BSOD very frequent... please help!!!
dleon
4
Hi All:
This problem is really frustrating,
I executed the updates, check the disk and drivers and it seems to be everything OK.
Is if possible somebody check my files, I executed the SF Diagnostic Tools, and I have the results in the .zip I will try to attach.
Best Regards and thank you in advance.
usasma
Mr. Cranky Pants
5,139
These 2 devices have problems in Device Manager:
USB-IF xHCI USB Host Controller ROOT\UOIP_BUS_DRIVER\0000 Este dispositivo no funciona correctamente porque Windows no puede cargar los controladores requeridos para este dispositivo.
Intel(R) Centrino(R) Wireless-N 2230 PCI\VEN_8086&DEV_0887&SUBSYS_40628086&REV_C4\4&1AA134EC&0&00E1 Este dispositivo está deshabilitado.
For the first device, please locate it in Device Manager, right click on it, and select "Uninstall". Reboot the computer and check to see if it returns with an error.
For the second device, is it deliberately disabled? If so, why?
Out of 23 memory dumps there were 10 different BSOD error codes. The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking/overheating - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
You can get a head start on the hardware diagnostics if you'd like - they are located here: Hardware Diagnostics
WPRO_41_2001.sys Mon Nov 7 16:04:48 2011 (4EB847F0)
CACE Technologies WinPcap Packet Driver
http://www.carrona.org/drivers/driver.php?id=WPRO_41_2001.sys
CLVirtualDrive.sys Mon Dec 26 08:26:47 2011 (4EF87617)
CyberLink Virtual Device Driver
http://www.carrona.org/drivers/driver.php?id=CLVirtualDrive.sys
If all of this doesn't stop the BSOD's, please run these free hardware diagnostics: Hardware Diagnostics. Let us know the results and we can move on from there.
Analysis:
[font=lucida console]**************************Tue Aug 27 09:47:56.200 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082713-20843-01.dmp]
Built by: [B]9200[/B].16628.amd64fre.win8_gdr.130531-1504
System Uptime:[B]0 days 21:00:19.321[/B]
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+346c6 )[/B]
BugCheck [B]1A, {41287, 14f389890, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001A]MEMORY_MANAGEMENT (1a)[/url]
Arguments:
Arg1: 0000000000041287, An illegal page fault occurred while holding working set synchronization.
    Parameter 2 contains the referenced virtual address.
Arg2: 000000014f389890
Arg3: 0000000000000000
Arg4: 0000000000000000
BUGCHECK_STR:  0x1a_41287
PROCESS_NAME:  googledrivesyn
FAILURE_BUCKET_ID: [B]0x1a_41287_nt!_??_::FNODOBFM::_string_[/B]
CPUID:        "Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz"
MaxSpeed:     2500
CurrentSpeed: [B]2494[/B]
  BIOS Version                  F.25
  BIOS Release Date             01/21/2013
  Manufacturer                  Hewlett-Packard
  Product Name                  HP ENVY m6 Notebook PC
**************************Mon Aug 26 12:45:16.077 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082613-16046-01.dmp]
System Uptime:[B]0 days 0:21:27.849[/B]
BugCheck [B]1A, {41287, 68, 0, 0}[/B]
Arguments:
Arg2: 0000000000000068
PROCESS_NAME:  System
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Mon Aug 26 12:12:36.685 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082613-63203-01.dmp]
System Uptime:[B]2 days 21:14:39.303[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+1dfef )[/B]
BugCheck [B]1A, {5005, fffff70001080000, 32f, 198}[/B]
Arguments:
Arg1: 0000000000005005, The subtype of the bugcheck.
