Solved BSOD - Driver Power State Failure
Jbmccuaig
5
Hi
I getting this error when I try and shutdown my laptop, will not shutdown and after a couple of minutes it comes up with the above error.
Attached is the information from the SF Diagnostic Tool.
Any help would be appreciated.
Thanks
Jamie
    ASUS G75VX
    Intel i7 3630QM
    GTX G70MX
    AVG
Jbmccuaig
5
Just an update, I am been trying and few things out but I just brought a new monitor Acer T232HL touch screen. It is connected via and HDMI port and needs a usb connection in order to use the touch function. If I disconnect the monitor the problems seems to go away and can shutdown as normal.
Not sure if that's any use
    ASUS G75VX
    Intel i7 3630QM
    GTX G70MX
    AVG
usasma
Mr. Cranky Pants
5,139
If you disconnect the monitor - how can you see what you're doing? Do you have a second monitor - or do you replace this one with another one (and then it works fine).
Have you tried using the new monitor without the USB connected (just for troubleshooting)? Does the system still have problems with that?
SSD's were temperamental when they first came out, but their reliability has improved greatly over the last year or two. There are 2 things that MUST be checked on systems with BSOD's and SSD's:
1) That the SSD firmware is the latest available for the SSD
2) That the storage controller drivers on the motherboard are the most recent. They must date from late 2012 or later. This is ALL controllers, not just the one that the SSD is attached to.
If using the Corsair Link2 software, please uninstall it - as it's known to cause BSOD's in some Windows systems.
I would suggest removing and reinstalling your wifi drivers - as the memory dumps seem to be having issues with wireless.
ASMMAP64.sys Thu Jul 2 05:13:26 2009 (4A4C7A36)
LENOVO ATK Hotkey ATK0101 ACPI UTILITY
http://www.carrona.org/drivers/driver.php?id=ASMMAP64.sys
atkwmiacpi64.sys Tue Sep 6 21:44:52 2011 (4E66CC94)
ATK WMIACPI Utility
http://www.carrona.org/drivers/driver.php?id=atkwmiacpi64.sys
AiCharger.sys Thu Sep 22 22:04:40 2011 (4E7BE938)
Asus Charger Driver [br] Likely BSOD cause - haven't seen recently (15Jan2013)
http://www.carrona.org/drivers/driver.php?id=AiCharger.sys
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[font=lucida console]**************************Tue May 28 01:53:24.280 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052813-18937-01.dmp]
Windows 8 Kernel Version 9200 MP (8 procs) Free x64
Built by: [B]9200[/B].16581.amd64fre.win8_gdr.130410-1505
System Uptime:[B]0 days 0:38:29.065[/B]
*** ERROR: Module load completed but symbols could not be loaded for vwifibus.sys
Probably caused by :[B]vwifibus.sys[/B]
BugCheck [B]9F, {3, fffffa801f28dac0, fffff802c49247f0, fffffa802211c010}[/B]
Arguments:
Arg2: fffffa801f28dac0, Physical Device Object of the stack
Arg3: fffff802c49247f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa802211c010, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_3_vwifimp_IMAGE_vwifibus.sys[/B]
CPUID:        "Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz"
MaxSpeed:     2400
CurrentSpeed: [B]2395[/B]
  BIOS Version                  G75VX.206
  BIOS Release Date             02/27/2013
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product Name                  G75VX
**************************Tue May 28 00:30:00.243 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052813-25562-01.dmp]
System Uptime:[B]0 days 0:58:41.028[/B]
BugCheck [B]9F, {3, fffffa801f122660, fffff88002c2b7f0, fffffa80214f8c60}[/B]
Arguments:
Arg2: fffffa801f122660, Physical Device Object of the stack
Arg3: fffff88002c2b7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa80214f8c60, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2400
  Product Name                  G75VX
**************************Mon May 27 22:52:50.975 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052813-23234-01.dmp]
System Uptime:[B]0 days 0:49:35.759[/B]
BugCheck [B]9F, {3, fffffa801f0dc810, fffff80186d9e7f0, fffffa801aaa5010}[/B]
Arguments:
Arg2: fffffa801f0dc810, Physical Device Object of the stack
Arg3: fffff80186d9e7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa801aaa5010, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2400
  Product Name                  G75VX
