BSOD when connecting to wifi and using ethernet cable
hodan
5
Hi, i have been experiencing BSODs for 3 days not. At first it started when I connected to WiFi, so i switched to ethernet cable. Now it crashes when i am using the ethernet cable as well. I tried searching for solutions but i don't understand much about computers. I have the minidump file but i don't know how to show them here. I tried using driver verifier and now it crashes every 20 minutes without even connecting to the internet. I cant put my computer into safe mode, it reboots even if i press shift +f8 and i cant create recovery disk. Can anyone please help me solve this.
    64bit
usasma
Mr. Cranky Pants
5,139
At one point during the repeated boots you should get a prompt to try startup/automatic repair.
You can also try forcing a restart when the little spinning dial is at the bottom of boot screen (by holding down the power button)
Select that, and then you can select Safe Mode to boot into.
Try each one of the options here: http://www.eightforums.com/tutorials/2757-safe-mode-start-windows-8-a.html
If you still can't get into Safe Mode, you can always boot using your recovery media in order to access Startup Repair.
The very first thing to do in Safe Mode is to disable Driver Verifier
To do this, open up verifier.exe and select "Delete existing settings". Then click on Finish and reboot to let the changes take effect.
To upload the minidump file, zip it up and then upload it using the Attachments tool below the reply box.
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