Arg2: fffff70001080000
Arg3: 000000000000032f
Arg4: 0000000000000198
BUGCHECK_STR:  0x1a_5005
PROCESS_NAME:  YCMMirage.exe
FAILURE_BUCKET_ID: [B]0x1a_5005_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug 23 14:57:04.818 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082313-22640-01.dmp]
System Uptime:[B]0 days 1:59:01.582[/B]
*** ERROR: Module load completed but symbols could not be loaded for luafv.sys
Probably caused by :[B]luafv.sys ( luafv+1606b )[/B]
BugCheck [B]1E, {ffffffff80000003, fffff8800121b3b2, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001E]KMODE_EXCEPTION_NOT_HANDLED (1e)[/url]
Arguments:
Arg1: ffffffff80000003, The exception code that was not handled
Arg2: fffff8800121b3b2, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 0000000000000000, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_80000003
FAILURE_BUCKET_ID: [B]0x1E_80000003_luafv+1606b[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug 23 12:56:17.311 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082313-17812-01.dmp]
System Uptime:[B]0 days 21:07:22.516[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiTimerWaitTest+2f6 )[/B]
BugCheck [B]A, {80000002, 2, 0, fffff803b7af3276}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: 0000000080000002, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff803b7af3276, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nt!KiTimerWaitTest[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Thu Aug 22 15:34:27.020 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082213-33234-01.dmp]
System Uptime:[B]0 days 5:40:55.788[/B]
Probably caused by :[B]luafv.sys ( luafv+11199 )[/B]
BugCheck [B]3B, {c0000005, fffff802e84dc44a, fffff88029bee590, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff802e84dc44a, Address of the instruction which caused the bugcheck
Arg3: fffff88029bee590, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  iexplore.exe
FAILURE_BUCKET_ID: [B]0x3B_luafv+11199[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Tue Aug 20 11:52:11.702 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082013-19828-01.dmp]
Built by: [B]9200[/B].16581.amd64fre.win8_gdr.130410-1505
System Uptime:[B]0 days 1:20:10.474[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+27177 )[/B]
BugCheck [B]1A, {5003, fffff78280000000, 1074b, 10b2f000a0e96}[/B]
Arguments:
Arg1: 0000000000005003, The subtype of the bugcheck.
Arg2: fffff78280000000
Arg3: 000000000001074b
Arg4: 00010b2f000a0e96
BUGCHECK_STR:  0x1a_5003
FAILURE_BUCKET_ID: [B]0x1a_5003_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Tue Aug 20 10:30:06.666 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\082013-16578-01.dmp]
System Uptime:[B]0 days 23:03:42.253[/B]
Probably caused by :[B]hardware ( USBPORT+18716 )[/B]
BugCheck [B]D1, {5, 2, 1, fffff88005679716}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: 0000000000000005, memory referenced
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff88005679716, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]IP_MISALIGNED[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Mon Aug 19 11:25:20.719 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\081913-20250-01.dmp]
System Uptime:[B]0 days 0:06:59.492[/B]
*** WARNING: Unable to verify timestamp for SRTSP64.SYS
*** ERROR: Module load completed but symbols could not be loaded for SRTSP64.SYS
Probably caused by :[B]hardware ( SRTSP64+7db6a )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff8802d757b6a, 1, 483e75f6}[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8802d757b6a, The address that the exception occurred at
Arg3: 0000000000000001, Parameter 0 of the exception
Arg4: 00000000483e75f6, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_W
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]IP_MISALIGNED_SRTSP64.SYS[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Mon Aug 19 11:15:28.976 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\081913-43578-01.dmp]
System Uptime:[B]5 days 1:02:09.992[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDeferredReadyThread+282 )[/B]
BugCheck [B]A, {ffffffffc603001a, 2, 1, fffff800be498072}[/B]
Arguments:
Arg1: ffffffffc603001a, memory referenced
Arg3: 0000000000000001, bitfield :
Arg4: fffff800be498072, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nt!KiDeferredReadyThread[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Wed Aug 14 10:06:06.774 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\081413-29031-01.dmp]
System Uptime:[B]4 days 23:13:57.864[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2c899 )[/B]
BugCheck [B]1A, {8886, fffffa8000922c80, fffffa8003b46780, 500}[/B]
Arguments:
Arg1: 0000000000008886, The subtype of the bugcheck.
