BSOD using x264.exe after ~5-45 minutes 0x00000139
FMA1394
8
KERNEL_SECURITY_CHECK_FAILURE is the error it gives. Running Windows 8 (not 8.1. no, I'm not upgrading until they come out with that update in August to bring back the start menu =p)
Basically, when encoding video with x264.exe, this happens after 5-45 minutes. I've tried different ram, I've reset my processor clock speeds to stock--same error. What is going on? This only happens with this program and not other encoding programs like xvid, etc. Attached is the file as requested.
I'm suspecting a bad OS install, bad power supply, or a faulty processor.
Help.
    ASUS
    i7-3770K
    P8Z77-V DELUXE
    4x4GB 2133MHz Avexir Core
    Radeon R9 290
    Onboard
    HP ZR22w x3
    1920x1080 x3
    Too many
    Corsair AX1200
    Rosewill Thor v2
    H2O
    Corsair Vengeance K60
    Corsair Vengeance M60
    Mozilla Firefox
FMA1394
8
So I got this in my email inbox today... I'm pretty sure it's not AMD graphics drivers. Guess he deleted his post.
Anyone else got ideas?
    ASUS
    i7-3770K
    P8Z77-V DELUXE
    Radeon R9 290
    Onboard
    HP ZR22w x3
    1920x1080 x3
    Too many
    Corsair AX1200
    Rosewill Thor v2
    H2O
    Mozilla Firefox
usasma
Mr. Cranky Pants
5,139
Only 130 Windows Updates installed. Most systems have 160 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
C: and H: drives only have about 4% free space. Windows likes 15% free space in order to perform stuff "behind the scenes" without adversely affecting the system's performance. Please free up 15% on ALL hard drives (you can get away with 10% on larger drives and won't notice a large performance penalty)
You have 2 or 3 hard drives (plus a couple of USB's). What is the make/model/wattage and age of your Power Supply?
These devices have problems in Device Manager:
Not Available USB\VID_03F0&PID_0401\SG955172MFHT The drivers for this device are not installed.
Not Available USB\VID_0000&PID_0002\6&38A36D0C&0&1 43
High Definition Audio Bus PCI\VEN_1002&DEV_AA80&SUBSYS_AA801002&REV_00\6&B283911&0&01400009 This device is disabled.
The first items is a HP ScanJet; the second is likely to be your USB 3.0 controller (but that's uncertain as the VID and PID characters aren't correct). The last one is disabled. Is this deliberate? If so, why?
Lot's of Live Kernel Events in the WER section of MSINFO32. PLease:
Please do the following:
- open Event Viewer (run eventvwr.msc from the "Run" dialog))
- expand the Custom Views category (left click on the > next to the words "Custom Views")
- right click on Administrative Events
- select "Save all Events in Custom View as..."
- save the file as Admin.evtx
- zip up the file (right click on it, select "Send to", select "Compressed (zipped) folder")
- upload it with your next post (if it's too big, then upload it to a free file-hosting service and post a link here).
While waiting for a reply, please monitor your temps with this free utility: HWMonitor CPUID - System & hardware benchmark, monitoring, reporting
MSI Afterburner (along with Riva Tuner and EVGA Precision) are known to cause BSOD's in some Windows systems (it's driver is usually RTCore64.sys). Please un-install them immediately!