**************************Mon May 27 19:35:28.418 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052813-27828-01.dmp]
System Uptime:[B]0 days 1:37:06.203[/B]
BugCheck [B]9F, {3, fffffa801f053c90, fffff8800182b7f0, fffffa8019c93c60}[/B]
Arguments:
Arg2: fffffa801f053c90, Physical Device Object of the stack
Arg3: fffff8800182b7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8019c93c60, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2400
  Product Name                  G75VX
**************************Mon May 27 01:51:33.039 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052713-19515-01.dmp]
System Uptime:[B]0 days 2:40:56.824[/B]
BugCheck [B]9F, {3, fffffa801ee9cd80, fffff802546147f0, fffffa801f1b4cd0}[/B]
Arguments:
Arg2: fffffa801ee9cd80, Physical Device Object of the stack
Arg3: fffff802546147f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa801f1b4cd0, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2400
  Product Name                  G75VX
[/font]
3rd Party Drivers:
[COLOR=RED][B]ASMMAP64.sys                Thu Jul  2 05:13:26 2009 (4A4C7A36)[/B][/COLOR]
[COLOR=RED][B]CORSGKB.sys                 Mon Jun 20 22:38:24 2011 (4E000420)[/B][/COLOR]
[COLOR=RED][B]atkwmiacpi64.sys            Tue Sep  6 21:44:52 2011 (4E66CC94)[/B][/COLOR]
[COLOR=RED][B]AiCharger.sys               Thu Sep 22 22:04:40 2011 (4E7BE938)[/B][/COLOR]
AsHIDSwitch64.sys           Wed May 30 22:38:32 2012 (4FC6D9A8)
btath_bus.sys               Thu Jun 21 01:22:17 2012 (4FE2AF89)
btath_lwflt.sys             Thu Jun 21 01:22:36 2012 (4FE2AF9C)
btath_hcrp.sys              Thu Jun 21 01:23:29 2012 (4FE2AFD1)
L1C63x64.sys                Wed Jul 18 22:54:44 2012 (500776F4)
kbfiltr.sys                 Wed Aug  1 23:22:22 2012 (5019F26E)
dump_iaStorA.sys            Sat Sep  1 21:01:24 2012 (5042AFE4)
avgfwd6a.sys                Tue Sep  4 04:31:15 2012 (5045BC53)
SnakeEyes.sys               Wed Sep  5 01:31:26 2012 (5046E3AE)
btfilter.sys                Thu Sep 13 03:13:45 2012 (505187A9)
avgrkx64.sys                Thu Sep 13 20:41:40 2012 (50527D44)
SynTP.sys                   Mon Sep 17 12:56:39 2012 (50575647)
Smb_driver_Intel.sys        Mon Sep 17 12:58:22 2012 (505756AE)
avgloga.sys                 Thu Sep 20 21:23:51 2012 (505BC1A7)
btath_flt.sys               Thu Sep 27 05:49:09 2012 (50642115)
avgldx64.sys                Mon Oct  1 21:05:50 2012 (506A3DEE)
avgidsha.sys                Sun Oct 14 21:22:54 2012 (507B656E)
avgidsdrivera.sys           Mon Oct 22 06:47:11 2012 (5085242F)
HWiNFO64A.SYS               Wed Nov 14 06:15:59 2012 (50A37D6F)
avgmfx64.sys                Thu Nov 15 17:03:50 2012 (50A566C6)
athw8x.sys                  Mon Nov 19 02:57:56 2012 (50A9E684)
rikvm_38F51D56.sys          Mon Nov 19 04:45:43 2012 (50A9FFC7)
avgwfpa.sys                 Mon Nov 26 17:09:35 2012 (50B3E89F)
HECIx64.sys                 Mon Dec 17 14:32:21 2012 (50CF7345)
RTKVHD64.sys                Tue Jan  8 08:25:20 2013 (50EC1E40)
nvhda64v.sys                Mon Feb 25 00:27:35 2013 (512AF647)
mbam.sys                    Thu Feb 28 15:33:07 2013 (512FBF03)
nvlddmkm.sys                Sun May 12 15:09:45 2013 (518FE8F9)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
nvlddmkm.sys                Thu Mar 14 21:37:00 2013 (51427B3C)
[/font]
http://www.carrona.org/drivers/driver.php?id=CORSGKB.sys
AsHIDSwitch64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=btath_bus.sys
http://www.carrona.org/drivers/driver.php?id=btath_lwflt.sys
http://www.carrona.org/drivers/driver.php?id=btath_hcrp.sys
http://www.carrona.org/drivers/driver.php?id=L1C63x64.sys
http://www.carrona.org/drivers/driver.php?id=kbfiltr.sys
http://www.carrona.org/drivers/driver.php?id=avgfwd6a.sys
SnakeEyes.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=btfilter.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=btath_flt.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
http://www.carrona.org/drivers/driver.php?id=HWiNFO64A.SYS
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
http://www.carrona.org/drivers/driver.php?id=athw8x.sys
http://www.carrona.org/drivers/driver.php?id=rikvm_38F51D56.sys
http://www.carrona.org/drivers/driver.php?id=avgwfpa.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=mbam.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
Jbmccuaig
5
Thanks so much for the quick response.
