Solved bsod DRIVER_POWER_STATE_FAILURE plus sceenshot
Zealot
my laptop randomly reboots when ever i am using my laptop and a blue screen apears with a sad face andDRIVER_POWER_STATE_FAILURE below and reboots and loads up fine like nothing happens
the brand is asus
and the model is # g750jm-sb71-cb
sorry for the vague info first time reporting for an issue if you reqire any more info i will try my best to provide :)
    Windows 8.1 64-bit
    ASUSTeK COMPUTER INC. G750JM
    Intel® Core™ i7 4700HQ Processor
    Intel® HM87 Express Chipset
    16.0GB Dual-Channel DDR3 @ 798MHz
    NVIDIA GeForce GTX 860M
    Realtek High Definition Audio
    1920x1080@60Hz
    1.5 TB Hitachi (SATA)
    razer deathadder
    google chrome
    avast
blueelvis
OMG Debugger!
India
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
Zealot
zip
ok i have the zip uploaded take a look, i hope its nothing serious:)
    Windows 8.1 64-bit
    1920x1080@60Hz
    razer deathadder
    google chrome
    avast
blueelvis
OMG Debugger!
India
Hi Zealot ^_^,
I have analysed your dump files and below has been provided an analysis of the same for informative purposes :-
0: kd> !irp ffffe0002fb35ca0
Irp is active with 6 stacks 4 is current (= 0xffffe0002fb35e48)
 No Mdl: No System Buffer: Thread 00000000:  Irp stack trace.
     cmd  flg cl Device   File     Completion-Context
 [  0, 0]   0  0 00000000 00000000 00000000-00000000
   Args: 00000000 00000000 00000000 00000000
>[ 16, 2]   0 e1 ffffe0002b1f3670 00000000 fffff801a486ffc4-ffffd001eef188f0 Success Error Cancel pending
        \Driver\pci dxgkrnl!DpiFdoPowerCompletionRoutine
   Args: 00000000 00000001 00000001 00000000
 [ 16, 2]   0 e1 ffffe0002f68c1f0 00000000 fffff8025ff9dfd8-ffffe00030a1bf08 Success Error Cancel pending
       Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
 \Driver\[COLOR=#FF0000][B][U]nvlddmkm[/U][/B][/COLOR] nt!PopRequestCompletion
 [  0, 0]   0  0 00000000 00000000 00000000-ffffe00030a1bf08
As we can see from the Dump files, the Crash was caused by the "NVLDDMKM.sys" which is the NVIDIA Driver for your laptop. It appears that you are not using the Display Driver provided by ASUS. It is strongly recommended to use the Display Drivers provided by the manufacturers in case of laptops as they do special tweaking to support the Graphics Switching.
Kindly remove the current set of NVIDIA Display drivers installed on your system using the Display Driver Uninstaller from this **LINK**. Once the driver has been removed, restart the system. After this, install the latest NVIDIA Drivers from the below link -
Notebooks & Ultrabooks - ASUS ROG G750JM - ASUS
Let me know how it goes ^_^
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
Zealot
cool
ok did everything you said and now its the waiting game to see if it happens again or not thanks for your help for pinpointing the issue bro you are a life saver lol:)
    Windows 8.1 64-bit
    1920x1080@60Hz
    razer deathadder
    google chrome
    avast
blueelvis
OMG Debugger!
India
Thanks for your kind words ^_^
In case of any further problems, do not hesitate to post back ^_^
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
Zealot
will do
yea i for sure will contact you again if i have a issue , it was a pleasure working with ya
    Windows 8.1 64-bit
    1920x1080@60Hz
    razer deathadder
    google chrome
    avast
blueelvis
OMG Debugger!
India
Thanks for your kind words.
I am glad that your issue has been solved ^_^
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