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
ASUSFILTER.sys Tue Sep 20 11:46:33 2011 (4E78B559)
ASUS USB Hub filter driver
http://www.carrona.org/drivers/driver.php?id=ASUSFILTER.sys
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[font=lucida console]**************************Wed Apr 30 22:19:00.523 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\043014-10937-01.dmp]
Built by: [B]9200[/B].16628.amd64fre.win8_gdr.130531-1504
System Uptime:[B]0 days 0:11:06.165[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiFastFailDispatch+d0 )[/B]
BugCheck [B]139, {3, fffff8802a58e7b0, fffff8802a58e708, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000139]KERNEL_SECURITY_CHECK_FAILURE (139)[/url]
Arguments:
Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
Arg2: fffff8802a58e7b0, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff8802a58e708, Address of the exception record for the exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
BUGCHECK_STR:  0x139
DEFAULT_BUCKET_ID:  LIST_ENTRY_CORRUPT
PROCESS_NAME:  avs4x264mod.ex
FAILURE_BUCKET_ID: [B]0x139_3_nt!KiFastFailDispatch[/B]
CPUID:        "Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz"
MaxSpeed:     3500
CurrentSpeed: [B]3500[/B]
  BIOS Version                  1805
  BIOS Release Date             12/19/2012
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
**************************Sun Apr 27 16:53:45.915 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\042714-10734-01.dmp]
System Uptime:[B]0 days 0:01:14.557[/B]
BugCheck [B]139, {3, fffff88029fbd800, fffff88029fbd758, 0}[/B]
Arguments:
Arg2: fffff88029fbd800, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff88029fbd758, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
PROCESS_NAME:  HDD Regenerato
MaxSpeed:     3500
  BIOS Version                  1805
**************************Sun Apr 27 16:51:18.842 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\042714-10468-01.dmp]
System Uptime:[B]0 days 1:01:32.485[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+145a4 )[/B]
BugCheck [B]133, {0, 501, 500, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000133]DPC_WATCHDOG_VIOLATION (133)[/url]
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
    component can usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in ticks).
BUGCHECK_STR:  0x133
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x133_DPC_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     3500
  BIOS Version                  1805
**************************Sun Apr 27 13:54:54.381 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\042714-10187-01.dmp]
Windows 8 Kernel Version 9200 MP (8 procs) Free x64
System Uptime:[B]0 days 0:51:21.021[/B]
BugCheck [B]139, {3, fffff8802a4fe800, fffff8802a4fe758, 0}[/B]
Arguments:
Arg2: fffff8802a4fe800, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff8802a4fe758, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
MaxSpeed:     3500
  BIOS Version                  1805
**************************Sat Apr 26 22:23:00.034 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\042614-10437-01.dmp]
System Uptime:[B]0 days 1:01:08.674[/B]
BugCheck [B]139, {3, fffff88027614040, fffff88027613f98, 0}[/B]
Arguments:
Arg2: fffff88027614040, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff88027613f98, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
PROCESS_NAME:  vmware-remotem
MaxSpeed:     3500
  BIOS Version                  1805
**************************Sat Apr 26 21:20:19.417 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\042614-12156-01.dmp]
System Uptime:[B]0 days 0:16:36.057[/B]
BugCheck [B]139, {3, fffff880282f67b0, fffff880282f6708, 0}[/B]
Arguments:
Arg2: fffff880282f67b0, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff880282f6708, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
MaxSpeed:     3500
  BIOS Version                  1805
**************************Wed Apr 16 02:00:01.411 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\041614-10734-01.dmp]
System Uptime:[B]0 days 10:53:20.051[/B]
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
*** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys
Probably caused by :[B]dxgkrnl.sys ( dxgkrnl+6a82d )[/B]
BugCheck [B]139, {3, fffff880039a36a0, fffff880039a35f8, 0}[/B]
Arguments:
Arg2: fffff880039a36a0, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff880039a35f8, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
PROCESS_NAME:  dwm.exe
FAILURE_BUCKET_ID: [B]0x139_3_dxgkrnl+6a82d[/B]
MaxSpeed:     3500
  BIOS Version                  1805
**************************Sat Apr 12 00:33:10.843 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\041214-10343-01.dmp]
System Uptime:[B]0 days 0:06:00.483[/B]
BugCheck [B]139, {3, fffff8802af5d7b0, fffff8802af5d708, 0}[/B]
Arguments:
Arg2: fffff8802af5d7b0, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff8802af5d708, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
PROCESS_NAME:  Steam.exe
MaxSpeed:     3500
  BIOS Version                  1805
**************************Sat Apr 12 00:25:53.064 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\041214-10359-01.dmp]
System Uptime:[B]0 days 1:56:26.704[/B]
*** ERROR: Module load completed but symbols could not be loaded for kbdhid.sys
Probably caused by :[B]kbdhid.sys ( kbdhid+2944 )[/B]
BugCheck [B]139, {3, fffff80025262150, fffff800252620a8, 0}[/B]
Arguments:
Arg2: fffff80025262150, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff800252620a8, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
FAILURE_BUCKET_ID: [B]0x139_3_kbdhid+2944[/B]
MaxSpeed:     3500
  BIOS Version                  1805
**************************Thu Apr 10 20:37:03.568 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\041014-12359-01.dmp]
System Uptime:[B]8 days 4:06:51.297[/B]
*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
BugCheck [B]101, {18, 0, fffff88002d4b180, 4}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000101]CLOCK_WATCHDOG_TIMEOUT (101)[/url]
Arguments:
Arg1: 0000000000000018, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: fffff88002d4b180, The PRCB address of the hung processor.
