Solved BSOD Help
Been having this problem with my PC for a while now and have tried many fixes.
Any help would be appreciated. Thank you in advance.
(SF Diagnostic Tool Files attached)
[FONT=Segoe UI, Arial]System Information (local)[HR][/HR][/FONT]
[FONT=Segoe UI, Arial]computer name: OBSIDIAN
windows version: Windows 8 , 6.2, build: 9200
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8457207808 total
VM: 2147352576, free: 1914744832
[/FONT]
[FONT=Segoe UI, Arial][HR][/HR]Crash Dump Analysis[HR][/HR][/FONT]
[FONT=Segoe UI, Arial]Crash dump directory: C:\Windows\Minidump[/FONT]
[FONT=Segoe UI, Arial][/FONT]
[FONT=Segoe UI, Arial]Crash dumps are enabled on your computer.
[/FONT]
[FONT=Segoe UI, Arial]On Thu 5/30/2013 5:34:47 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\053013-25281-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]tcpip.sys[/FONT] (0xFFFFF88001CFB5F8)
Bugcheck code: 0xD1 (0x28, 0x2, 0x0, 0xFFFFF88001CFB5F8)
Error: [FONT=Segoe UI, Arial]DRIVER_IRQL_NOT_LESS_OR_EQUAL[/FONT]
file path: C:\Windows\system32\drivers\tcpip.sys
product: [FONT=Segoe UI, Arial]Microsoft® Windows® Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: TCP/IP Driver
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
[/FONT]
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]bckd.sys[/FONT] (bckd+0xFC57)
file path: C:\Windows\system32\drivers\bckd.sys
product: [FONT=Segoe UI, Arial]K9 Web Protection[/FONT]
company: [FONT=Segoe UI, Arial]Blue Coat Systems, Inc.[/FONT]
description: K9 Web Protection Driver (WFP)
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: bckd.sys (K9 Web Protection Driver (WFP), Blue Coat Systems, Inc.).
Google query: [FONT=Segoe UI, Arial]Blue Coat Systems, Inc. DRIVER_IRQL_NOT_LESS_OR_EQUAL[/FONT]
[/FONT]
[FONT=Segoe UI, Arial]On Wed 5/29/2013 8:57:34 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\052913-40578-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]tcpip.sys[/FONT] (0xFFFFF88001D1D5F8)
Bugcheck code: 0xD1 (0x28, 0x2, 0x0, 0xFFFFF88001D1D5F8)
[/FONT]
[FONT=Segoe UI, Arial]On Wed 5/22/2013 2:58:14 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\052213-32281-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntfs.sys[/FONT] (Ntfs+0x40C90)
Bugcheck code: 0x24 (0xB50019060B, 0xFFFFF8801E8E2198, 0xFFFFF8801E8E19D0, 0xFFFFF8009BE57DB5)
Error: [FONT=Segoe UI, Arial]NTFS_FILE_SYSTEM[/FONT]
file path: C:\Windows\system32\drivers\ntfs.sys
description: NT File System Driver
Bug check description: This indicates a problem occurred in the NTFS file system.
[/FONT]
[FONT=Segoe UI, Arial]On Mon 5/20/2013 3:49:54 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\051913-27062-01.dmp
Bugcheck code: 0x24 (0xB50019060B, 0xFFFFF8800487A428, 0xFFFFF88004879C60, 0xFFFFF8800136C9F7)
[/FONT]
[FONT=Segoe UI, Arial]On Mon 5/20/2013 3:08:27 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\051913-34562-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x5A440)
Bugcheck code: 0x50 (0xFFFFF6FE50029598, 0x0, 0xFFFFF802317B61E8, 0x2)
Error: [FONT=Segoe UI, Arial]PAGE_FAULT_IN_NONPAGED_AREA[/FONT]
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
[/FONT]
[FONT=Segoe UI, Arial]On Tue 4/30/2013 4:27:36 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\043013-29109-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x5A240)
Bugcheck code: 0xA (0xA00FFFFD8, 0x2, 0x0, 0xFFFFF8039B17580F)
Error: [FONT=Segoe UI, Arial]IRQL_NOT_LESS_OR_EQUAL[/FONT]
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
[/FONT][FONT=Segoe UI, Arial]
[/FONT]
    Custom Build
    Intel Core i5-3570K
    ASUS P8Z77-V
    Corsair Vengeance 4x2GB CMZ4GX3M2A1600C9
    GIGABYTE GV-N66TOC-2GD GeForce GTX 660 Ti 2GB
    On board
    ASUS VS228H-P 22.5"
    Seagate ST2000DM001 Barracuda 7200RPM 2 TB
    Corsair CX Series 600 Watt
    Corsair Carbide Series Black 400R
    Cooler Master-Hyper 212 EVO
    Chrome
    Norton 360 Premier Edition
    K9 Internet Filter
usasma
Mr. Cranky Pants
5,139
These devices have problems in Device Manager:
Not Available ROOT\STORLIB\0001 The drivers for this device are not installed.
Not Available ROOT\STORLIB\0002 The drivers for this device are not installed.
They are likely to be due to a program from Eldos Corporation: https://www.eldos.com/ Reinstall, then uninstall the program.
MSI Afterburner (along with Riva Tuner and EVGA Precision) are known to cause BSOD's in some Windows systems (it's driver is usually RTCore64.sys). Please un-install it immediately!
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
ICCWDT.sys (Intel Watchdog Timer Driver) dates from 2010 - please update your Intel components to the latest, Win8 compatible versions.
AsIO.sys dates from 2010 - Asus PCProbe Utility and other utilities
AsUpIO.sys dates from 2010 - ASUS hardware monitoring software related
Please update your Asus utilities to the latest, Win8 compatible versions.
The latest memory dump blames networking components, while earlier dumps blame storage sub-system and video sub-system components.
Start by running Driver Verifier to see if we can pin down the name of a driver. Please use these instructions: Driver Verifier Settings
As time allows, please start up on these free diagnostics (as a hardware problem could also be the reason for this): Hardware Diagnostics
Please let us know the results so we can move on to other diagnostics (if necessary).
Loading Dump File [C:\Users\Owner\Downloads\053013-25281-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols;srv*c:\SymcachePublic*http://ctxsym.citrix.com/symbolsad/symbols
Executable search path is:
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9200.16581.amd64fre.win8_gdr.130410-1505
Machine Name:
Kernel base = 0xfffff803`2881c000 PsLoadedModuleList = 0xfffff803`28ae8a20
Debug session time: Thu May 30 13:34:47.663 2013 (UTC - 4:00)
System Uptime: 0 days 2:13:55.355
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {28, 2, 0, fffff88001cfb5f8}
Probably caused by : NETIO.SYS ( NETIO!StreamInjectRequestsToStack+23e )
Followup: MachineOwner
1: kd> !analyze -v; !sysinfo cpuspeed; !sysinfo SMBIOS; lmtsmn
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000028, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88001cfb5f8, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80328b74168
GetUlongFromAddress: unable to read from fffff80328b741f8
 0000000000000028 Nonpaged pool
CURRENT_IRQL:  2
FAULTING_IP:
tcpip!TcpSegmentTcbSend+1c8
fffff880`01cfb5f8 8b4228          mov     eax,dword ptr [rdx+28h]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  AV
PROCESS_NAME:  System
TAG_NOT_DEFINED_c000000f:  FFFFF88001422FB0
TRAP_FRAME:  fffff880014221f0 -- (.trap 0xfffff880014221f0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=00000000000005ac
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88001cfb5f8 rsp=fffff88001422380 rbp=00000000ffffffd6
 r8=00000000000005ac  r9=000000000000002a r10=fffff88001e22078
r11=0000000000000006 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl nz ac pe nc
tcpip!TcpSegmentTcbSend+0x1c8:
fffff880`01cfb5f8 8b4228          mov     eax,dword ptr [rdx+28h] ds:00000000`00000028=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80328875769 to fffff80328876440
STACK_TEXT:
fffff880`014220a8 fffff803`28875769 : 00000000`0000000a 00000000`00000028 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`014220b0 fffff803`28873fe0 : 00000000`00000000 fffff880`014225a0 fffff880`01422600 fffff880`014221f0 : nt!KiBugCheckDispatch+0x69
fffff880`014221f0 fffff880`01cfb5f8 : fffffa80`07978b0c fffff880`01422640 00000000`00000000 fffffa80`077ea201 : nt!KiPageFault+0x260
fffff880`01422380 fffff880`01cfa67f : 00000000`43f25b88 fffffa80`0701de90 00000000`00000000 fffffa80`0701dfe8 : tcpip!TcpSegmentTcbSend+0x1c8
fffff880`01422480 fffff880`01cfbdf8 : fffff880`01e24b90 00000000`00000000 00000000`00000000 00000000`ffffffd6 : tcpip!TcpBeginTcbSend+0x3af
fffff880`01422710 fffff880`01d064b1 : 00000000`00000001 fffff880`01d0eb1c fffff880`01422b02 00000000`00000002 : tcpip!TcpTcbSend+0x1e8
fffff880`01422a80 fffff880`01d063c1 : 00000000`00000000 fffffa80`074344d0 00000000`00000001 00000000`00000040 : tcpip!TcpEnqueueTcbSendOlmNotifySendComplete+0xa1
fffff880`01422ab0 fffff880`01a38626 : 00000000`00000000 fffffa80`0acb1590 fffff880`01422bf9 fffffa80`0dbd61f0 : tcpip!TcpEnqueueTcbSend+0x741
fffff880`01422b80 fffff880`01a3807b : fffffa80`0b2e3cb0 fffffa80`074344d0 00000000`00000000 fffff880`1d980000 : NETIO!StreamInjectRequestsToStack+0x23e
fffff880`01422c60 fffff880`01a37f21 : fffffa80`0b2e3cb0 00000000`00000000 fffffa80`06a6e010 00000000`00000002 : NETIO!StreamPermitDataHelper+0x5f
fffff880`01422c90 fffff803`2889eca1 : fffff880`009f2f00 fffff880`01422e00 fffffa80`0e1a1530 00000000`00000000 : NETIO!StreamPermitRemoveDataDpc+0x81
fffff880`01422d00 fffff803`2889e8e0 : fffff880`009f0180 fffff880`1a276830 fffffa80`0be0b9c0 00000000`00000004 : nt!KiExecuteAllDpcs+0x191
fffff880`01422e40 fffff803`28870385 : 00000000`00000000 fffff880`009f0180 fffff880`1ada54a0 fffffa80`0e1a1470 : nt!KiRetireDpcList+0xd0
fffff880`01422fb0 fffff803`28870189 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxRetireDpcList+0x5
fffff880`1ada53f0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`01a38626 8bf0            mov     esi,eax
SYMBOL_STACK_INDEX:  8
SYMBOL_NAME:  NETIO!StreamInjectRequestsToStack+23e
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: NETIO
IMAGE_NAME:  NETIO.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  50765624
BUCKET_ID_FUNC_OFFSET:  23e
FAILURE_BUCKET_ID:  AV_NETIO!StreamInjectRequestsToStack
CPUID:        "Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz"
MaxSpeed:     3400
CurrentSpeed: 3400
[SMBIOS Data Tables v2.7]
[DMI Version - 39]
[2.0 Calling Convention - No]
[Table Size - 3892 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
  Vendor                        American Megatrends Inc.
