BSOD driver power state failure
ardikur
2
Hello,
So recently, I got driver power state failure BSOD and I decided to refresh my laptop. I already updated my windows 8 but the problem still persist. I also noticed that some update fail to install when I restart my laptop. After that, everytime I turn on my laptop, my laptop freeze about 3 minute and then work normally. But if I shut down my laptop, it started to restart, but then after that I can shut down normally.
My .dmp file is attached below. Thank you for your help! :)
axe0
BSOD Kernel Dump Analyst
2,431
Hi ardikur,
Welcome to the 8forums.
I see you have KMSpico, for what have you used KMSpico?
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
axe0
2,431
Yes please,
This quote is meant for counterfeit copy of windows, but it is pretty much the same for other software.
KMSpico heavily modifies code that causes the installation to behave it in unexpected ways. Analyzing BSOD's and determining their causes on with these sorts of installations is very unreliable. For this many analysts won't attempt it.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
