BSOD Loop after using driver verifier
Danoes
14
Hello
I decided to use driver verifier after having trouble with regular BSOD concerning: MemoryManagement, DriverIRQLNotEqual and others. Now I keep having BSOD (Driver_Verifier_detected_violation) as I boot my laptop up. I don't even have time to login.
OS:Windows8.1.
What to do?
    AcerAspireV3 772G
usasma
Mr. Cranky Pants
5,139
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
Danoes
14
Thanks for the quick reply, Sir!
The thing I'm experiencing is as it says in the article that you're too slow to click F8 or Shift+F8.
Is it me or am I doing it wrong?
EDIT: I can't do anything at all.
EDIT1: It might have something to do with BIOS or something?
    AcerAspireV3 772G
usasma
Mr. Cranky Pants
5,139
The F8 thing only works with systems that have a BIOS (not a UEFI). If the system came with Win8 or 8.1 - then it has a UEFI and you can't use the F8 method.
Do you have a recovery drive? If so, can you boot from it (I think Acer uses F12 to access the boot menu).
Alternately, try to boot the computer and shut it down before it hits the BSOD (by holding the power button down)
Try this at least 3 times - it's supposed to get you to the Startup Repair menu (so you can use the steps in the second option)
    Samsung/NP780
    800x600
Danoes
14
Okay, I tried all of above but none worked and I also don't have a recovery drive, I'm afraid...
This leaves me at zero options again I guess.
Do you have any other ideas?
I do have the faster system where you can't use F8.
EDIT: I can however get into the setup utility or something but don't know the possibilities of this.
    AcerAspireV3 772G
usasma
Mr. Cranky Pants
5,139
Do you know anyone who has a Win8/8.1 system that you can make a recovery drive on?
Maybe try it on one of the computers at a local computer shop?
You'll need a small flash drive (1gB or less in most cases) - don't copy the recovery partition
What setup utility are you referring to? How do you get into it?
    Samsung/NP780
    800x600
Danoes
14
It's called BIOS setup, I'll bring my pc to a pc fixing shop as I have no more options or a USB drive.
    AcerAspireV3 772G
usasma
Mr. Cranky Pants
5,139
#8
The UEFI/BIOS setup won't help here.
If you're unable to get to system repair, it's best to let a shop disable it for you.
Good luck!
    Samsung/NP780
    800x600
