BSOD using wifi, error code random
andmau90
when i start to use wifi connection after an interval random time my pc restart with BSDO.
I think that the problem is the wifi card and i try an usb card but the same problem returns.
with ethernet everything is fine.View attachment 53318
Can you help me to solve this important problem?
thank you very much
Out of 12 memory dumps there were 7 different BSOD error codes. The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking/overheating - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- dirt/dust/hair/fur/crud inside the case. Blow out the case/vents with canned air (DO NOT use an air compressor or vacuum as they can cause damage to the system)
- missing Windows Updates
- compatibility issues (3rd party hardware/drivers), older systems, or even pirated systems
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
You can get a head start on the hardware diagnostics if you'd like - they are located here: Hardware Diagnostics
Your UEFI/BIOS dates from 2011. Please check at the manufacturer's website to see if there are any UEFI/BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the UEFI/BIOS is a very unforgiving process - and one mistake can physically damage your motherboard. If possible, use the "inside Windows" flash mechanism (if your OEM provides one) - that is much more forgiving than the traditional (floppy drive) flash method.
There's lot's of network issues in the memory dumps, and many of them are related to Virtual Box. I'd suggest uninstalling it in order to test it. Feel free to reinstall it after the system has been stabilized.
Lot's of Windows Updates failures in the WER section of the MSINFO32 report. If the problems continue, please post over in the Windows Updates & Activation - Windows 8 Forums for further expert assistance with this issue.
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Windows systems.
NOTE: these symptoms were from the previous release of OverDrive. The new release uses the same driver name, but is dated from 4 November 2013.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure - Sysnative Forums
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
hpdskflt.sys Fri Jan 7 12:17:50 2011 (4D274ABE)
HP Mobile Data Protection System Disk Filter
http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys
Accelerometer.sys Fri Jan 7 12:17:50 2011 (4D274ABE)
HP Mobile Data Protection System Accelerometer
http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys
SynTP.sys Thu Oct 13 22:34:52 2011 (4E979FCC)
Synaptic Touch Pad Driver
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
AODDriver2.sys Tue Feb 11 06:06:52 2014 (52FA044C)
AMD Overdrive; also in EasyTune6 for Gigabyte motherboard [br] Known BSOD issues in Win7[br][br]Part of AMD Fuel[br][br]Location: C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
If this doesn't resolve the problem and the hardware diagnostics all pass - then try Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[font=lucida console]**************************Tue Nov  4 05:45:37.796 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\110414-18109-01.dmp]
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Built by: [B]9600[/B].17328.amd64fre.winblue_r3.140827-1500
System Uptime:[B]2 days 20:36:58.794[/B]
*** ERROR: Module load completed but symbols could not be loaded for Ndu.sys
*** ERROR: Module load completed but symbols could not be loaded for wfplwfs.sys
*** WARNING: Unable to verify timestamp for netr28ux.sys
*** ERROR: Module load completed but symbols could not be loaded for netr28ux.sys
Probably caused by :[B]Ndu.sys ( Ndu+c54b )[/B]
BugCheck [B]C2, {7, 1200, c050008, ffffe00044815090}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000C2]BAD_POOL_CALLER (c2)[/url]
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 0000000000001200, (reserved)
Arg3: 000000000c050008, Memory contents of the pool block
Arg4: ffffe00044815090, Address of the block of pool being deallocated
BUGCHECK_STR:  0xc2_7_Io
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0xc2_7_Io___Ndu+c54b[/B]
  BIOS Version                  F.21
  BIOS Release Date             09/13/2011
  Manufacturer                  Hewlett-Packard
  Product Name                  HP Pavilion dv6 Notebook PC
**************************Fri Oct 31 19:52:32.827 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\110114-17750-01.dmp]
System Uptime:[B]0 days 0:38:02.818[/B]