Arg4: 0000000000000004, 0.
BUGCHECK_STR:  CLOCK_WATCHDOG_TIMEOUT_8_PROC
FAILURE_BUCKET_ID: [B]CLOCK_WATCHDOG_TIMEOUT_8_PROC_ANALYSIS_INCONCLUSIVE[/B]
[/font]
3rd Party Drivers:
[COLOR=RED][B]ASUSFILTER.sys              Tue Sep 20 11:46:33 2011 (4E78B559)[/B][/COLOR]
e1i63x64.sys                Wed Feb 29 22:25:14 2012 (4F4EEC1A)
bcmwl63a.sys                Tue Mar 13 20:31:05 2012 (4F5FE6C9)
megasas.sys                 Tue Apr  3 15:45:15 2012 (4F7B534B)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
AsIO.sys                    Wed Aug 22 05:54:47 2012 (5034AC67)
dump_storahci.sys           Fri Mar  1 21:15:44 2013 (513160D0)
ElbyCDIO.sys                Mon Mar  4 04:21:51 2013 (513467AF)
au630x64.sys                Thu Mar 14 05:44:07 2013 (51419BE7)
ASUSwh.sys                  Thu Mar 28 13:44:34 2013 (51548182)
ASUScr.sys                  Thu Mar 28 13:44:37 2013 (51548185)
ASUSumsc.sys                Thu Mar 28 13:44:44 2013 (5154818C)
ASUSstpt.sys                Thu Mar 28 13:44:49 2013 (51548191)
hcw85cir3.sys               Mon Apr  8 11:07:53 2013 (5162DD49)
HCW85BDA.sys                Mon Apr  8 11:08:00 2013 (5162DD50)
vmci.sys                    Fri May 17 21:19:18 2013 (5196D716)
asmtxhci.sys                Mon Jun 24 13:16:27 2013 (51C87EEB)
asmthub3.sys                Mon Jun 24 13:16:39 2013 (51C87EF7)
VMNET.SYS                   Thu Jul 18 15:42:50 2013 (51E8453A)
vmnetadapter.sys            Thu Jul 18 15:43:00 2013 (51E84544)
vmnetbridge.sys             Thu Jul 18 15:43:47 2013 (51E84573)
VClone.sys                  Wed Jul 24 11:02:55 2013 (51EFEC9F)
vsock.sys                   Wed Jul 31 22:46:10 2013 (51F9CBF2)
AtihdW86.sys                Tue Sep 24 20:24:18 2013 (52422D32)
AMDACPKSL.SYS               Tue Sep 24 20:24:41 2013 (52422D49)
hcmon.sys                   Wed Oct  9 11:03:51 2013 (52557057)
cpuz136_x64.sys             Tue Oct 22 08:52:21 2013 (52667505)
AnyDVD.sys                  Tue Nov 26 09:46:13 2013 (5294B435)
atikmpag.sys                Fri Dec  6 15:21:45 2013 (52A231D9)
atikmdag.sys                Fri Dec  6 16:19:43 2013 (52A23F6F)
vmnetuserif.sys             Mon Apr 14 18:07:57 2014 (534C5C3D)
VMkbd.sys                   Mon Apr 14 18:42:54 2014 (534C646E)
vmx86.sys                   Mon Apr 14 19:31:39 2014 (534C6FDB)
[COLOR=RED][B]RTCore64.sys                Tue Sep  6 08:24:50 2011 (4E661112)[/B][/COLOR]
vmnetuserif.sys             Fri Oct 18 14:19:38 2013 (52617BBA)
VMkbd.sys                   Fri Oct 18 14:50:26 2013 (526182F2)
vmx86.sys                   Fri Oct 18 15:34:39 2013 (52618D4F)
bcbtums.sys                 Thu Oct 17 16:45:30 2013 (52604C6A)
[/font]
http://www.carrona.org/drivers/driver.php?id=e1i63x64.sys
http://www.carrona.org/drivers/driver.php?id=bcmwl63a.sys
http://www.carrona.org/drivers/driver.php?id=megasas.sys
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
http://www.carrona.org/drivers/driver.php?id=ElbyCDIO.sys
au630x64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=ASUSwh.sys
http://www.carrona.org/drivers/driver.php?id=ASUScr.sys
http://www.carrona.org/drivers/driver.php?id=ASUSumsc.sys
http://www.carrona.org/drivers/driver.php?id=ASUSstpt.sys
http://www.carrona.org/drivers/driver.php?id=hcw85cir3.sys
http://www.carrona.org/drivers/driver.php?id=HCW85BDA.sys
http://www.carrona.org/drivers/driver.php?id=vmci.sys