I am using a laptop (G75VX running windows 8), I also have another monitor that has been connected to the laptop for 6months without any shutdown issues. The BSOD started when I connected the Acer T232HL to the laptop.
Getting the BSOD now when using my original monitor, have updated all the drivers I was able to. Going to see if any of that works.
Will reply to this thread.
Thanks
    ASUS G75VX
    Intel i7 3630QM
    GTX G70MX
    AVG
Jbmccuaig
5
New dump files
Attached is the dump files from the latest crash today.
Any help is very much appreciated.
Thanks
    ASUS G75VX
    Intel i7 3630QM
    GTX G70MX
    AVG
usasma
Mr. Cranky Pants
5,139
AVG had issues early on in the beta days of Win8. I'd suggest that you:
- uninstall AVG
- run this free removal tool to remove any remnants that may be left behind: AVG | Download tools and utilities
- then be sure that Microsoft Defender and the Windows Firewall are enabled (look in the Action Center that's in the Notification Area (System Tray - down by the clock in the lower right corner of the Desktop).
- monitor for further BSOD's.
If that doesn't stop it, then I'd next suggest that you run Driver Verifier according to these directions: Driver Verifier Settings
Memory dumps still blame the wifi drivers:
Microsoft (R) Windows Debugger Version 6.2.9200.16384 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\053013-19218-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9200.16581.amd64fre.win8_gdr.130410-1505
Machine Name:
Kernel base = 0xfffff800`c8273000 PsLoadedModuleList = 0xfffff800`c853fa20
Debug session time: Wed May 29 23:45:48.272 2013 (UTC - 4:00)
System Uptime: 0 days 1:43:30.057
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 9F, {3, fffffa801e5a0ca0, fffff800c72057f0, fffffa801fe6d700}
Probably caused by : vwifibus.sys
Followup: MachineOwner
0: kd> !analyze -v
A driver has failed to complete a power IRP within a specific time (usually 10 minutes).