  BIOS Version                  1805
  BIOS Starting Address Segment f000
  BIOS Release Date             12/19/2012
  BIOS ROM Size                 800000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       12: - BIOS Shadowing Supported
       15: - CD-Boot Supported
       16: - Selectable Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       26: - Print Screen Device Supported
       27: - Keyboard Services Supported
       28: - Serial Services Supported
       29: - Printer Services Supported
       32: - BIOS Vendor Reserved
  BIOS Characteristic Extensions
       00: - ACPI Supported
       01: - USB Legacy Supported
       08: - BIOS Boot Specification Supported
       10: - Specification Reserved
       11: - Specification Reserved
  BIOS Major Revision           4
  BIOS Minor Revision           6
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
[System Information (Type 1) - Length 27 - Handle 0001h]
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
  Version                       System Version
  Serial Number
  UUID                          00000000-0000-0000-0000-000000000000
  Wakeup Type                   Power Switch
  SKUNumber                     SKU
  Family                        To be filled by O.E.M.
[BaseBoard Information (Type 2) - Length 15 - Handle 0002h]
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product                       P8Z77-V
  Version                       Rev 1.xx
  Serial Number
  Asset Tag
  Feature Flags                 09h
       -439804448: - (null)
       -439804400: - (null)
  Location                      To be filled by O.E.M.
  Chassis Handle                0003h
  Board Type                    0ah - Processor/Memory Module
  Number of Child Handles       0
[System Enclosure (Type 3) - Length 22 - Handle 0003h]
  Manufacturer                  Chassis Manufacture
  Chassis Type                  Desktop
  Version                       Chassis Version
  Serial Number
  Asset Tag Number
  Bootup State                  Safe
  Power Supply State            Safe
  Thermal State                 Safe
  Security Status               None
  OEM Defined                   0
  Height                        0U
  Number of Power Cords         1
  Number of Contained Elements  0
  Contained Element Size        0
[Processor Information (Type 4) - Length 42 - Handle 0004h]
  Socket Designation            LGA1155
  Processor Type                Central Processor
  Processor Family              bfh - Specification Reserved
  Processor Manufacturer        Intel
  Processor ID                  a9060300fffbebbf
  Processor Version             Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
  Processor Voltage             8ah - 1.0V
  External Clock                100MHz
  Max Speed                     3800MHz
  Current Speed                 3422MHz
  Status                        Enabled Populated
  Processor Upgrade             Other
  L1 Cache Handle               0005h
  L2 Cache Handle               0006h
  L3 Cache Handle               0007h
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
[Cache Information (Type 7) - Length 19 - Handle 0005h]
  Socket Designation            L1-Cache
  Cache Configuration           0180h - WB Enabled Int NonSocketed L1
  Maximum Cache Size            0100h - 256K
  Installed Size                0100h - 256K
  Supported SRAM Type           0001h - Other
  Current SRAM Type             0001h - Other
  Cache Speed                   0ns
  Error Correction Type         None
  System Cache Type             Unified
  Associativity                 8-way Set-Associative
[Cache Information (Type 7) - Length 19 - Handle 0006h]
  Socket Designation            L2-Cache
  Cache Configuration           0281h - Varies Enabled Int NonSocketed L2
  Maximum Cache Size            0400h - 1024K
  Installed Size                0400h - 1024K
  Cache Speed                   0ns
[Cache Information (Type 7) - Length 19 - Handle 0007h]
  Socket Designation            L3-Cache
  Cache Configuration           0302h - Unknown Disabled Int NonSocketed L3
  Maximum Cache Size            1800h - 6144K
  Installed Size                1800h - 6144K
  Cache Speed                   0ns
  Associativity                 Other
[Onboard Devices Information (Type 10) - Length 6 - Handle 0024h]
  Number of Devices             1
  01: Type                      Ethernet [enabled]
  01: Description               Onboard Ethernet
[OEM Strings (Type 11) - Length 5 - Handle 0025h]
  Number of Strings             4
   1                            To Be Filled By O.E.M.
   2                            To Be Filled By O.E.M.
   3                            To Be Filled By O.E.M.
   4                            To Be Filled By O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 0026h]
[Memory Device (Type 17) - Length 34 - Handle 005ah]
  Physical Memory Array Handle  005bh
  Memory Error Info Handle      005fh
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          2048MB
  Form Factor                   09h - DIMM
  Device Set                    [None]
  Device Locator                ChannelA-DIMM0
  Bank Locator                  BANK 0
  Memory Type                   18h - Specification Reserved
  Type Detail                   0080h - Synchronous
  Speed                         1600MHz
  Manufacturer                  029E
  Serial Number
  Asset Tag Number
  Part Number                   CMZ4GX3M2A1600C9
[Physical Memory Array (Type 16) - Length 23 - Handle 005bh]
  Location                      03h - SystemBoard/Motherboard
  Use                           03h - System Memory
  Memory Error Correction       03h - None
  Maximum Capacity              33554432KB
  Memory Error Inf Handle       005ch
  Number of Memory Devices      4
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 005ch]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 005dh]
  Starting Address              00000000h
  Ending Address                001fffffh
  Memory Device Handle          005ah
  Mem Array Mapped Adr Handle   0067h
  Partition Row Position        [Unknown]
  Interleave Position           01
  Interleave Data Depth         02
[Memory Device (Type 17) - Length 34 - Handle 005eh]
  Memory Error Info Handle      [No Errors]
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          2048MB
  Device Set                    [None]
  Device Locator                ChannelA-DIMM1
  Bank Locator                  BANK 1
  Speed                         1600MHz
  Manufacturer                  029E
  Serial Number
  Asset Tag Number
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 005fh]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0060h]
  Starting Address              00400000h
  Ending Address                005fffffh
  Memory Device Handle          005eh
[Memory Device (Type 17) - Length 34 - Handle 0061h]
  Memory Error Info Handle      0062h
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          2048MB
  Device Set                    [None]
  Device Locator                ChannelB-DIMM0