*** ERROR: Module load completed but symbols could not be loaded for Wdf01000.sys
Probably caused by :[B]HDAudBus.sys ( HDAudBus!HdaController::PowerDown+1e9 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8005a1238a8, ffffd000301a2348, ffffd000301a1b50}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x1000007E]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/url]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8005a1238a8, The address that the exception occurred at
Arg3: ffffd000301a2348, Exception Record Address
Arg4: ffffd000301a1b50, Context Record Address
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_HDAudBus!HdaController::PowerDown[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 19:09:51.731 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\110114-17203-01.dmp]
System Uptime:[B]0 days 0:03:28.733[/B]
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by :[B]win32k.sys ( win32k+5a429 )[/B]
BugCheck [B]3B, {c0000005, fffff80041d29ba4, ffffd0004039ad70, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80041d29ba4, Address of the instruction which caused the bugcheck
Arg3: ffffd0004039ad70, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]0x3B_win32k+5a429[/B]
  BIOS Version                  F.21
**************************Sat Nov  1 06:42:25.903 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\110114-20875-01.dmp]
System Uptime:[B]0 days 2:50:50.904[/B]
Probably caused by :[B]memory_corruption ( nt!MiFindLastSubsection+27 )[/B]
BugCheck [B]24, {b500190637, ffffd000416d1c18, ffffd000416d1420, fffff800fd8db3f3}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000024]NTFS_FILE_SYSTEM (24)[/url]
Arguments:
Arg1: 000000b500190637
Arg2: ffffd000416d1c18
Arg3: ffffd000416d1420
Arg4: fffff800fd8db3f3
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]0x24_nt!MiFindLastSubsection[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 09:01:38.137 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-16421-01.dmp]
System Uptime:[B]0 days 0:11:00.133[/B]
*** WARNING: Unable to verify timestamp for VBoxNetFlt.sys
*** ERROR: Module load completed but symbols could not be loaded for VBoxNetFlt.sys
Probably caused by :[B]VBoxNetFlt.sys ( VBoxNetFlt+523b )[/B]
BugCheck [B]D1, {28, 2, 1, fffff8008d4a255f}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: 0000000000000028, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff8008d4a255f, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_VBoxNetFlt+523b[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 08:49:58.558 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-28765-01.dmp]
System Uptime:[B]0 days 0:38:39.551[/B]
BugCheck [B]D1, {28, 2, 1, fffff8001512755f}[/B]
Arguments:
Arg4: fffff8001512755f, address which referenced memory
BUGCHECK_STR:  AV
  BIOS Version                  F.21
**************************Fri Oct 31 08:10:54.838 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-16031-01.dmp]
System Uptime:[B]0 days 0:11:55.828[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KxWaitForLockOwnerShipWithIrql+14 )[/B]
BugCheck [B]24, {b500190637, ffffd000214182c8, ffffd00021417ad0, fffff801a94b2ba4}[/B]
Arguments:
Arg2: ffffd000214182c8
Arg3: ffffd00021417ad0
Arg4: fffff801a94b2ba4
PROCESS_NAME:  explorer.exe
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]0x24_nt!KxWaitForLockOwnerShipWithIrql[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 07:58:34.264 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-16343-01.dmp]
System Uptime:[B]0 days 0:04:47.264[/B]
Probably caused by :[B]win32k.sys ( win32k+1633fc )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff800ac43e867, 0, ffffffffffffffff}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001E]KMODE_EXCEPTION_NOT_HANDLED (1e)[/url]
Arguments:
Arg2: fffff800ac43e867, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_R
PROCESS_NAME:  csrss.exe
FAILURE_BUCKET_ID: [B]0x1E_c0000005_R_win32k+1633fc[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 07:49:36.299 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-15468-01.dmp]
System Uptime:[B]0 days 0:02:11.301[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiFastFailDispatch+d0 )[/B]
BugCheck [B]139, {3, ffffd0002069c680, ffffd0002069c5d8, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000139]KERNEL_SECURITY_CHECK_FAILURE (139)[/url]
Arguments:
Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
Arg2: ffffd0002069c680, Address of the trap frame for the exception that caused the bugcheck
Arg3: ffffd0002069c5d8, Address of the exception record for the exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
BUGCHECK_STR:  0x139
DEFAULT_BUCKET_ID:  LIST_ENTRY_CORRUPT
PROCESS_NAME:  taskhostex.exe
FAILURE_BUCKET_ID: [B]0x139_3_nt!KiFastFailDispatch[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 07:46:56.513 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-15984-01.dmp]