Arg2: fffffa8000922c80
Arg3: fffffa8003b46780
Arg4: 0000000000000500
BUGCHECK_STR:  0x1a_8886
FAILURE_BUCKET_ID: [B]0x1a_8886_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  9 10:39:46.061 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080913-20593-01.dmp]
System Uptime:[B]0 days 1:18:11.833[/B]
Probably caused by :[B]memory_corruption ( nt!MiComputeStartingOffset+12 )[/B]
BugCheck [B]A, {fffffffffffffff8, 0, 0, fffff802eb6d1752}[/B]
Arguments:
Arg1: fffffffffffffff8, memory referenced
Arg2: 0000000000000000, IRQL
Arg4: fffff802eb6d1752, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nt!MiComputeStartingOffset[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  9 09:18:49.097 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080913-26671-01.dmp]
System Uptime:[B]0 days 15:24:05.866[/B]
Probably caused by :[B]memory_corruption ( nt!MiBadShareCount+4b )[/B]
BugCheck [B]4E, {99, 165f52, 2, 600019000193b6c}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000004E]PFN_LIST_CORRUPT (4e)[/url]
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 0000000000165f52, page frame number
Arg3: 0000000000000002, current page state
Arg4: 0600019000193b6c, 0
BUGCHECK_STR:  0x4E_99
FAILURE_BUCKET_ID: [B]0x4E_99_nt!MiBadShareCount[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Thu Aug  8 17:53:54.719 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080813-16296-01.dmp]
System Uptime:[B]0 days 0:12:46.492[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiPageFault+260 )[/B]
BugCheck [B]D1, {404, 2, 8, 404}[/B]
Arguments:
Arg1: 0000000000000404, memory referenced
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: 0000000000000404, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_CODE_AV_BAD_IP_nt!KiPageFault[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Thu Aug  8 17:37:54.575 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080813-17171-01.dmp]
System Uptime:[B]0 days 0:13:56.349[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+332ce )[/B]
BugCheck [B]BE, {fffff8a006f498b8, 800000016b759101, fffff8802c9c1140, a}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000BE]ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)[/url]
Arguments:
Arg1: fffff8a006f498b8, Virtual address for the attempted write.
Arg2: 800000016b759101, PTE contents.
Arg3: fffff8802c9c1140, (reserved)
Arg4: 000000000000000a, (reserved)
BUGCHECK_STR:  0xBE
FAILURE_BUCKET_ID: [B]0xBE_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Thu Aug  8 17:22:31.589 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080813-21187-01.dmp]
System Uptime:[B]0 days 0:18:48.362[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidMmInterface+141c5 )[/B]
BugCheck [B]50, {fffff1000db9efa0, 0, fffff88003e27045, 2}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff1000db9efa0, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff88003e27045, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_dxgmms1!VidMmInterface[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Thu Aug  8 16:54:43.561 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080813-26062-01.dmp]
System Uptime:[B]3 days 1:50:57.878[/B]
BugCheck [B]1A, {8886, fffffa800670bc00, fffffa800834a7d0, 500}[/B]
Arguments:
Arg2: fffffa800670bc00
Arg3: fffffa800834a7d0
PROCESS_NAME:  rundll32.exe
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  2 12:20:17.139 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080213-44906-01.dmp]
System Uptime:[B]0 days 1:07:33.911[/B]
*** ERROR: Module load completed but symbols could not be loaded for mouhid.sys
Probably caused by :[B]mouhid.sys ( mouhid+2cb3 )[/B]
BugCheck [B]A, {0, 2, 1, fffff80244720711}[/B]
Arguments:
Arg1: 0000000000000000, memory referenced
Arg4: fffff80244720711, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_mouhid+2cb3[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  2 11:11:00.952 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080213-17234-01.dmp]
System Uptime:[B]0 days 0:27:38.724[/B]
Probably caused by :[B]memory_corruption ( nt!MiUnlinkPageFromLockedList+19a )[/B]
BugCheck [B]A, {fffffa801c19c26b, 2, 0, fffff8037b49b68a}[/B]
Arguments:
Arg1: fffffa801c19c26b, memory referenced
Arg4: fffff8037b49b68a, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nt!MiUnlinkPageFromLockedList[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  2 10:43:00.663 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080213-17312-01.dmp]
System Uptime:[B]0 days 0:05:18.436[/B]
*** WARNING: Unable to verify timestamp for cdd.dll
*** ERROR: Module load completed but symbols could not be loaded for cdd.dll
Probably caused by :[B]dxgkrnl.sys ( dxgkrnl!g_TdrForceTimeout+3b715 )[/B]
BugCheck [B]FC, {fffff880035b0c14, 800000003a3bb963, fffff88006dc0830, 2}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000FC]ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY (fc)[/url]
Arguments:
Arg1: fffff880035b0c14, Virtual address for the attempted execute.
Arg2: 800000003a3bb963, PTE contents.
Arg3: fffff88006dc0830, (reserved)
BUGCHECK_STR:  0xFC
PROCESS_NAME:  csrss.exe
FAILURE_BUCKET_ID: [B]0xFC_dxgkrnl!g_TdrForceTimeout[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  2 10:37:20.761 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080213-15921-01.dmp]
System Uptime:[B]0 days 0:15:24.533[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+26a56 )[/B]
BugCheck [B]1A, {888a, fffff8a006e65850, fffff68000019399, fffffa80041b39e0}[/B]
Arguments:
Arg1: 000000000000888a, Internal memory management structures (likely the PTE or PFN) are corrupt.
