BSOD re Page Fault and Drive Power State Failure
1
Lately my 1.5 year old ASUS CM6870 Desktop running Win8.1 started to give me the BSOD with the following two error messages: Page Fault in Non_Page Area; and Drive Power State Failure. Occasionally I will get the sudden BSOD and this B stands for Black with no cursor or message showing. In about 10 seconds the monitor will display a message saying it is going into inactive mode. I pressed the desktop power button, the system just shut down. Two days ago at log off Windows was doing update and at 30%, everything was frozen. Left it on the whole night, same screen the next morning. Need to depress the power button to shut down the system although Windows said I can't shut down the PC while it's doing an update. That's about the symptoms I can recap for now. Zip file attached as instructed. Thanks.
softwaremaniac
2,480
There is no dump file. Please check your minidump folder for it. When you find it, upload it. If you are using CCleaner, please strop as it deletes minidumps.
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