  Bank Locator                  BANK 2
  Speed                         1600MHz
  Manufacturer                  029E
  Serial Number
  Asset Tag Number
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0062h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0063h]
  Starting Address              00200000h
  Ending Address                003fffffh
  Memory Device Handle          0061h
  Interleave Position           02
[Memory Device (Type 17) - Length 34 - Handle 0064h]
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          2048MB
  Device Set                    [None]
  Device Locator                ChannelB-DIMM1
  Bank Locator                  BANK 3
  Speed                         1600MHz
  Manufacturer                  029E
  Serial Number
  Asset Tag Number
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0065h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0066h]
  Starting Address              00600000h
  Ending Address                007fffffh
  Memory Device Handle          0064h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0067h]
  Partition Width               04
fffff880`01163000 fffff880`011d0000   ACPI     ACPI.sys     Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`01141000 fffff880`01158000   acpiex   acpiex.sys   Wed Jul 25 22:25:57 2012 (5010AAB5)
fffff880`03b33000 fffff880`03bc5000   afd      afd.sys      Mon Nov 05 22:53:42 2012 (509889C6)
fffff880`046b9000 fffff880`046d1000   AgileVpn AgileVpn.sys Wed Jul 25 22:23:11 2012 (5010AA0F)
fffff880`05c00000 fffff880`05c27000   AnyDVD   AnyDVD.sys   Thu Apr 25 09:44:29 2013 (5179333D)
fffff880`012be000 fffff880`012cd000   asahci64 asahci64.sys Thu Jan 05 00:08:19 2012 (4F053043)
fffff880`0465a000 fffff880`04660000   AsIO     AsIO.sys     Mon Aug 23 21:53:02 2010 (4C7325FE)
fffff880`04653000 fffff880`0465a000   AsUpIO   AsUpIO.sys   Mon Aug 02 22:47:59 2010 (4C57835F)
fffff880`1ec40000 fffff880`1ec4c000   asyncmac asyncmac.sys Wed Jul 25 22:28:25 2012 (5010AB49)
fffff880`00fec000 fffff880`00ff6000   atapi    atapi.sys    Wed Jul 25 22:30:33 2012 (5010ABC9)
fffff880`01000000 fffff880`01034000   ataport  ataport.SYS  Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`05cb1000 fffff880`05f84000   athrx    athrx.sys    Wed Mar 21 23:26:22 2012 (4F6A9BDE)
fffff880`0384e000 fffff880`0385f000   BasicDisplay BasicDisplay.sys Wed Jul 25 22:29:08 2012 (5010AB74)
fffff880`016e9000 fffff880`016f6000   BasicRender BasicRender.sys Wed Jul 25 22:28:51 2012 (5010AB63)
fffff880`1a663000 fffff880`1a684000   bckd     bckd.sys     Fri Mar 01 06:20:57 2013 (51308F19)
fffff880`01bf4000 fffff880`01bfc000   Beep     Beep.SYS     Wed Jul 25 22:30:19 2012 (5010ABBB)
fffff880`044fc000 fffff880`04653000   BHDrvx64 BHDrvx64.sys Wed Apr 10 01:39:03 2013 (5164FAF7)
fffff880`00c00000 fffff880`00c0a000   BOOTVID  BOOTVID.dll  Wed Jul 25 22:30:22 2012 (5010ABBE)
fffff880`1a770000 fffff880`1a790000   bowser   bowser.sys   Wed Jul 25 22:28:01 2012 (5010AB31)
fffff880`016bb000 fffff880`016e9000   ccSetx64 ccSetx64.sys Thu Aug 16 17:18:11 2012 (502D6393)
fffff960`00855000 fffff960`0088b000   cdd      cdd.dll      unavailable (00000000)
fffff880`0168a000 fffff880`016bb000   cdrom    cdrom.sys    Wed Jul 25 22:26:36 2012 (5010AADC)
fffff880`00c0a000 fffff880`00c89000   CI       CI.dll       Wed Mar 27 23:30:42 2013 (5153B962)
fffff880`01636000 fffff880`0168a000   CLASSPNP CLASSPNP.SYS Thu Feb 28 23:59:20 2013 (513035A8)
fffff880`00d66000 fffff880`00dc2000   CLFS     CLFS.SYS     Wed Jul 25 22:29:39 2012 (5010AB93)
fffff880`00e11000 fffff880`00e9d000   cng      cng.sys      Thu Oct 11 01:17:34 2012 (5076566E)
fffff880`046fd000 fffff880`0470c000   CompositeBus CompositeBus.sys Wed Jul 25 22:28:03 2012 (5010AB33)
fffff880`1b28d000 fffff880`1b29a000   condrv   condrv.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`01fe8000 fffff880`01ffc000   crashdmp crashdmp.sys Sat Feb 02 02:26:00 2013 (510CBF88)
fffff880`03eed000 fffff880`03f7e000   csc      csc.sys      Thu Sep 20 02:08:29 2012 (505AB2DD)
fffff880`04355000 fffff880`04376000   dfsc     dfsc.sys     Wed Jul 25 22:26:53 2012 (5010AAED)
fffff880`04344000 fffff880`04355000   discache discache.sys Wed Jul 25 22:28:23 2012 (5010AB47)
fffff880`01a9e000 fffff880`01aba000   disk     disk.sys     Wed Jul 25 22:29:25 2012 (5010AB85)
fffff880`047d1000 fffff880`047f3000   drmk     drmk.sys     Thu Oct 11 01:18:59 2012 (507656C3)
fffff880`06c63000 fffff880`06c70000   dump_diskdump dump_diskdump.sys Wed Jul 25 22:29:58 2012 (5010ABA6)
fffff880`06c86000 fffff880`06c9a000   dump_dumpfve dump_dumpfve.sys Thu Sep 20 02:09:30 2012 (505AB31A)
fffff880`06c70000 fffff880`06c86000   dump_storahci dump_storahci.sys Fri Mar 01 21:15:44 2013 (513160D0)
fffff880`03876000 fffff880`039df000   dxgkrnl  dxgkrnl.sys  Sat Apr 13 01:09:52 2013 (5168E8A0)
fffff880`03800000 fffff880`0384e000   dxgmms1  dxgmms1.sys  Tue Jan 08 22:58:58 2013 (50ECEB02)
fffff880`05598000 fffff880`055ee000   e1i63x64 e1i63x64.sys Wed Feb 29 22:25:14 2012 (4F4EEC1A)
fffff880`042a4000 fffff880`0431e000   eeCtrl64 eeCtrl64.sys Tue Jul 31 19:36:51 2012 (50186C13)
fffff880`012dc000 fffff880`012f6000   EhStorClass EhStorClass.sys Wed Jul 25 22:26:24 2012 (5010AAD0)
fffff880`04298000 fffff880`042a4000   ElbyCDIO ElbyCDIO.sys Mon Mar 04 04:21:51 2013 (513467AF)
fffff880`1ec1e000 fffff880`1ec40000   ENG64    ENG64.SYS    Fri Apr 26 02:10:48 2013 (517A1A68)
fffff880`0431e000 fffff880`04344000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Tue Jul 31 19:36:50 2012 (50186C12)
fffff880`1ea18000 fffff880`1ec1e000   EX64     EX64.SYS     Fri Apr 26 02:08:58 2013 (517A19FA)
fffff880`05f84000 fffff880`05fbb000   fastfat  fastfat.SYS  Wed Jul 25 22:30:23 2012 (5010ABBF)
fffff880`013d4000 fffff880`013e8000   fileinfo fileinfo.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`012f6000 fffff880`01356000   fltmgr   fltmgr.sys   Wed Jul 25 22:30:09 2012 (5010ABB1)
fffff880`0162c000 fffff880`01636000   Fs_Rec   Fs_Rec.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`01f4f000 fffff880`01fc5000   fvevol   fvevol.sys   Thu Sep 20 02:08:15 2012 (505AB2CF)
fffff880`01ecc000 fffff880`01f34000   fwpkclnt fwpkclnt.sys Thu Feb 28 23:55:54 2013 (513034DA)
fffff880`05c27000 fffff880`05c2dc00   GEARAspiWDM GEARAspiWDM.sys Thu May 03 15:56:17 2012 (4FA2E2E1)
fffff803`28f68000 fffff803`28fd4000   hal      hal.dll      Tue Oct 23 23:03:21 2012 (50875A79)
fffff880`05582000 fffff880`05598000   HDAudBus HDAudBus.sys Thu Sep 20 02:08:43 2012 (505AB2EB)
fffff880`06c0a000 fffff880`06c63000   HdAudio  HdAudio.sys  Tue Jan 08 22:59:46 2013 (50ECEB32)
fffff880`05600000 fffff880`05613000   HECIx64  HECIx64.sys  Mon Jul 02 18:14:58 2012 (4FF21D62)
fffff880`06cd2000 fffff880`06ced000   HIDCLASS HIDCLASS.SYS Mon Apr 08 22:34:48 2013 (51637E48)
fffff880`06c9a000 fffff880`06ca2000   HIDPARSE HIDPARSE.SYS Wed Jul 25 22:30:15 2012 (5010ABB7)
fffff880`06cc5000 fffff880`06cd2000   hidusb   hidusb.sys   Mon Apr 08 22:34:41 2013 (51637E41)
fffff880`1a691000 fffff880`1a770000   HTTP     HTTP.sys     Thu Mar 14 20:17:15 2013 (5142688B)