Arg2: fffff8a006e65850
Arg3: fffff68000019399
Arg4: fffffa80041b39e0
BUGCHECK_STR:  0x1a_888a
FAILURE_BUCKET_ID: [B]0x1a_888a_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  2 10:21:33.736 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080213-16906-01.dmp]
System Uptime:[B]0 days 0:40:36.507[/B]
Probably caused by :[B]USBPORT.SYS ( USBPORT+1a192 )[/B]
BugCheck [B]3D, {fffff880009c1fc0, 0, 0, fffff8022a72eda4}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003D]INTERRUPT_EXCEPTION_NOT_HANDLED (3d)[/url]
Arguments:
Arg1: fffff880009c1fc0
Arg4: fffff8022a72eda4
BUGCHECK_STR:  0x3D
FAILURE_BUCKET_ID: [B]0x3D_USBPORT+1a192[/B]
MaxSpeed:     2500
  BIOS Version                  F.25
**************************Fri Aug  2 09:40:33.491 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080213-18609-01.dmp]
System Uptime:[B]0 days 15:18:11.704[/B]
BugCheck [B]D1, {fffff80356f25766, d, 8, fffff80356f25766}[/B]
Arguments:
Arg1: fffff80356f25766, memory referenced
Arg2: 000000000000000d, IRQL
Arg4: fffff80356f25766, address which referenced memory
BUGCHECK_STR:  AV
MaxSpeed:     2500
  BIOS Version                  F.25
[/font]
3rd Party Drivers:
[COLOR=RED][B]CLVirtualDrive.sys           Mon Dec 26 08:26:47 2011 (4EF87617)[/B][/COLOR]
btmaux.sys                   Tue Apr 24 02:34:35 2012 (4F96497B)
PxHlpa64.sys                 Tue Apr 24 13:26:29 2012 (4F96E245)
ISCTD64.sys                  Fri May  4 20:44:01 2012 (4FA477D1)
ikbevent.sys                 Tue Jun 12 15:22:18 2012 (4FD796EA)
imsevent.sys                 Wed Jun 13 21:35:28 2012 (4FD93FE0)
IntcDAud.sys                 Tue Jun 19 10:40:51 2012 (4FE08F73)
iBtFltCoex.sys               Tue Jul  3 18:22:55 2012 (4FF370BF)
amdkmpfd.sys                 Mon Jul  9 21:49:35 2012 (4FFB8A2F)
btmhsf.sys                   Sat Jul 14 09:31:32 2012 (500174B4)
AMPPAL.sys                   Tue Jul 17 03:35:22 2012 (500515BA)
igdpmd64.sys                 Fri Jul 20 17:47:55 2012 (5009D20B)
stwrt64.sys                  Sat Jul 21 09:36:42 2012 (500AB06A)
iwdbus.sys                   Mon Jul 23 16:19:17 2012 (500DB1C5)
WirelessButtonDriver64.sys   Fri Jul 27 16:22:12 2012 (5012F874)
RtsBaStor.sys                Mon Jul 30 02:08:03 2012 (501624C3)
Rt630x64.sys                 Mon Jul 30 12:03:12 2012 (5016B040)
iaStorA.sys                  Tue Jul 31 14:21:21 2012 (50182221)
dump_iaStorA.sys             Tue Jul 31 14:21:21 2012 (50182221)
atikmdag.sys                 Wed Aug  1 23:34:54 2012 (5019F55E)
atikmpag.sys                 Thu Aug  2 00:09:28 2012 (5019FD78)
SynTP.sys                    Fri Aug 24 19:20:26 2012 (50380C3A)
Smb_driver_Intel.sys         Fri Aug 24 19:22:13 2012 (50380CA5)
hpdskflt.sys                 Mon Sep 24 11:31:14 2012 (50607CC2)
Accelerometer.sys            Mon Sep 24 11:31:45 2012 (50607CE1)
intelppm.sys                 Mon Nov  5 22:55:02 2012 (50988A16)
HECIx64.sys                  Mon Dec 17 14:32:21 2012 (50CF7345)
[COLOR=RED][B]WPRO_41_2001.sys             Mon Nov  7 16:04:48 2011 (4EB847F0)[/B][/COLOR]
Ironx64.SYS                  Mon Jul 23 20:34:50 2012 (500DEDAA)
EraserUtilRebootDrv.sys      Tue Jul 31 19:36:50 2012 (50186C12)
eeCtrl64.sys                 Tue Jul 31 19:36:51 2012 (50186C13)
SYMEVENT64x86.SYS            Wed Aug 22 01:33:18 2012 (50346F1E)
SYMEFA64.SYS                 Fri Jan 18 19:31:37 2013 (50F9E969)
