URL="http://www.carrona.org/drivers/driver.php?id=EUBKMON.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]EUBKMON.sys[/COLOR][/B][/URL]
EuFdDisk.sys Fri May 10 06:04:27  2013 (518C71CB)
[URL="http://www.carrona.org/drivers/driver.php?id=EuFdDisk.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]EuFdDisk.sys[/COLOR][/B][/URL]
Rt630x86.sys Fri May 10 11:59:39  2013 (518CC50B)
Realtek 8101E/8168/8169 NDIS 6.30 32-bit Driver
[URL="http://www.carrona.org/drivers/driver.php?id=Rt630x86.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]Rt630x86.sys[/COLOR][/B][/URL]
vmci.sys Sat May 18 03:17:35 2013  (5196D6AF)
VMware
[URL="http://www.carrona.org/drivers/driver.php?id=vmci.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]vmci.sys[/COLOR][/B][/URL]
VMNET.SYS Thu Jul 18 21:42:28 2013  (51E84524)
VMware Virtual Network Driver
[URL="http://www.carrona.org/drivers/driver.php?id=VMNET.SYS"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]VMNET.SYS[/COLOR][/B][/URL]
vmnetadapter.sys Thu Jul 18 21:42:37  2013 (51E8452D)
VMware virtual network adapter driver
[URL="http://www.carrona.org/drivers/driver.php?id=vmnetadapter.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]vmnetadapter.sys[/COLOR][/B][/URL]
vmnetbridge.sys Thu Jul 18  21:43:22 2013 (51E8455A)
VMware bridge driver
[URL="http://www.carrona.org/drivers/driver.php?id=vmnetbridge.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]vmnetbridge.sys[/COLOR][/B][/URL]
vsock.sys Thu Aug 1 04:44:46  2013 (51F9CB9E)
VMware vSockets Service
[URL="http://www.carrona.org/drivers/driver.php?id=vsock.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]vsock.sys[/COLOR][/B][/URL]
MpKsl933f4aeb.sys Thu Aug 22  00:32:05 2013 (52153FE5)
[COLOR=#777777][COLOR=#4b0082]MpKsl933f4aeb.sys[/COLOR] - this driver hasn't been added to the  DRT as of this run. Please search Google/Bing for the driver if additional  information is needed.[/COLOR]
intelppm.sys Thu Aug 22 03:58:53 2013  (5215705D)
Intel Processor driver
[URL="http://www.carrona.org/drivers/driver.php?id=intelppm.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]intelppm.sys[/COLOR][/B][/URL]
hiber_ataport.sys Thu Aug 22  06:11:29 2013 (52158F71)
[COLOR=#777777][COLOR=#4b0082]hiber_ataport.sys[/COLOR] - this driver hasn't been added to the  DRT as of this run. Please search Google/Bing for the driver if additional  information is needed.[/COLOR]
point32.sys Thu Dec 12 14:15:26 2013  (52A9B6EE)
Microsoft Intellipoint software
[URL="http://www.carrona.org/drivers/driver.php?id=point32.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]point32.sys[/COLOR][/B][/URL]
hcmon.sys Thu Aug 21 17:07:00 2014  (53F60B14)
VMware USB monitor
[URL="http://www.carrona.org/drivers/driver.php?id=hcmon.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]hcmon.sys[/COLOR][/B][/URL]
nvhda32v.sys Thu Oct 9 19:02:04 2014  (5436BF8C)
nVidia HDMI Audio Device (nForce chipset driver)
[URL="http://www.carrona.org/drivers/driver.php?id=nvhda32v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvhda32v.sys[/COLOR][/B][/URL]
IOMap.sys Thu Oct 23 02:54:22  2014 (544851BE)
ASUS Kernel Mode Driver for NT ?Asus Smart Doctor/iTracker 2  Asus GPU Tweak and GPU Tweak Streaming from this link:  [url]http://www.eightforums.com/bsod-crashes-debugging/47151-bsod-after-sleep-restarts-driver_power_state_failure.html#post388083[/url]  )
[URL="http://www.carrona.org/drivers/driver.php?id=IOMap.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]IOMap.sys[/COLOR][/B][/URL]
