Berktheturk
On Sun 14.5.2017 16:48:57 your computer crashed
crash dump file: C:\Windows\Minidump\051417-5312-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1509A0)
Bugcheck code: 0x9F (0x3, 0xFFFFE000835EE060, 0xFFFFF800A1927960, 0xFFFFE00087CD4C10)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
hello this is my dump files i get this bsod very occasionaly i run windows 8.1 64x
i try to open a game it crashes in minutes my graphic cards and my drivers are up to date i dont know why it happens i attached the dump folders PLEASE HELP ASAP thank you