Arguments:
Arg2: fffffa801e5a0ca0, Physical Device Object of the stack
Arg3: fffff800c72057f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa801fe6d700, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  vwifibus.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  5010ab2a
MODULE_NAME: vwifibus
FAULTING_MODULE: fffff88004e26000 vwifibus
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
CURRENT_IRQL:  2
TAG_NOT_DEFINED_c000000f:  FFFFF800C720BFB0
STACK_TEXT:
fffff800`c72057b8 fffff800`c84093a2 : 00000000`0000009f 00000000`00000003 fffffa80`1e5a0ca0 fffff800`c72057f0 : nt!KeBugCheckEx
fffff800`c72057c0 fffff800`c84093d5 : fffffa80`20a868f0 fffffa80`1d82f1b0 fffff800`c7205939 fffff800`c82f5ef6 : nt!PopIrpWatchdogBugcheck+0xe2
fffff800`c7205820 fffff800`c82f61ea : fffffa80`1d82f1b0 00000000`00000000 fffff800`c7205b18 fffffa80`19797940 : nt!PopIrpWatchdog+0x32
fffff800`c7205870 fffff800`c82f4655 : 00000000`00000000 fffff800`c82f5cff 00000000`00140001 fffff800`c856f040 : nt!KiProcessExpiredTimerList+0x22a
fffff800`c72059a0 fffff800`c82f6668 : fffff800`c856b180 fffff800`c856df80 00000000`00000006 00000000`00039d5e : nt!KiExpireTimerTable+0xa9
fffff800`c7205a40 fffff800`c82f5a06 : fffffa80`00000000 00001f80`00560080 00000000`00000000 00000000`00000002 : nt!KiTimerExpiration+0xc8
fffff800`c7205af0 fffff800`c82f69ba : fffff800`c856b180 fffff800`c856b180 00000000`001a3db0 fffff800`c85c5880 : nt!KiRetireDpcList+0x1f6
fffff800`c7205c60 00000000`00000000 : fffff800`c7206000 fffff800`c7200000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  0x9F_3_vwifimp_IMAGE_vwifibus.sys
0: kd> lmtsmn
fffff880`01157000 fffff880`011c4000   ACPI     ACPI.sys     Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`010d2000 fffff880`010e9000   acpiex   acpiex.sys   Wed Jul 25 22:25:57 2012 (5010AAB5)
fffff880`01600000 fffff880`01692000   afd      afd.sys      Mon Nov 05 22:53:42 2012 (509889C6)
fffff880`03a0c000 fffff880`03a24000   AgileVpn AgileVpn.sys Wed Jul 25 22:23:11 2012 (5010AA0F)
fffff880`04f5e000 fffff880`04f67000   AsHIDSwitch64 AsHIDSwitch64.sys Wed May 30 22:38:32 2012 (4FC6D9A8)
fffff880`056ba000 fffff880`056c2000   ASMMAP64 ASMMAP64.sys Thu Jul 02 05:13:26 2009 (4A4C7A36)
fffff880`04a86000 fffff880`04e26000   athw8x   athw8x.sys   Mon Mar 11 05:03:25 2013 (513D9DDD)
fffff880`03bed000 fffff880`03bf6000   atkwmiacpi64 atkwmiacpi64.sys Tue Sep 06 21:44:52 2011 (4E66CC94)
fffff880`0417c000 fffff880`0418b000   avgfwd6a avgfwd6a.sys Tue Sep 04 04:31:15 2012 (5045BC53)
fffff880`03bb9000 fffff880`03bed000   avgidsdrivera avgidsdrivera.sys Mon Oct 22 06:47:11 2012 (5085242F)
fffff880`01c95000 fffff880`01ca8000   avgidsha avgidsha.sys Sun Oct 14 21:22:54 2012 (507B656E)
fffff880`01692000 fffff880`016c3000   avgldx64 avgldx64.sys Mon Oct 01 21:05:50 2012 (506A3DEE)
fffff880`01fb9000 fffff880`01ff1000   avgloga  avgloga.sys  Thu Sep 20 21:23:51 2012 (505BC1A7)
fffff880`01c00000 fffff880`01c1f000   avgmfx64 avgmfx64.sys Thu Nov 15 17:03:50 2012 (50A566C6)
fffff880`01751000 fffff880`0175d000   avgrkx64 avgrkx64.sys Thu Sep 13 20:41:40 2012 (50527D44)
fffff880`04147000 fffff880`0417c000   avgwfpa  avgwfpa.sys  Mon Nov 26 17:09:35 2012 (50B3E89F)