fffff880`05fc8000 fffff880`05fd4000   ICCWDT   ICCWDT.sys   Wed Aug 18 04:27:45 2010 (4C6B9981)
fffff880`04216000 fffff880`04298000   IDSvia64 IDSvia64.sys Tue Aug 28 22:48:40 2012 (503D8308)
fffff880`05649000 fffff880`05b641a0   igdkmd64 igdkmd64.sys Wed Dec 12 19:42:26 2012 (50C92472)
fffff880`05c38000 fffff880`05c54000   intelppm intelppm.sys Mon Nov 05 22:55:02 2012 (50988A16)
fffff880`01200000 fffff880`01239000   Ironx64  Ironx64.SYS  Mon Jul 23 20:34:50 2012 (500DEDAA)
fffff880`06cfa000 fffff880`06d09000   kbdclass kbdclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff880`06ced000 fffff880`06cfa000   kbdhid   kbdhid.sys   Wed Jul 25 22:28:49 2012 (5010AB61)
fffff803`279da000 fffff803`279e3000   kd       kd.dll       Wed Jul 25 22:30:34 2012 (5010ABCA)
fffff880`0470c000 fffff880`04717000   kdnic    kdnic.sys    Wed Jul 25 22:27:41 2012 (5010AB1D)
fffff880`04782000 fffff880`047d1000   ks       ks.sys       Sat Feb 02 02:25:50 2013 (510CBF7E)
fffff880`01600000 fffff880`0161b000   ksecdd   ksecdd.sys   Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`01a6f000 fffff880`01a9e000   ksecpkg  ksecpkg.sys  Thu Oct 11 01:16:46 2012 (5076563E)
fffff880`05ca7000 fffff880`05cac380   ksthunk  ksthunk.sys  Wed Jul 25 22:28:58 2012 (5010AB6A)
fffff880`06d73000 fffff880`06d87000   lltdio   lltdio.sys   Wed Jul 25 22:24:02 2012 (5010AA42)
fffff880`06d32000 fffff880`06d5a000   luafv    luafv.sys    Wed Jul 25 22:29:13 2012 (5010AB79)
fffff880`00d07000 fffff880`00d66000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Wed Jul 25 22:30:12 2012 (5010ABB4)
fffff880`06d24000 fffff880`06d32000   monitor  monitor.sys  Thu Feb 28 23:56:18 2013 (513034F2)
fffff880`06d15000 fffff880`06d24000   mouclass mouclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff880`06d09000 fffff880`06d15000   mouhid   mouhid.sys   Fri Mar 01 21:15:53 2013 (513160D9)
fffff880`011da000 fffff880`011f4000   mountmgr mountmgr.sys Wed Jul 25 22:29:33 2012 (5010AB8D)
fffff880`1a790000 fffff880`1a7a7000   mpsdrv   mpsdrv.sys   Thu Oct 11 01:15:15 2012 (507655E3)
fffff880`1a600000 fffff880`1a663000   mrxsmb   mrxsmb.sys   Tue Feb 05 17:29:08 2013 (511187B4)
fffff880`1a7a7000 fffff880`1a7f2000   mrxsmb10 mrxsmb10.sys Wed Jul 25 22:23:06 2012 (5010AA0A)
fffff880`043bb000 fffff880`043f6000   mrxsmb20 mrxsmb20.sys Tue Feb 05 17:28:36 2013 (51118794)
fffff880`039f0000 fffff880`039fc000   Msfs     Msfs.SYS     Wed Jul 25 22:30:24 2012 (5010ABC0)
fffff880`00ea6000 fffff880`00eb0000   msisadrv msisadrv.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`00c89000 fffff880`00cec000   msrpc    msrpc.sys    Wed Jul 25 22:28:37 2012 (5010AB55)
fffff880`03eda000 fffff880`03ee6000   mssmbios mssmbios.sys Wed Jul 25 22:29:19 2012 (5010AB7F)
fffff880`01fc5000 fffff880`01fdc000   mup      mup.sys      Wed Jul 25 22:30:00 2012 (5010ABA8)
fffff880`01ad1000 fffff880`01bca000   ndis     ndis.sys     Sat Feb 02 02:23:49 2013 (510CBF05)
fffff880`04660000 fffff880`0466c000   ndistapi ndistapi.sys Thu Sep 20 02:09:19 2012 (505AB30F)
fffff880`06800000 fffff880`06814000   ndisuio  ndisuio.sys  Wed Jul 25 22:26:21 2012 (5010AACD)
fffff880`0466c000 fffff880`0469b000   ndiswan  ndiswan.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`04a7b000 fffff880`04a8f000   NDProxy  NDProxy.SYS  Mon Apr 08 22:33:41 2013 (51637E05)
fffff880`03fe3000 fffff880`03fff000   Ndu      Ndu.sys      Wed Jul 25 22:23:41 2012 (5010AA2D)
fffff880`03a16000 fffff880`03a26000   netbios  netbios.sys  Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`03adb000 fffff880`03b33000   netbt    netbt.sys    Wed Jul 25 22:24:26 2012 (5010AA5A)
fffff880`01a00000 fffff880`01a6f000   NETIO    NETIO.SYS    Thu Oct 11 01:16:20 2012 (50765624)
fffff880`0385f000 fffff880`03871000   Npfs     Npfs.SYS     Wed Jul 25 22:30:26 2012 (5010ABC2)
fffff880`03ece000 fffff880`03eda000   npsvctrig npsvctrig.sys Wed Jul 25 22:27:33 2012 (5010AB15)
fffff880`03ec0000 fffff880`03ece000   nsiproxy nsiproxy.sys Wed Jul 25 22:25:00 2012 (5010AA7C)
fffff803`2881c000 fffff803`28f68000   nt       ntkrnlmp.exe Wed Apr 10 18:18:57 2013 (5165E551)
fffff880`01812000 fffff880`019f5000   Ntfs     Ntfs.sys     Sat Feb 02 02:25:09 2013 (510CBF55)
fffff880`01fdc000 fffff880`01fe5000   Null     Null.SYS     Wed Jul 25 22:30:16 2012 (5010ABB8)
fffff880`04388000 fffff880`043bb000   nvhda64v nvhda64v.sys Mon Feb 25 00:27:35 2013 (512AF647)
fffff880`04aa3000 fffff880`05582000   nvlddmkm nvlddmkm.sys Tue May 07 16:51:05 2013 (51896939)
fffff880`06d87000 fffff880`06df5000   nwifi    nwifi.sys    Wed Jul 25 22:25:11 2012 (5010AA87)
fffff880`03bc5000 fffff880`03bef000   pacer    pacer.sys    Wed Jul 25 22:23:05 2012 (5010AA09)
fffff880`00f11000 fffff880`00f2b000   partmgr  partmgr.sys  Tue Jan 08 23:01:42 2013 (50ECEBA6)
fffff880`00eb0000 fffff880`00eed000   pci      pci.sys      Wed Jul 25 22:27:43 2012 (5010AB1F)
fffff880`012cd000 fffff880`012dc000   PCIIDEX  PCIIDEX.SYS  Wed Jul 25 22:29:09 2012 (5010AB75)
fffff880`0161b000 fffff880`0162c000   pcw      pcw.sys      Wed Jul 25 22:28:44 2012 (5010AB5C)
fffff880`00efa000 fffff880`00f11000   pdc      pdc.sys      Thu Feb 28 23:58:34 2013 (5130357A)
fffff880`1b6b8000 fffff880`1b784000   peauth   peauth.sys   Mon Apr 08 22:32:01 2013 (51637DA1)
fffff880`03f98000 fffff880`03fe3000   portcls  portcls.sys  Thu Oct 11 01:16:51 2012 (50765643)
fffff880`00de5000 fffff880`00dfa000   PSHED    PSHED.dll    Thu Jul 26 00:53:53 2012 (5010CD61)
fffff880`05c75000 fffff880`05c9a000   rasl2tp  rasl2tp.sys  Wed Jul 25 22:23:16 2012 (5010AA14)
fffff880`05629000 fffff880`05643000   raspppoe raspppoe.sys Wed Jul 25 22:24:55 2012 (5010AA77)
fffff880`05c54000 fffff880`05c75000   raspptp  raspptp.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`0469b000 fffff880`046b9000   rassstp  rassstp.sys  Wed Jul 25 22:23:59 2012 (5010AA3F)
fffff880`03a26000 fffff880`03a98000   rdbss    rdbss.sys    Wed Jul 25 22:25:57 2012 (5010AAB5)
fffff880`05c9c000 fffff880`05ca7000   rdpbus   rdpbus.sys   Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`01c55000 fffff880`01c90000   rdyboost rdyboost.sys Wed Jul 25 22:28:34 2012 (5010AB52)
fffff880`06814000 fffff880`0682c000   rspndr   rspndr.sys   Wed Jul 25 22:24:06 2012 (5010AA46)
fffff880`0682c000 fffff880`06c09b00   RTKVHD64 RTKVHD64.sys Tue Jun 12 06:02:32 2012 (4FD713B8)
fffff880`1b784000 fffff880`1b78f000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`05fec000 fffff880`05ff9000   serenum  serenum.sys  Wed Jul 25 22:30:13 2012 (5010ABB5)
fffff880`05fd4000 fffff880`05fec000   serial   serial.sys   Wed Jul 25 22:30:01 2012 (5010ABA9)
fffff880`00f2b000 fffff880`00f74000   spaceport spaceport.sys Mon Apr 08 22:34:53 2013 (51637E4D)
fffff880`1b2af000 fffff880`1b375000   SRTSP64  SRTSP64.SYS  Fri Jan 25 16:26:16 2013 (5102F878)
fffff880`03eaa000 fffff880`03ec0000   SRTSPX64 SRTSPX64.SYS Fri Jan 25 16:30:05 2013 (5102F95D)
fffff880`1b200000 fffff880`1b28d000   srv      srv.sys      Wed Jul 25 22:25:28 2012 (5010AA98)
fffff880`1b600000 fffff880`1b6a1000   srv2     srv2.sys     Mon Apr 08 22:33:02 2013 (51637DDE)