System Uptime:[B]0 days 0:12:10.514[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!RtlAvlInsertNodeEx+6a )[/B]
BugCheck [B]3B, {c0000005, fffff8005f8c8892, ffffd000419dcd50, 0}[/B]
Arguments:
Arg2: fffff8005f8c8892, Address of the instruction which caused the bugcheck
Arg3: ffffd000419dcd50, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME:  lsass.exe
FAILURE_BUCKET_ID: [B]0x3B_nt!RtlAvlInsertNodeEx[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 07:34:16.521 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-17078-01.dmp]
System Uptime:[B]0 days 1:54:42.523[/B]
*** ERROR: Module load completed but symbols could not be loaded for nwifi.sys
Probably caused by :[B]nwifi.sys ( nwifi+cdaf )[/B]
BugCheck [B]D1, {ffffe000073b9fee, 2, 1, fffff8000403cdaf}[/B]
Arguments:
Arg1: ffffe000073b9fee, memory referenced
Arg4: fffff8000403cdaf, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nwifi+cdaf[/B]
  BIOS Version                  F.21
**************************Fri Oct 31 04:03:32.547 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103114-16281-01.dmp]
System Uptime:[B]0 days 9:30:50.546[/B]
BugCheck [B]139, {3, ffffd000a4fb88e0, ffffd000a4fb8838, 0}[/B]
Arguments:
Arg2: ffffd000a4fb88e0, Address of the trap frame for the exception that caused the bugcheck
Arg3: ffffd000a4fb8838, Address of the exception record for the exception that caused the bugcheck
BUGCHECK_STR:  0x139
PROCESS_NAME:  CCC.exe
  BIOS Version                  F.21
[/font]
3rd Party Drivers:
[COLOR=RED][B]hpdskflt.sys                Fri Jan  7 12:17:50 2011 (4D274ABE)[/B][/COLOR]
[COLOR=RED][B]Accelerometer.sys           Fri Jan  7 12:17:50 2011 (4D274ABE)[/B][/COLOR]
[COLOR=RED][B]SynTP.sys                   Thu Oct 13 22:34:52 2011 (4E979FCC)[/B][/COLOR]
RtsPStor.sys                Thu Mar 29 03:09:33 2012 (4F740AAD)
netr28ux.sys                Thu Apr 25 22:33:43 2013 (5179E787)
[COLOR=RED][B]AODDriver2.sys              Tue Feb 11 06:06:52 2014 (52FA044C)[/B][/COLOR]
amd_sata.sys                Thu Mar 20 23:01:59 2014 (532BABA7)
amd_xata.sys                Thu Mar 20 23:02:02 2014 (532BABAA)
netr28x.sys                 Wed Apr  9 09:02:41 2014 (534544F1)
Rt630x64.sys                Tue Jun 17 07:56:46 2014 (53A02CFE)
AMDACPKSL.SYS               Sat Jun 21 22:31:43 2014 (53A6400F)
AtihdWB6.sys                Sat Jun 21 22:32:00 2014 (53A64020)
atikmpag.sys                Mon Sep 15 17:59:06 2014 (5417612A)
atikmdag.sys                Mon Sep 15 18:21:08 2014 (54176654)
VBoxDDR0.r0                 Sat Oct 11 07:26:21 2014 (543913DD)
VBoxDD2R0.r0                Sat Oct 11 07:26:21 2014 (543913DD)
VBoxNetAdp.sys              Sat Oct 11 07:26:22 2014 (543913DE)
VBoxNetFlt.sys              Sat Oct 11 07:26:22 2014 (543913DE)
VBoxUSBMon.sys              Sat Oct 11 07:26:22 2014 (543913DE)
VBoxDrv.sys                 Sat Oct 11 07:28:48 2014 (54391470)
VMMR0.r0                    Sat Oct 11 07:28:48 2014 (54391470)
hiber_amd_sata.sys          Thu Mar 20 23:01:59 2014 (532BABA7)
Rt630x64.sys                Fri May 10 05:59:08 2013 (518CC4EC)
amdxata.sys                 Mon Jul  8 18:45:00 2013 (51DB40EC)
amdsata.sys                 Mon Jul  8 18:54:38 2013 (51DB432E)
AODDriver2.sys              Wed Sep 11 23:36:40 2013 (523136C8)
tap0901.sys                 Tue Apr  8 09:33:45 2014 (5343FAB9)
atikmpag.sys                Fri Jul  4 21:26:52 2014 (53B7545C)
atikmdag.sys                Fri Jul  4 21:39:13 2014 (53B75741)
netr28x.sys                 Thu Jul 11 05:27:41 2013 (51DE7A8D)
magdrvamd64.sys             Mon May 19 10:55:50 2014 (537A1B76)
netr28x.sys                 Tue Nov 26 03:32:39 2013 (52945CA7)
[/font]
http://www.carrona.org/drivers/driver.php?id=RtsPStor.sys
http://www.carrona.org/drivers/driver.php?id=netr28ux.sys
http://www.carrona.org/drivers/driver.php?id=amd_sata.sys
http://www.carrona.org/drivers/driver.php?id=amd_xata.sys
http://www.carrona.org/drivers/driver.php?id=netr28x.sys
http://www.carrona.org/drivers/driver.php?id=AMDACPKSL.SYS
http://www.carrona.org/drivers/driver.php?id=AtihdWB6.sys
http://www.carrona.org/drivers/driver.php?id=VBoxDDR0.r0
http://www.carrona.org/drivers/driver.php?id=VBoxDD2R0.r0
http://www.carrona.org/drivers/driver.php?id=VBoxNetAdp.sys
http://www.carrona.org/drivers/driver.php?id=VBoxNetFlt.sys
http://www.carrona.org/drivers/driver.php?id=VBoxUSBMon.sys
http://www.carrona.org/drivers/driver.php?id=VBoxDrv.sys
http://www.carrona.org/drivers/driver.php?id=VMMR0.r0
hiber_amd_sata.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=amdsata.sys
http://www.carrona.org/drivers/driver.php?id=tap0901.sys
http://www.carrona.org/drivers/driver.php?id=magdrvamd64.sys
