BSOD using Chrome + Skype, IRQL_Not_Less_Or_Equal.
rayrayray
Dear all,
My laptop has been suffering from BSOD almost every 1 hour since 2-3days ago! :(
Key details of my laptop:
Lenovo Y410P
Windows 8.1 64-bit, x64
i7-4700MQ
RAM 8GB
NVidia GeForce GT750M
Error code: IRQL_NOT_LESS_OR_EQUAL
Extra note: I have moved my OS from the existing hard-disk HDD to a SSD since the very beginning (1.5 years ago) but the problem has only existed since 1 week ago. (I don't know how to reinstall windows 8 on my laptop.. will need guidance on this as well if necessary!)
Please help, and thank you in advance!!
Hello, and welcome to EF.
It's always weird how errors like these can just happen out of nowhere. But these crash files are really detemined to blame your LAN driver:
Probably caused by :[COLOR="#FF0000"]athw8x.sys[/COLOR] ( athw8x+26cac7 )
Let's update it: http://www.atheros.cz/
Although that may not be the fix, lets keep with this for now, and go step by step instead of blasting you with a list of things to get done. Easier to narrow it down :)
-Justin
    Windows 8 Pro x64
    Custom
    Intel Core i5-4570 CPU @ 3.20GHz
    Gigabyte Z87-D3HP-CF
    8GB DDR3-1596 - Dual Channel
    NVIDIA GeForce GTX 750 Ti
    Onboard
    Samsung
    SSD - 120GB
    Second - 1TB
    Chrome
    Avast
Thank you HonorGamer!!
I have just updated my Wireless Driver 10 minutes ago. Will keep this thread updated with BSOD or not occurrences in the next few days.
Hope all goes well! :) :) :)
Sounds good! Just remember if you do get another BSOD, to do the same this as you did on the first post and follow the posting instructions.
-Justin
    Windows 8 Pro x64
    Custom
    Onboard
    Samsung
    SSD - 120GB
    Second - 1TB
    Chrome
    Avast
Hey Justin!
Everything was working just fine.. until it BSOD twice - once when I was using Chrome, the other while i was using Firefox.
Attached is the Debug files again.. Hopefully this doesn't crash on me while i'm posting here!