fffff880`1b78f000 fffff880`1b7d3000   srvnet   srvnet.sys   Mon Apr 08 22:31:13 2013 (51637D71)
fffff880`04729000 fffff880`04782000   sscbfs3  sscbfs3.sys  Tue Oct 30 20:48:28 2012 (5090755C)
fffff880`01034000 fffff880`0104a000   storahci storahci.sys Fri Mar 01 21:15:44 2013 (513160D0)
fffff880`01269000 fffff880`012be000   storport storport.sys Thu Feb 28 23:58:51 2013 (5130358B)
fffff880`05c9a000 fffff880`05c9b480   swenum   swenum.sys   Wed Jul 25 22:28:53 2012 (5010AB65)
fffff880`01356000 fffff880`013d4000   SYMDS64  SYMDS64.SYS  Wed Jan 16 20:56:45 2013 (50F75A5D)
fffff880`016f7000 fffff880`01812000   SYMEFA64 SYMEFA64.SYS Fri Jan 18 19:31:37 2013 (50F9E969)
fffff880`03e72000 fffff880`03eaa000   SYMEVENT64x86 SYMEVENT64x86.SYS Wed May 23 20:52:24 2012 (4FBD8648)
fffff880`03e00000 fffff880`03e72000   SYMNETS  SYMNETS.SYS  Fri Jul 20 22:07:07 2012 (500A0ECB)
fffff880`01c94000 fffff880`01ecc000   tcpip    tcpip.sys    Thu Feb 28 23:57:45 2013 (51303549)
fffff880`1b7d3000 fffff880`1b7e5000   tcpipreg tcpipreg.sys Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`0125b000 fffff880`01269000   TDI      TDI.SYS      Wed Jul 25 22:27:59 2012 (5010AB2F)
fffff880`01239000 fffff880`0125b000   tdx      tdx.sys      Wed Jul 25 22:24:58 2012 (5010AA7A)
fffff880`00dc2000 fffff880`00de5000   tm       tm.sys       Wed Jul 25 22:29:01 2012 (5010AB6D)
fffff960`0071f000 fffff960`00728000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`046d1000 fffff880`046fd000   tunnel   tunnel.sys   Wed Jul 25 22:23:04 2012 (5010AA08)
fffff880`05bbc000 fffff880`05bf4000   ucx01000 ucx01000.sys Thu Sep 20 02:07:54 2012 (505AB2BA)
fffff880`04717000 fffff880`04729000   umbus    umbus.sys    Wed Jul 25 22:27:39 2012 (5010AB1B)
fffff880`1b29a000 fffff880`1b2a4000   umpass   umpass.sys   Wed Jul 25 22:27:36 2012 (5010AB18)
fffff880`06ca2000 fffff880`06cc5000   usbccgp  usbccgp.sys  Wed Jul 25 22:27:06 2012 (5010AAFA)
fffff880`05bf4000 fffff880`05bff000   USBD     USBD.SYS     Thu Sep 20 02:10:20 2012 (505AB34C)
fffff880`05613000 fffff880`05629000   usbehci  usbehci.sys  Thu Sep 20 02:09:27 2012 (505AB317)
fffff880`04400000 fffff880`0447e000   usbhub   usbhub.sys   Sat Feb 02 02:25:14 2013 (510CBF5A)
fffff880`0447e000 fffff880`044f1000   UsbHub3  UsbHub3.sys  Sat Feb 02 02:23:36 2013 (510CBEF8)
fffff880`04a00000 fffff880`04a7b000   USBPORT  USBPORT.SYS  Thu Sep 20 02:09:39 2012 (505AB323)
fffff880`05b65000 fffff880`05bbc000   USBXHCI  USBXHCI.SYS  Fri Mar 01 21:16:03 2013 (513160E3)
fffff880`00eed000 fffff880`00efa000   vdrvroot vdrvroot.sys Wed Jul 25 22:27:29 2012 (5010AB11)
fffff880`00f74000 fffff880`00f8c000   volmgr   volmgr.sys   Wed Jul 25 22:29:22 2012 (5010AB82)
fffff880`00f8c000 fffff880`00fec000   volmgrx  volmgrx.sys  Wed Jul 25 22:29:59 2012 (5010ABA7)
fffff880`01c00000 fffff880`01c55000   volsnap  volsnap.sys  Wed Jul 25 22:30:26 2012 (5010ABC2)
fffff880`05fbb000 fffff880`05fc8000   vwifibus vwifibus.sys Wed Jul 25 22:27:54 2012 (5010AB2A)
fffff880`03a00000 fffff880`03a16000   vwififlt vwififlt.sys Wed Jul 25 22:26:39 2012 (5010AADF)
fffff880`06df5000 fffff880`06dff000   vwifimp  vwifimp.sys  Wed Jul 25 22:26:39 2012 (5010AADF)
fffff880`03f7e000 fffff880`03f98000   wanarp   wanarp.sys   Mon Apr 08 22:31:00 2013 (51637D64)
fffff880`039df000 fffff880`039f0000   watchdog watchdog.sys Wed Jul 25 22:29:05 2012 (5010AB71)
fffff880`0106f000 fffff880`01131000   Wdf01000 Wdf01000.sys Tue Jan 08 22:59:00 2013 (50ECEB04)
fffff880`01131000 fffff880`01141000   WDFLDR   WDFLDR.SYS   Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`01f34000 fffff880`01f4f000   wfplwfs  wfplwfs.sys  Wed Jul 25 22:23:58 2012 (5010AA3E)
fffff960`0003e000 fffff960`0042f000   win32k   win32k.sys   unavailable (00000000)
fffff880`05c2e000 fffff880`05c38000   wmiacpi  wmiacpi.sys  Wed Jul 25 22:29:53 2012 (5010ABA1)
fffff880`011d0000 fffff880`011da000   WMILIB   WMILIB.SYS   Wed Jul 25 22:30:04 2012 (5010ABAC)
fffff880`01158000 fffff880`01163000   WppRecorder WppRecorder.sys Wed Jul 25 22:29:07 2012 (5010AB73)
fffff880`1b2a4000 fffff880`1b2af000   WSDPrint WSDPrint.sys Wed Jul 25 22:29:47 2012 (5010AB9B)
fffff880`06d5a000 fffff880`06d73000   WudfPf   WudfPf.sys   Wed Jul 25 22:26:45 2012 (5010AAE5)
Unloaded modules:
fffff880`1dc57000 fffff880`1dc79000   ENG64.SYS
    Timestamp: unavailable (00000000)
    Checksum:  00000000
    ImageSize:  00022000
fffff880`1da51000 fffff880`1dc57000   EX64.SYS
    Checksum:  00000000
    ImageSize:  00206000
fffff880`01aba000 fffff880`01ac7000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`01bca000 fffff880`01be0000   dump_storahc
    Checksum:  00000000
    ImageSize:  00016000
fffff880`01be0000 fffff880`01bf4000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00014000
fffff880`04376000 fffff880`04388000   dam.sys
    Checksum:  00000000
    ImageSize:  00012000
fffff880`00e9d000 fffff880`00ea6000   SymELAM.sys
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01fdc000 fffff880`01fe8000   hwpolicy.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`00cfa000 fffff880`00d07000   ApiSetSchema
    Checksum:  00000000
    ImageSize:  0000D000
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
Here are the files after running Driver Verifier.
    Custom Build
    Intel Core i5-3570K
    ASUS P8Z77-V
    On board
    ASUS VS228H-P 22.5"
    Chrome
    K9 Internet Filter
usasma
Mr. Cranky Pants
5,139
Probably caused by : AsUpIO.sys ( AsUpIO+18c8 )
Please remove Asus PCProbe. If it's not installed, then remove Asus AISuite (which is installed).
Don't forget to turn Driver Verifier off. To do this, open up verifier.exe and select "Delete existing settings", click on "Finish" and then reboot to let the settings take effect. (if BSOD's continue, turn it back on).
Don't forget the hardware diagnostics also. They're not as essential, but will become necessary if the BSOD's continue.
Loading Dump File [C:\Users\Owner\Downloads\053113-29031-01.dmp]
Machine Name:
Kernel base = 0xfffff802`f0211000 PsLoadedModuleList = 0xfffff802`f04dda20
Debug session time: Fri May 31 14:15:27.035 2013 (UTC - 4:00)
System Uptime: 0 days 0:03:31.764
BugCheck C4, {f6, 17c, fffffa8008f52940, fffff88003bd98c8}
*** WARNING: Unable to verify timestamp for AsUpIO.sys
*** ERROR: Module load completed but symbols could not be loaded for AsUpIO.sys
0: kd> !analyze -v; lmtsmn; !sysinfo cpuspeed; !sysinfo SMBIOS
DRIVER_VERIFIER_DETECTED_VIOLATION (c4)
A device driver attempting to corrupt the system has been caught.  This is
because the driver was specified in the registry as being suspect (by the
administrator) and the kernel has enabled substantial checking of this driver.
If the driver attempts to corrupt the system, bugchecks 0xC4, 0xC1 and 0xA will
be among the most commonly seen crashes.
Arguments:
Arg1: 00000000000000f6, Referencing user handle as KernelMode.
Arg2: 000000000000017c, Handle value being referenced.
Arg3: fffffa8008f52940, Address of the current process.
Arg4: fffff88003bd98c8, Address inside the driver that is performing the incorrect reference.