UimFIO.SYS Fri Oct 24 00:34:48 2014  (54498288)
Backup driver
[URL="http://www.carrona.org/drivers/driver.php?id=UimFIO.SYS"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]UimFIO.SYS[/COLOR][/B][/URL]
nvvad32v.sys Thu Nov 20 16:33:31  2014 (546E09CB)
NVIDIA GeForce Virtual Audio Driver
[URL="http://www.carrona.org/drivers/driver.php?id=nvvad32v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvvad32v.sys[/COLOR][/B][/URL]
[COLOR=red][B]NvStreamKms.sys Mon Jan 12 18:56:41 2015 (54B40AD9)[/B][/COLOR]
nVidia Streaming Kernel service - may cause [COLOR=red]BSOD[/COLOR] in  Win8.1 systems (found in May 2014). Date/TimeStamp: Tue Apr 29 20:59:44 2014  (53604B00) [B]MAY NOT BE A PROBLEM, this is a tenative posting - Appears that  April 29 driver is a problem, July 2014 drivers seem OK[/B]
[URL="http://www.carrona.org/drivers/driver.php?id=NvStreamKms.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]NvStreamKms.sys[/COLOR][/B][/URL]
VMparport.sys Sat Jan 17  01:08:43 2015 (54B9A80B)
VMware
[URL="http://www.carrona.org/drivers/driver.php?id=VMparport.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]VMparport.sys[/COLOR][/B][/URL]
vmnetuserif.sys Sat Jan 17  01:33:44 2015 (54B9ADE8)
VMware network application interface driver
[URL="http://www.carrona.org/drivers/driver.php?id=vmnetuserif.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]vmnetuserif.sys[/COLOR][/B][/URL]
VMkbd.sys Sat Jan 17 02:09:59  2015 (54B9B667)
VMware keyboard filter driver
[URL="http://www.carrona.org/drivers/driver.php?id=VMkbd.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]VMkbd.sys[/COLOR][/B][/URL]
vmx86.sys Sat Jan 17 03:03:08 2015  (54B9C2DC)
VMware Virtualization Driver
[URL="http://www.carrona.org/drivers/driver.php?id=vmx86.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]vmx86.sys[/COLOR][/B][/URL]
nvlddmkm.sys Fri Mar 13 16:31:35  2015 (550302D7)
nVidia Video drivers
[URL="http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvlddmkm.sys[/COLOR][/B][/URL]
Debug session time: Fri  Mar 27 23:25:51.976 2015 (UTC + 2:00)
Loading Dump File  [D:\SysnativeBSODApps\032715-21843-01.dmp]
Built by:  9600.17668.x86fre.winblue_r8.150127-1500
System Uptime: 0 days 0:32:24.750
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR:  Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+17c73b )
BugCheck 133, {1,  1e00, 0, 0}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]DPC_WATCHDOG_VIOLATION  (133)[/URL]
Bugcheck code 00000133
Arguments:
Arg1: 00000001, The  system cumulatively spent an extended period of time at
DISPATCH_LEVEL or  above. The offending component can usually be
identified with a stack trace.
Arg2: 00001e00, The watchdog period.
Arg3: 00000000
Arg4: 00000000
BUGCHECK_STR: 0x133
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
FAILURE_BUCKET_ID: 0x133_ISR_nvlddmkm+17c73b
MaxSpeed: 3000
CurrentSpeed: 3003
BiosVersion = V1.10
BiosReleaseDate = 11/11/2008
SystemManufacturer = MICRO-STAR  INTERNATIONAL CO.,LTD
SystemProductName = MS-7360
--- E O J --- 2015 Apr 01 23:06:39 PM _88-dbug Copyright  2012 Sysnative Forums
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
banger
Many thanks the Video card has been replaced and I will update drivers as instructed.
    MSI MS7360
    MS 7360 P35 V1.0
    4 GB
    MSI Geforce GT610
    Realtek Onboard
    Dell 19" Widescreen
    Corsair 500W
    Generic
    Logitech G19
    MS Comfort 4500
    19 mbps
    MS Defender