http://www.carrona.org/drivers/driver.php?id=asmtxhci.sys
http://www.carrona.org/drivers/driver.php?id=asmthub3.sys
http://www.carrona.org/drivers/driver.php?id=VMNET.SYS
http://www.carrona.org/drivers/driver.php?id=vmnetadapter.sys
http://www.carrona.org/drivers/driver.php?id=vmnetbridge.sys
http://www.carrona.org/drivers/driver.php?id=VClone.sys
http://www.carrona.org/drivers/driver.php?id=vsock.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW86.sys
http://www.carrona.org/drivers/driver.php?id=AMDACPKSL.SYS
http://www.carrona.org/drivers/driver.php?id=hcmon.sys
http://www.carrona.org/drivers/driver.php?id=cpuz136_x64.sys
http://www.carrona.org/drivers/driver.php?id=AnyDVD.sys
http://www.carrona.org/drivers/driver.php?id=vmnetuserif.sys
http://www.carrona.org/drivers/driver.php?id=VMkbd.sys
http://www.carrona.org/drivers/driver.php?id=vmx86.sys
http://www.carrona.org/drivers/driver.php?id=RTCore64.sys
http://www.carrona.org/drivers/driver.php?id=bcbtums.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
FMA1394
8
Thanks for the reply. I will give these things a try. I have indeed confirmed that this is something wrong with my OS installation presently. I put a blank hard drive in (unplugged my normal boot drive) and did a clean install of windows 8.1. No more bluescreen. So I'm going to go back to my original ssd and try the things you have suggested.
Edit: I'm also going to make the jump and upgrade to 8.1 on my normal install. Microsoft recently announced that they are going to drop support for 8.0, 8.1 (without update 1) on May 9th (iirc).
Edit2: Since you asked, I have a 1200W Corsair AX1200 (the old one, not AX1200i)
    ASUS
    i7-3770K
    P8Z77-V DELUXE
    Radeon R9 290
    Onboard
    HP ZR22w x3
    1920x1080 x3
    Too many
    Corsair AX1200
    Rosewill Thor v2
    H2O
    Mozilla Firefox
usasma
Mr. Cranky Pants
5,139
If you suspect OS corruption, try this:
Then please run the following DISM commands to see if there's any problems with the system (from an elevated (Run as administrator) Command Prompt). Press Enter after each one:
Dism /Online /Cleanup-Image /ScanHealth
Dism /Online /Cleanup-Image /CheckHealth
FYI - I have repaired systems using the last command even though problems weren't found with the first 2 - so I suggest running them all.
From this article: Repair a Windows Image
You can also run sfc.exe /scannow from an elevated (Run as administrator) Command Prompt to check for further corruption.
    Samsung/NP780
    800x600
FMA1394
8
I just wanted to say that I have solved the problem! I ended up doing an upgrade install with a MSDN Windows 8.1 Pro with update installation DVD, which reset/uninstalled all drivers. After installing all of the latest drivers from AMD's and ASUS's websites, I was up and running. No more bluescreens. I'm able to encode video with x264.exe again with no problems whatsoever.
Before I originally posted on this forum, I had tried sfc /scannow and a dism command similar to one of the ones you mentioned. Neither had worked, but maybe I had not used the right dism commands.
Thanks for all the help.
tl;dr The fix for this problem was to upgrade to Windows 8.1 Pro with update.
    ASUS
    i7-3770K
    P8Z77-V DELUXE
    Radeon R9 290
    Onboard
    HP ZR22w x3
    1920x1080 x3
    Too many
    Corsair AX1200
    Rosewill Thor v2
    H2O
    Mozilla Firefox