Debugging Details:
BUGCHECK_STR:  0xc4_f6
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
PROCESS_NAME:  €
CURRENT_IRQL:  1b
LAST_CONTROL_TRANSFER:  from fffff802f085b1ac to fffff802f026b440
STACK_TEXT:
fffff880`039c0148 fffff802`f085b1ac : 00000000`000000c4 00000000`000000f6 00000000`0000017c fffffa80`08f52940 : nt!KeBugCheckEx
fffff880`039c0150 fffff802`f0862c88 : fffffa80`08f52940 00000000`00000000 00000000`00000000 00000000`00000000 : nt!VerifierBugCheckIfAppropriate+0x3c
fffff880`039c0190 fffff802`f080ebd5 : 00000000`00000000 00000000`00000000 fffff880`039c0520 00000000`00000000 : nt!VfCheckUserHandle+0x1b8
fffff880`039c0270 fffff802`f0643cc5 : 00000000`00f80000 00000000`00000002 fffffa80`06b0b9e0 fffff880`039c0700 : nt! ?? ::NNGAKEGL::`string'+0x3af24
fffff880`039c0300 fffff802`f0687ca2 : fffff880`039c0300 fffff802`00000008 fffffa80`06b20890 00000000`00000000 : nt!ObReferenceObjectByHandle+0x25
fffff880`039c0350 fffff802`f026a453 : 00000000`0000017c ffffffff`ffffffff 00000000`00000003 fffff880`039c0400 : nt!NtMapViewOfSection+0x211
fffff880`039c0430 fffff802`f026f630 : fffff802`f087069a fffff880`03bd9736 fffff880`039c0b00 fffff880`039c0738 : nt!KiSystemServiceCopyEnd+0x13
fffff880`039c0638 fffff802`f087069a : fffff880`03bd9736 fffff880`039c0b00 fffff880`039c0738 00000000`00000000 : nt!KiServiceLinkage
fffff880`039c0640 fffff880`03bd98c8 : 00000000`00000000 fffffa80`0a93b9a0 00000000`00000001 fffff980`50f84fe0 : nt!VfZwMapViewOfSection+0xb2
fffff880`039c06b0 00000000`00000000 : fffffa80`0a93b9a0 00000000`00000001 fffff980`50f84fe0 00000000`007f0000 : AsUpIO+0x18c8
STACK_COMMAND:  kb
FOLLOWUP_IP:
AsUpIO+18c8
fffff880`03bd98c8 8bd8            mov     ebx,eax
SYMBOL_STACK_INDEX:  9
SYMBOL_NAME:  AsUpIO+18c8
MODULE_NAME: AsUpIO
IMAGE_NAME:  AsUpIO.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4c57835f
FAILURE_BUCKET_ID:  0xc4_f6_VRF_AsUpIO+18c8
fffff880`00e02000 fffff880`00e6f000   ACPI     ACPI.sys     Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`01190000 fffff880`011a7000   acpiex   acpiex.sys   Wed Jul 25 22:25:57 2012 (5010AAB5)
fffff880`0435c000 fffff880`043ee000   afd      afd.sys      Mon Nov 05 22:53:42 2012 (509889C6)
fffff880`03a4d000 fffff880`03a65000   AgileVpn AgileVpn.sys Wed Jul 25 22:23:11 2012 (5010AA0F)
fffff880`0635e000 fffff880`06385000   AnyDVD   AnyDVD.sys   Thu Apr 25 09:44:29 2013 (5179333D)
fffff880`0133e000 fffff880`0134d000   asahci64 asahci64.sys Thu Jan 05 00:08:19 2012 (4F053043)
fffff880`03bdf000 fffff880`03be5000   AsIO     AsIO.sys     Wed Aug 22 05:54:47 2012 (5034AC67)
fffff880`03bd8000 fffff880`03bdf000   AsUpIO   AsUpIO.sys   Mon Aug 02 22:47:59 2010 (4C57835F)
fffff880`01295000 fffff880`0129f000   atapi    atapi.sys    Wed Jul 25 22:30:33 2012 (5010ABC9)
fffff880`0129f000 fffff880`012d3000   ataport  ataport.SYS  Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`06059000 fffff880`0632c000   athrx    athrx.sys    Wed Mar 21 23:26:22 2012 (4F6A9BDE)
fffff880`042a5000 fffff880`042b6000   BasicDisplay BasicDisplay.sys Wed Jul 25 22:29:08 2012 (5010AB74)
fffff880`021b9000 fffff880`021c6000   BasicRender BasicRender.sys Wed Jul 25 22:28:51 2012 (5010AB63)
fffff880`1b0c5000 fffff880`1b0e6000   bckd     bckd.sys     Fri Mar 01 06:20:57 2013 (51308F19)
fffff880`021b1000 fffff880`021b9000   Beep     Beep.SYS     Wed Jul 25 22:30:19 2012 (5010ABBB)
fffff880`03a81000 fffff880`03bd8000   BHDrvx64 BHDrvx64.sys Wed Apr 10 01:39:03 2013 (5164FAF7)
fffff880`00dad000 fffff880`00db7000   BOOTVID  BOOTVID.dll  Wed Jul 25 22:30:22 2012 (5010ABBE)
fffff880`1b1d9000 fffff880`1b1f9000   bowser   bowser.sys   Wed Jul 25 22:28:01 2012 (5010AB31)
fffff880`02141000 fffff880`0216f000   ccSetx64 ccSetx64.sys Thu Aug 16 17:18:11 2012 (502D6393)
fffff960`00840000 fffff960`00876000   cdd      cdd.dll      Thu Jul 26 00:49:37 2012 (5010CC61)
fffff880`02110000 fffff880`02141000   cdrom    cdrom.sys    Wed Jul 25 22:26:36 2012 (5010AADC)
fffff880`00c00000 fffff880`00c7f000   CI       CI.dll       Wed Mar 27 23:30:42 2013 (5153B962)
fffff880`02071000 fffff880`020c5000   CLASSPNP CLASSPNP.SYS Thu Feb 28 23:59:20 2013 (513035A8)
fffff880`00d19000 fffff880`00d75000   CLFS     CLFS.SYS     Wed Jul 25 22:29:39 2012 (5010AB93)
fffff880`00e79000 fffff880`00f05000   cng      cng.sys      Thu Oct 11 01:17:34 2012 (5076566E)
fffff880`03a65000 fffff880`03a74000   CompositeBus CompositeBus.sys Wed Jul 25 22:28:03 2012 (5010AB33)
fffff880`1cfd3000 fffff880`1cfe0000   condrv   condrv.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`020c5000 fffff880`020d9000   crashdmp crashdmp.sys Sat Feb 02 02:26:00 2013 (510CBF88)
fffff880`03cbe000 fffff880`03d4f000   csc      csc.sys      Thu Sep 20 02:08:29 2012 (505AB2DD)
fffff880`045d2000 fffff880`045f3000   dfsc     dfsc.sys     Wed Jul 25 22:26:53 2012 (5010AAED)
fffff880`045c1000 fffff880`045d2000   discache discache.sys Wed Jul 25 22:28:23 2012 (5010AB47)
fffff880`0162f000 fffff880`0164b000   disk     disk.sys     Wed Jul 25 22:29:25 2012 (5010AB85)
fffff880`06400000 fffff880`06422000   drmk     drmk.sys     Thu Oct 11 01:18:59 2012 (507656C3)
fffff880`06f65000 fffff880`06f72000   dump_diskdump dump_diskdump.sys Wed Jul 25 22:29:58 2012 (5010ABA6)
fffff880`06f88000 fffff880`06f9c000   dump_dumpfve dump_dumpfve.sys Thu Sep 20 02:09:30 2012 (505AB31A)
fffff880`06f72000 fffff880`06f88000   dump_storahci dump_storahci.sys Fri Mar 01 21:15:44 2013 (513160D0)
fffff880`040dd000 fffff880`04246000   dxgkrnl  dxgkrnl.sys  Sat Apr 13 01:09:52 2013 (5168E8A0)
fffff880`04257000 fffff880`042a5000   dxgmms1  dxgmms1.sys  Tue Jan 08 22:58:58 2013 (50ECEB02)
fffff880`05d4c000 fffff880`05da2000   e1i63x64 e1i63x64.sys Wed Feb 29 22:25:14 2012 (4F4EEC1A)
fffff880`04521000 fffff880`0459b000   eeCtrl64 eeCtrl64.sys Tue Jul 31 19:36:51 2012 (50186C13)
fffff880`0135c000 fffff880`01376000   EhStorClass EhStorClass.sys Wed Jul 25 22:26:24 2012 (5010AAD0)
fffff880`04515000 fffff880`04521000   ElbyCDIO ElbyCDIO.sys Mon Mar 04 04:21:51 2013 (513467AF)
fffff880`0459b000 fffff880`045c1000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Tue Jul 31 19:36:50 2012 (50186C12)
fffff880`05d15000 fffff880`05d4c000   fastfat  fastfat.SYS  Wed Jul 25 22:30:23 2012 (5010ABBF)
fffff880`014ab000 fffff880`014bf000   fileinfo fileinfo.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`01376000 fffff880`013d6000   fltmgr   fltmgr.sys   Wed Jul 25 22:30:09 2012 (5010ABB1)
fffff880`01862000 fffff880`0186c000   Fs_Rec   Fs_Rec.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`01ed1000 fffff880`01f47000   fvevol   fvevol.sys   Thu Sep 20 02:08:15 2012 (505AB2CF)
