BSOD Driver Power State Failure
blueelvis
OMG Debugger!
India
2,097
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
blueelvis
OMG Debugger!
India
2,097
Hi mikel1 ^_^,
The above attachment worked fine. The link which you sent via PM was flagged by ESET as malicious so I would suggest you to stay away from that host ;)
I have analysed your dump files and below has been provided an analysis of the same for informative purposes :-
[HR][/HR]
5: kd> !irp ffffcf816fd3eca0Irp is active with 8 stacks 4 is current (= 0xffffcf816fd3ee48)
 No Mdl: No System Buffer: Thread 00000000:  Irp stack trace.
     cmd  flg cl Device   File     Completion-Context
 [  0, 0]   0  0 00000000 00000000 00000000-00000000
			Args: 00000000 00000000 00000000 00000000
 [  0, 0]   0 10 00000000 00000000 00000000-00000000
>[ 16, 2]   0 e1 ffffe0002152a880 00000000 fffff8004089a24c-ffffd00037d67750 Success Error Cancel pending
	       \Driver\pci	nt!ViFilterGenericCompletionRoutine
			Args: 00000000 00000001 00000001 00000000
 [ 16, 2]   0 e0 ffffe00024ffebb0 00000000 fffff80166c4637c-ffffd00037d677d0 Success Error Cancel
	       \DRIVER\VERIFIER_FILTER	dxgkrnl!DpiFdoPowerCompletionRoutine
 [ 16, 2]   0 e0 ffffe00024e7a040 00000000 fffff8004089a24c-ffffd00037d67b50 Success Error Cancel
	       \Driver\[COLOR=#ff0000][B]nvlddmkm[/B][/COLOR]	nt!ViFilterGenericCompletionRoutine
 [ 16, 2]   0 e1 ffffe000251405f0 00000000 fffff800403231cc-ffffe000278d0ea8 Success Error Cancel pending
	       \DRIVER\VERIFIER_FILTER	nt!PopRequestCompletion
 [  0, 0]   0  0 00000000 00000000 00000000-ffffe000278d0ea8
Irp Extension present at 0xffffcf816fd3efb0:
[HR][/HR]
We see that the NVIDIA driver is responsible for causing the crash (Actually, in every crash). But wait, what's this? -
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
Why have you enabled Driver Verifier? This is the reason why your system is crashing. Till you are not instructed to turn this on, please disable this by typing the below command in an Administrator Command Prompt (See **here** on how to open CMD as Admin) -
verifier /reset
Once you have disabled it, let me know how it goes ^_^
-Pranav
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
blueelvis
OMG Debugger!
India
2,097
Hi mikel1 ^_^,
Kindly disable it by following the instructions from my previous post. Hopefully, the below procedure would get rid of these BSODs.
Follow the below instructions -
  1. Please download the Display Driver Uninstaller from **THIS** link and run it to remove your currently installed NVIDIA Driver.
  2. Once it has removed the driver, please reboot the system. Don't worry about the display in case it is appearing a little weird.
  3. Once the system has booted up, download the driver from **THIS** link and install it.
  4. Kindly follow **THIS** link and disable the NVIDIA Streaming Service.
Check for BSODs.
Let me know in case of any further problems ^_^
-Pranav
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
blueelvis
OMG Debugger!
India
2,097
#9
I followed your steps and it crashed again...maybe windows 10 update solves the problem..
Hmm. The instructions which I have provided to you work with most (Like 99%) of the laptops. Have you upgraded to Windows 10? Did it solve your problem?
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
blueelvis
OMG Debugger!
India
2,097
#11
Ok. Keep us updated in case of any further problems :)
-Pranav
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
