BSOD - error power state failure, dumps attached
datfreak
BSOD - error power state failure 5 mins after resume
Hi, firstly thankyou for helping me with this!
I have a new i3 system for my home theater that crashes after resuming from sleep sometimes(about half the time).
It works for about 5 min after resuming and then crashes.
Ive tried windows updates,latest bios,latest mobo drivers and have disconnected non needed devices.
Soft:
Win 8 pro
classic shell
Mediaportal software
Hard:
Corsair CMX8GX3M2B1600C9 8GB (2x4GB) DDR3
ASUS P8H77-M Motherboard
Intel Core i3 3225
Samsung 840 120GB SSD
2tb WD green drive
HP MCE remote reciever
Wireless keyboard/touchpad (removed)
2 X usb dvb-t tuners - Mobi dual
onboard graphics thru hdmi
Ive attached the files created by SF diag tool.
thankyou for your thoughts
    win8 pro
    asus
    3225 i3
    asus
    8gb
    onboard 4000
datfreak
Updated system info in original post.
    win8 pro
    asus
    3225 i3
    asus
    8gb
    onboard 4000
usasma
Mr. Cranky Pants
If you still need help with this, please reply back. I've been sick and haven't been able to keep up.
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
datfreak
I do still need help - thanku
    win8 pro
    asus
    3225 i3
    asus
    8gb
    onboard 4000
usasma
Mr. Cranky Pants
Ran the last 7 memory dumps.
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website). Be sure to update ALL controllers on the motherboard! I STRONGLY suggest not using controller drivers older than mid-2012 with SSD's.
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: http://www.eightforums.com/bsod-cra...ndows-8-x64-pc-reboots-when-waking-sleep.html
27 Feb 2013 - I'm starting to see much better reliability with SSD's using current (mid-2012 and later) storage drivers. I have withdrawn my objections to using these devices in everyday systems.
I always suspect RAM disk programs (because most BSOD's occur from bad memory operations). Try uninstalling it to see if it helps. If it's not to blame, then feel free to reinstall the latest, Win8 compatible version.
All BSOD's blame af9035bda.sys - I suspect that it's a driver for your USB Tuners. It dates from 2009 so it's probably not compatible with Win8. Please update the driver to a compatible version.
Analysis:
[font=lucida console]**************************Sat Apr 13 02:46:46.738 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041313-4625-01.dmp]
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]3 days 9:43:00.363[/B]
*** ERROR: Module load completed but symbols could not be loaded for usbccgp.sys
Probably caused by :[B]usbccgp.sys[/B]
BugCheck [B]9F, {3, fffffa800aa54370, fffff880009db7e0, fffffa8006ffb320}[/B]
Arguments:
Arg2: fffffa800aa54370, Physical Device Object of the stack
Arg3: fffff880009db7e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8006ffb320, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_3_AF9035BDA_IMAGE_usbccgp.sys[/B]
**************************Tue Apr  9 17:03:27.736 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041013-4843-01.dmp]
System Uptime:[B]2 days 13:49:22.360[/B]
BugCheck [B]9F, {3, fffffa8006a1d930, fffff800c87037e0, fffffa800fe86010}[/B]
Arguments:
Arg2: fffffa8006a1d930, Physical Device Object of the stack
Arg3: fffff800c87037e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800fe86010, The blocked IRP
BUGCHECK_STR:  0x9F
**************************Sun Apr  7 03:13:46.737 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040713-4656-01.dmp]
System Uptime:[B]2 days 23:52:11.364[/B]
BugCheck [B]9F, {3, fffffa800b5ed060, fffff880009db7e0, fffffa80106b25a0}[/B]
Arguments:
Arg2: fffffa800b5ed060, Physical Device Object of the stack
Arg4: fffffa80106b25a0, The blocked IRP
BUGCHECK_STR:  0x9F
**************************Tue Apr  2 20:36:03.728 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040313-4500-01.dmp]
System Uptime:[B]0 days 14:08:43.365[/B]
BugCheck [B]9F, {3, fffffa800b472060, fffff880009db7e0, fffffa800cb14010}[/B]
Arguments:
Arg2: fffffa800b472060, Physical Device Object of the stack
Arg4: fffffa800cb14010, The blocked IRP
BUGCHECK_STR:  0x9F
**************************Sun Mar 31 23:11:01.735 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040113-4296-01.dmp]
System Uptime:[B]2 days 18:45:35.367[/B]
BugCheck [B]9F, {3, fffffa8008d39060, fffff80238c1f7e0, fffffa800ecfd010}[/B]
Arguments:
Arg2: fffffa8008d39060, Physical Device Object of the stack
Arg3: fffff80238c1f7e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800ecfd010, The blocked IRP
BUGCHECK_STR:  0x9F
CPUID:        "Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz"
MaxSpeed:     3300
CurrentSpeed: [B]3300[/B]
  BIOS Version                  0903
  BIOS Release Date             01/16/2013
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
**************************Wed Mar 27 17:32:53.731 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032813-4484-01.dmp]
System Uptime:[B]1 days 12:21:34.360[/B]
BugCheck [B]9F, {3, fffffa800aac82d0, fffff80318f037e0, fffffa800e0a4010}[/B]
Arguments:
Arg2: fffffa800aac82d0, Physical Device Object of the stack
Arg3: fffff80318f037e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800e0a4010, The blocked IRP
BUGCHECK_STR:  0x9F
**************************Tue Mar 26 00:16:23.740 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-4265-01.dmp]
System Uptime:[B]3 days 1:32:25.342[/B]
BugCheck [B]9F, {3, fffffa800add1970, fffff880018877e0, fffffa8011b7f010}[/B]
Arguments:
Arg2: fffffa800add1970, Physical Device Object of the stack
Arg3: fffff880018877e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8011b7f010, The blocked IRP
BUGCHECK_STR:  0x9F
[/font]
3rd Party Drivers:
[COLOR=RED][B]AF9035BDA.sys       Tue Nov  3 01:21:06 2009 (4AEFCBD2)[/B][/COLOR]
IntcDAud.sys        Tue Jun 19 10:40:51 2012 (4FE08F73)
HECIx64.sys         Mon Jul  2 18:14:58 2012 (4FF21D62)
dump_iaStorA.sys    Mon Jul  9 16:42:33 2012 (4FFB4239)
usbcir.sys          Wed Jul 25 22:27:07 2012 (5010AAFB)
Rt630x64.sys        Thu Oct 25 05:14:58 2012 (50890312)
RTKVHD64.sys        Tue Oct 30 05:51:36 2012 (508FA328)
intelppm.sys        Mon Nov  5 22:55:02 2012 (50988A16)
igdkmd64.sys        Wed Nov  7 23:01:47 2012 (509B2EAB)
vv.sys              Wed Nov 21 00:39:42 2012 (50AC691E)
RAMDiskVE.sys       Mon Jan 14 13:36:04 2013 (50F45014)
[/font]
AF9035BDA.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=usbcir.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
vv.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=RAMDiskVE.sys
    Samsung/NP780
    800x600