fffff880`01e4e000 fffff880`01eb6000   fwpkclnt fwpkclnt.sys Thu Feb 28 23:55:54 2013 (513034DA)
fffff880`06385000 fffff880`0638bc00   GEARAspiWDM GEARAspiWDM.sys Thu May 03 15:56:17 2012 (4FA2E2E1)
fffff802`f095d000 fffff802`f09c9000   hal      hal.dll      Tue Oct 23 23:03:21 2012 (50875A79)
fffff880`05cff000 fffff880`05d15000   HDAudBus HDAudBus.sys Thu Sep 20 02:08:43 2012 (505AB2EB)
fffff880`06e82000 fffff880`06edb000   HdAudio  HdAudio.sys  Tue Jan 08 22:59:46 2013 (50ECEB32)
fffff880`04fb6000 fffff880`04fc9000   HECIx64  HECIx64.sys  Mon Jul 02 18:14:58 2012 (4FF21D62)
fffff880`06f0b000 fffff880`06f26000   HIDCLASS HIDCLASS.SYS Mon Apr 08 22:34:48 2013 (51637E48)
fffff880`06f26000 fffff880`06f2e000   HIDPARSE HIDPARSE.SYS Wed Jul 25 22:30:15 2012 (5010ABB7)
fffff880`06efe000 fffff880`06f0b000   hidusb   hidusb.sys   Mon Apr 08 22:34:41 2013 (51637E41)
fffff880`1b0fa000 fffff880`1b1d9000   HTTP     HTTP.sys     Thu Mar 14 20:17:15 2013 (5142688B)
fffff880`04493000 fffff880`04515000   IDSvia64 IDSvia64.sys Tue Aug 28 22:48:40 2012 (503D8308)
fffff880`04a0b000 fffff880`04f261a0   igdkmd64 igdkmd64.sys Wed Dec 12 19:42:26 2012 (50C92472)
fffff880`06396000 fffff880`063b2000   intelppm intelppm.sys Mon Nov 05 22:55:02 2012 (50988A16)
fffff880`0216f000 fffff880`021a8000   Ironx64  Ironx64.SYS  Mon Jul 23 20:34:50 2012 (500DEDAA)
fffff880`06f3b000 fffff880`06f4a000   kbdclass kbdclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff880`06f2e000 fffff880`06f3b000   kbdhid   kbdhid.sys   Wed Jul 25 22:28:49 2012 (5010AB61)
fffff802`ef349000 fffff802`ef352000   kd       kd.dll       Wed Jul 25 22:30:34 2012 (5010ABCA)
fffff880`03a74000 fffff880`03a7f000   kdnic    kdnic.sys    Wed Jul 25 22:27:41 2012 (5010AB1D)
fffff880`05f52000 fffff880`05fa1000   ks       ks.sys       Sat Feb 02 02:25:50 2013 (510CBF7E)
fffff880`01836000 fffff880`01851000   ksecdd   ksecdd.sys   Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`01600000 fffff880`0162f000   ksecpkg  ksecpkg.sys  Thu Oct 11 01:16:46 2012 (5076563E)
fffff880`06422000 fffff880`06427380   ksthunk  ksthunk.sys  Wed Jul 25 22:28:58 2012 (5010AB6A)
fffff880`06feb000 fffff880`06fff000   lltdio   lltdio.sys   Wed Jul 25 22:24:02 2012 (5010AA42)
fffff880`06faa000 fffff880`06fd2000   luafv    luafv.sys    Wed Jul 25 22:29:13 2012 (5010AB79)
fffff880`00cba000 fffff880`00d19000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Wed Jul 25 22:30:12 2012 (5010ABB4)
fffff880`06f9c000 fffff880`06faa000   monitor  monitor.sys  Thu Feb 28 23:56:18 2013 (513034F2)
fffff880`06f56000 fffff880`06f65000   mouclass mouclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff880`06f4a000 fffff880`06f56000   mouhid   mouhid.sys   Fri Mar 01 21:15:53 2013 (513160D9)
fffff880`0127b000 fffff880`01295000   mountmgr mountmgr.sys Wed Jul 25 22:29:33 2012 (5010AB8D)
fffff880`1b000000 fffff880`1b017000   mpsdrv   mpsdrv.sys   Thu Oct 11 01:15:15 2012 (507655E3)
fffff880`1b017000 fffff880`1b07a000   mrxsmb   mrxsmb.sys   Tue Feb 05 17:29:08 2013 (511187B4)
fffff880`1b07a000 fffff880`1b0c5000   mrxsmb10 mrxsmb10.sys Wed Jul 25 22:23:06 2012 (5010AA0A)
fffff880`06428000 fffff880`06463000   mrxsmb20 mrxsmb20.sys Tue Feb 05 17:28:36 2013 (51118794)
fffff880`042c8000 fffff880`042d4000   Msfs     Msfs.SYS     Wed Jul 25 22:30:24 2012 (5010ABC0)
fffff880`00f0e000 fffff880`00f18000   msisadrv msisadrv.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`010e7000 fffff880`0114a000   msrpc    msrpc.sys    Wed Jul 25 22:28:37 2012 (5010AB55)
fffff880`03c68000 fffff880`03c74000   mssmbios mssmbios.sys Wed Jul 25 22:29:19 2012 (5010AB7F)
fffff880`01fd7000 fffff880`01fee000   mup      mup.sys      Wed Jul 25 22:30:00 2012 (5010ABA8)
fffff880`0186c000 fffff880`01965000   ndis     ndis.sys     Sat Feb 02 02:23:49 2013 (510CBF05)
fffff880`03be5000 fffff880`03bf1000   ndistapi ndistapi.sys Thu Sep 20 02:09:19 2012 (505AB30F)
fffff880`06a6e000 fffff880`06a82000   ndisuio  ndisuio.sys  Wed Jul 25 22:26:21 2012 (5010AACD)
fffff880`03a00000 fffff880`03a2f000   ndiswan  ndiswan.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`05fac000 fffff880`05fc0000   NDProxy  NDProxy.SYS  Mon Apr 08 22:33:41 2013 (51637E05)
fffff880`06463000 fffff880`0647f000   Ndu      Ndu.sys      Wed Jul 25 22:23:41 2012 (5010AA2D)
fffff880`04040000 fffff880`04050000   netbios  netbios.sys  Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`04304000 fffff880`0435c000   netbt    netbt.sys    Wed Jul 25 22:24:26 2012 (5010AA5A)
fffff880`01965000 fffff880`019d4000   NETIO    NETIO.SYS    Thu Oct 11 01:16:20 2012 (50765624)
fffff880`042b6000 fffff880`042c8000   Npfs     Npfs.SYS     Wed Jul 25 22:30:26 2012 (5010ABC2)
fffff880`03c5c000 fffff880`03c68000   npsvctrig npsvctrig.sys Wed Jul 25 22:27:33 2012 (5010AB15)
fffff880`03c4e000 fffff880`03c5c000   nsiproxy nsiproxy.sys Wed Jul 25 22:25:00 2012 (5010AA7C)
fffff802`f0211000 fffff802`f095d000   nt       ntkrnlmp.exe Wed Apr 10 18:18:57 2013 (5165E551)
fffff880`01653000 fffff880`01836000   Ntfs     Ntfs.sys     Sat Feb 02 02:25:09 2013 (510CBF55)
fffff880`021a8000 fffff880`021b1000   Null     Null.SYS     Wed Jul 25 22:30:16 2012 (5010ABB8)
fffff880`06564000 fffff880`06597000   nvhda64v nvhda64v.sys Mon Feb 25 00:27:35 2013 (512AF647)
fffff880`0521e000 fffff880`05cff000   nvlddmkm nvlddmkm.sys Sun May 12 15:09:45 2013 (518FE8F9)
fffff880`06a00000 fffff880`06a6e000   nwifi    nwifi.sys    Wed Jul 25 22:25:11 2012 (5010AA87)
fffff880`04000000 fffff880`0402a000   pacer    pacer.sys    Wed Jul 25 22:23:05 2012 (5010AA09)
fffff880`00f79000 fffff880`00f93000   partmgr  partmgr.sys  Tue Jan 08 23:01:42 2013 (50ECEBA6)
fffff880`00f18000 fffff880`00f55000   pci      pci.sys      Wed Jul 25 22:27:43 2012 (5010AB1F)
fffff880`0134d000 fffff880`0135c000   PCIIDEX  PCIIDEX.SYS  Wed Jul 25 22:29:09 2012 (5010AB75)
fffff880`01851000 fffff880`01862000   pcw      pcw.sys      Wed Jul 25 22:28:44 2012 (5010AB5C)
fffff880`00f62000 fffff880`00f79000   pdc      pdc.sys      Thu Feb 28 23:58:34 2013 (5130357A)
fffff880`1cc8c000 fffff880`1cd58000   peauth   peauth.sys   Mon Apr 08 22:32:01 2013 (51637DA1)
fffff880`06597000 fffff880`065e2000   portcls  portcls.sys  Thu Oct 11 01:16:51 2012 (50765643)
fffff880`00d98000 fffff880`00dad000   PSHED    PSHED.dll    Thu Jul 26 00:53:53 2012 (5010CD61)
fffff880`063d3000 fffff880`063f8000   rasl2tp  rasl2tp.sys  Wed Jul 25 22:23:16 2012 (5010AA14)
fffff880`05f38000 fffff880`05f52000   raspppoe raspppoe.sys Wed Jul 25 22:24:55 2012 (5010AA77)