SRTSPX64.SYS                 Fri Jan 25 16:30:05 2013 (5102F95D)
ccSetx64.sys                 Thu Mar 21 23:02:33 2013 (514BC9C9)
SYMNETS.SYS                  Tue Apr  9 19:24:13 2013 (5164A31D)
SYMDS64.SYS                  Thu Apr 25 19:19:47 2013 (5179BA13)
BHDrvx64.sys                 Mon May 20 16:47:31 2013 (519A8BE3)
IDSvia64.sys                 Thu Jul 25 20:11:40 2013 (51F1BEBC)
SRTSP64.SYS                  Mon Apr 22 18:26:52 2013 (5175B92C)
EX64.SYS                     Fri Apr 26 02:08:58 2013 (517A19FA)
ENG64.SYS                    Fri Apr 26 02:10:48 2013 (517A1A68)
eeCtrl64.sys                 Sun Jul 21 19:13:40 2013 (51EC6B24)
EraserUtilRebootDrv.sys      Sun Jul 21 19:13:41 2013 (51EC6B25)
EraserUtilDrv11310.sys       Sun Jul 21 19:13:41 2013 (51EC6B25)
IDSvia64.sys                 Tue Aug 28 22:48:40 2012 (503D8308)
HECIx64.sys                  Mon Jul  2 18:14:58 2012 (4FF21D62)
[/font]
http://www.carrona.org/drivers/driver.php?id=btmaux.sys
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
http://www.carrona.org/drivers/driver.php?id=ISCTD64.sys
http://www.carrona.org/drivers/driver.php?id=ikbevent.sys
http://www.carrona.org/drivers/driver.php?id=imsevent.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=iBtFltCoex.sys
http://www.carrona.org/drivers/driver.php?id=amdkmpfd.sys
http://www.carrona.org/drivers/driver.php?id=btmhsf.sys
http://www.carrona.org/drivers/driver.php?id=AMPPAL.sys
http://www.carrona.org/drivers/driver.php?id=igdpmd64.sys
http://www.carrona.org/drivers/driver.php?id=stwrt64.sys
http://www.carrona.org/drivers/driver.php?id=iwdbus.sys
http://www.carrona.org/drivers/driver.php?id=WirelessButtonDriver64.sys
http://www.carrona.org/drivers/driver.php?id=RtsBaStor.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys
http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys
http://www.carrona.org/drivers/driver.php?id=Ironx64.SYS
http://www.carrona.org/drivers/driver.php?id=EraserUtilRebootDrv.sys
http://www.carrona.org/drivers/driver.php?id=eeCtrl64.sys
http://www.carrona.org/drivers/driver.php?id=SYMEVENT64x86.SYS
http://www.carrona.org/drivers/driver.php?id=SYMEFA64.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSPX64.SYS
http://www.carrona.org/drivers/driver.php?id=ccSetx64.sys
http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS
http://www.carrona.org/drivers/driver.php?id=SYMDS64.SYS
http://www.carrona.org/drivers/driver.php?id=BHDrvx64.sys
http://www.carrona.org/drivers/driver.php?id=IDSvia64.sys
http://www.carrona.org/drivers/driver.php?id=SRTSP64.SYS
http://www.carrona.org/drivers/driver.php?id=EX64.SYS
http://www.carrona.org/drivers/driver.php?id=ENG64.SYS
EraserUtilDrv11310.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
dleon
4
Thank you very much for your help!!
Until now the machine is working fine. Instead of unistall the driver I downloaded an updated version and installed it.
I enabled the wireless driver. There's no reason to be disabled.
I will let you know if I have some news.
Best Regards, and thanks again.
dleon
4
Please, help me again
We have been several months with the same problems and tried different things to solve it, but still doesn't work.
I executed again SF Diagnostics tool and I attach a new .zip with the last errors.
I will be very grateful if you can help me again.