fffff880`063b2000 fffff880`063d3000   raspptp  raspptp.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`03a2f000 fffff880`03a4d000   rassstp  rassstp.sys  Wed Jul 25 22:23:59 2012 (5010AA3F)
fffff880`04050000 fffff880`040c2000   rdbss    rdbss.sys    Wed Jul 25 22:25:57 2012 (5010AAB5)
fffff880`05fa1000 fffff880`05fac000   rdpbus   rdpbus.sys   Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`01f9c000 fffff880`01fd7000   rdyboost rdyboost.sys Wed Jul 25 22:28:34 2012 (5010AB52)
fffff880`06a82000 fffff880`06a9a000   rspndr   rspndr.sys   Wed Jul 25 22:24:06 2012 (5010AA46)
fffff880`06aa4000 fffff880`06e81b00   RTKVHD64 RTKVHD64.sys Tue Jun 12 06:02:32 2012 (4FD713B8)
fffff880`1cd58000 fffff880`1cd63000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`06351000 fffff880`0635e000   serenum  serenum.sys  Wed Jul 25 22:30:13 2012 (5010ABB5)
fffff880`06339000 fffff880`06351000   serial   serial.sys   Wed Jul 25 22:30:01 2012 (5010ABA9)
fffff880`00f93000 fffff880`00fdc000   spaceport spaceport.sys Mon Apr 08 22:34:53 2013 (51637E4D)
fffff880`03c38000 fffff880`03c4e000   SRTSPX64 SRTSPX64.SYS Fri Jan 25 16:30:05 2013 (5102F95D)
fffff880`1cf46000 fffff880`1cfd3000   srv      srv.sys      Wed Jul 25 22:25:28 2012 (5010AA98)
fffff880`1cea5000 fffff880`1cf46000   srv2     srv2.sys     Mon Apr 08 22:33:02 2013 (51637DDE)
fffff880`1cd63000 fffff880`1cda7000   srvnet   srvnet.sys   Mon Apr 08 22:31:13 2013 (51637D71)
fffff880`06000000 fffff880`06059000   sscbfs3  sscbfs3.sys  Tue Oct 30 20:48:28 2012 (5090755C)
fffff880`012d3000 fffff880`012e9000   storahci storahci.sys Fri Mar 01 21:15:44 2013 (513160D0)
fffff880`012e9000 fffff880`0133e000   storport storport.sys Thu Feb 28 23:58:51 2013 (5130358B)
fffff880`063f8000 fffff880`063f9480   swenum   swenum.sys   Wed Jul 25 22:28:53 2012 (5010AB65)
fffff880`0142d000 fffff880`014ab000   SYMDS64  SYMDS64.SYS  Wed Jan 16 20:56:45 2013 (50F75A5D)
fffff880`014bf000 fffff880`015da000   SYMEFA64 SYMEFA64.SYS Fri Jan 18 19:31:37 2013 (50F9E969)
fffff880`03c00000 fffff880`03c38000   SYMEVENT64x86 SYMEVENT64x86.SYS Wed May 23 20:52:24 2012 (4FBD8648)
fffff880`03d69000 fffff880`03ddb000   SYMNETS  SYMNETS.SYS  Fri Jul 20 22:07:07 2012 (500A0ECB)
fffff880`01c16000 fffff880`01e4e000   tcpip    tcpip.sys    Thu Feb 28 23:57:45 2013 (51303549)
fffff880`1cda7000 fffff880`1cdb9000   tcpipreg tcpipreg.sys Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`042f6000 fffff880`04304000   TDI      TDI.SYS      Wed Jul 25 22:27:59 2012 (5010AB2F)
fffff880`042d4000 fffff880`042f6000   tdx      tdx.sys      Wed Jul 25 22:24:58 2012 (5010AA7A)
fffff880`00d75000 fffff880`00d98000   tm       tm.sys       Wed Jul 25 22:29:01 2012 (5010AB6D)
fffff960`00676000 fffff960`0067f000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04412000 fffff880`0443e000   tunnel   tunnel.sys   Wed Jul 25 22:23:04 2012 (5010AA08)
fffff880`04f7e000 fffff880`04fb6000   ucx01000 ucx01000.sys Thu Sep 20 02:07:54 2012 (505AB2BA)
fffff880`0443e000 fffff880`04450000   umbus    umbus.sys    Wed Jul 25 22:27:39 2012 (5010AB1B)
fffff880`1cfe0000 fffff880`1cfea000   umpass   umpass.sys   Wed Jul 25 22:27:36 2012 (5010AB18)
fffff880`06edb000 fffff880`06efe000   usbccgp  usbccgp.sys  Wed Jul 25 22:27:06 2012 (5010AAFA)
fffff880`05e7e000 fffff880`05e89000   USBD     USBD.SYS     Thu Sep 20 02:10:20 2012 (505AB34C)
fffff880`04fc9000 fffff880`04fdf000   usbehci  usbehci.sys  Thu Sep 20 02:09:27 2012 (505AB317)
fffff880`05e00000 fffff880`05e7e000   usbhub   usbhub.sys   Sat Feb 02 02:25:14 2013 (510CBF5A)
fffff880`064f1000 fffff880`06564000   UsbHub3  UsbHub3.sys  Sat Feb 02 02:23:36 2013 (510CBEF8)
fffff880`05ebd000 fffff880`05f38000   USBPORT  USBPORT.SYS  Thu Sep 20 02:09:39 2012 (505AB323)
fffff880`04f27000 fffff880`04f7e000   USBXHCI  USBXHCI.SYS  Fri Mar 01 21:16:03 2013 (513160E3)
fffff880`00f55000 fffff880`00f62000   vdrvroot vdrvroot.sys Wed Jul 25 22:27:29 2012 (5010AB11)
fffff880`0114a000 fffff880`01190000   VerifierExt VerifierExt.sys Wed Jul 25 22:28:18 2012 (5010AB42)
fffff880`00fdc000 fffff880`00ff4000   volmgr   volmgr.sys   Wed Jul 25 22:29:22 2012 (5010AB82)
fffff880`0121b000 fffff880`0127b000   volmgrx  volmgrx.sys  Wed Jul 25 22:29:59 2012 (5010ABA7)
fffff880`01f47000 fffff880`01f9c000   volsnap  volsnap.sys  Wed Jul 25 22:30:26 2012 (5010ABC2)
fffff880`0632c000 fffff880`06339000   vwifibus vwifibus.sys Wed Jul 25 22:27:54 2012 (5010AB2A)
fffff880`0402a000 fffff880`04040000   vwififlt vwififlt.sys Wed Jul 25 22:26:39 2012 (5010AADF)
fffff880`06a9a000 fffff880`06aa4000   vwifimp  vwifimp.sys  Wed Jul 25 22:26:39 2012 (5010AADF)
fffff880`03d4f000 fffff880`03d69000   wanarp   wanarp.sys   Mon Apr 08 22:31:00 2013 (51637D64)
fffff880`04246000 fffff880`04257000   watchdog watchdog.sys Wed Jul 25 22:29:05 2012 (5010AB71)
fffff880`01000000 fffff880`010c2000   Wdf01000 Wdf01000.sys Tue Jan 08 22:59:00 2013 (50ECEB04)
fffff880`010c2000 fffff880`010d2000   WDFLDR   WDFLDR.SYS   Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`01eb6000 fffff880`01ed1000   wfplwfs  wfplwfs.sys  Wed Jul 25 22:23:58 2012 (5010AA3E)
fffff960`00063000 fffff960`00454000   win32k   win32k.sys   Mon Apr 08 22:34:32 2013 (51637E38)
fffff880`0638c000 fffff880`06396000   wmiacpi  wmiacpi.sys  Wed Jul 25 22:29:53 2012 (5010ABA1)
fffff880`00e6f000 fffff880`00e79000   WMILIB   WMILIB.SYS   Wed Jul 25 22:30:04 2012 (5010ABAC)
fffff880`011a7000 fffff880`011b2000   WppRecorder WppRecorder.sys Wed Jul 25 22:29:07 2012 (5010AB73)
fffff880`1cfea000 fffff880`1cff5000   WSDPrint WSDPrint.sys Wed Jul 25 22:29:47 2012 (5010AB9B)
fffff880`06fd2000 fffff880`06feb000   WudfPf   WudfPf.sys   Wed Jul 25 22:26:45 2012 (5010AAE5)
Unloaded modules:
fffff880`020d9000 fffff880`020e6000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`020e6000 fffff880`020fc000   dump_storahc
    Checksum:  00000000
    ImageSize:  00016000
fffff880`020fc000 fffff880`02110000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00014000
fffff880`04400000 fffff880`04412000   dam.sys
    Checksum:  00000000
    ImageSize:  00012000
fffff880`00f05000 fffff880`00f0e000   SymELAM.sys
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01fee000 fffff880`01ffa000   hwpolicy.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`00cad000 fffff880`00cba000   ApiSetSchema
    Checksum:  00000000
    ImageSize:  0000D000
sysinfo: could not find necessary interfaces.
sysinfo: note that mssmbios.sys must be loaded (XPSP2+).
    Samsung/NP780
    800x600
Thank you for your help. I will let you know if I have anymore problems.
    Custom Build
    Intel Core i5-3570K
    ASUS P8Z77-V
    On board
    ASUS VS228H-P 22.5"
    Chrome
    K9 Internet Filter