fffff880`043df000 fffff880`043f0000   BasicDisplay BasicDisplay.sys Wed Jul 25 22:29:08 2012 (5010AB74)
fffff880`0413a000 fffff880`04147000   BasicRender BasicRender.sys Wed Jul 25 22:28:51 2012 (5010AB63)
fffff880`04f2c000 fffff880`04f38000   BATTC    BATTC.SYS    Thu Oct 11 01:19:58 2012 (507656FE)
fffff880`04132000 fffff880`0413a000   Beep     Beep.SYS     Wed Jul 25 22:30:19 2012 (5010ABBB)
fffff880`00dad000 fffff880`00db7000   BOOTVID  BOOTVID.dll  Wed Jul 25 22:30:22 2012 (5010ABBE)
fffff880`0a125000 fffff880`0a145000   bowser   bowser.sys   Wed Jul 25 22:28:01 2012 (5010AB31)
fffff880`04fec000 fffff880`04ff9000   btath_bus btath_bus.sys Thu Jun 21 01:22:17 2012 (4FE2AF89)
fffff880`05935000 fffff880`05951000   btath_flt btath_flt.sys Thu Sep 27 05:49:09 2012 (50642115)
fffff880`058e9000 fffff880`05935000   btath_hcrp btath_hcrp.sys Thu Jun 21 01:23:29 2012 (4FE2AFD1)
fffff880`05951000 fffff880`05969000   btath_lwflt btath_lwflt.sys Thu Jun 21 01:22:36 2012 (4FE2AF9C)
fffff880`054b2000 fffff880`05553000   btfilter btfilter.sys Thu Sep 13 03:13:45 2012 (505187A9)
fffff880`05897000 fffff880`058a9000   BthEnum  BthEnum.sys  Tue Jan 08 22:58:34 2013 (50ECEAEA)
fffff880`05835000 fffff880`0586c000   BthLEEnum BthLEEnum.sys Wed Jul 25 22:25:02 2012 (5010AA7E)
fffff880`058a9000 fffff880`058cb000   bthpan   bthpan.sys   Wed Jul 25 22:23:42 2012 (5010AA2E)
fffff880`056dc000 fffff880`05801000   bthport  bthport.sys  Thu Feb 28 23:55:37 2013 (513034C9)
fffff880`0660c000 fffff880`06623000   BTHUSB   BTHUSB.sys   Tue Jan 08 22:59:16 2013 (50ECEB14)
fffff960`00979000 fffff960`009af000   cdd      cdd.dll      Thu Jul 26 00:49:37 2012 (5010CC61)
fffff880`040f8000 fffff880`04129000   cdrom    cdrom.sys    Wed Jul 25 22:26:36 2012 (5010AADC)
fffff880`00c00000 fffff880`00c7f000   CI       CI.dll       Wed Mar 27 23:30:42 2013 (5153B962)
fffff880`016fd000 fffff880`01751000   CLASSPNP CLASSPNP.SYS Thu Feb 28 23:59:20 2013 (513035A8)
fffff880`00d19000 fffff880`00d75000   CLFS     CLFS.SYS     Wed Jul 25 22:29:39 2012 (5010AB93)
fffff880`04f25000 fffff880`04f2b400   CmBatt   CmBatt.sys   Wed Jul 25 22:29:20 2012 (5010AB80)
fffff880`00eed000 fffff880`00f79000   cng      cng.sys      Thu Oct 11 01:17:34 2012 (5076566E)
fffff880`03ba7000 fffff880`03bb6000   CompositeBus CompositeBus.sys Wed Jul 25 22:28:03 2012 (5010AB33)
fffff880`0b933000 fffff880`0b940000   condrv   condrv.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`069c2000 fffff880`069d0000   CORSGKB  CORSGKB.sys  Mon Jun 20 22:38:24 2011 (4E000420)
fffff880`0175d000 fffff880`01771000   crashdmp crashdmp.sys Sat Feb 02 02:26:00 2013 (510CBF88)
fffff880`03a9a000 fffff880`03b2b000   csc      csc.sys      Thu Sep 20 02:08:29 2012 (505AB2DD)
fffff880`03b86000 fffff880`03ba7000   dfsc     dfsc.sys     Wed Jul 25 22:26:53 2012 (5010AAED)
fffff880`03b75000 fffff880`03b86000   discache discache.sys Wed Jul 25 22:28:23 2012 (5010AB47)
fffff880`015d7000 fffff880`015f3000   disk     disk.sys     Wed Jul 25 22:29:25 2012 (5010AB85)
fffff880`04a52000 fffff880`04a74000   drmk     drmk.sys     Thu Oct 11 01:18:59 2012 (507656C3)
fffff880`0560d000 fffff880`05621000   dump_dumpfve dump_dumpfve.sys Thu Sep 20 02:09:30 2012 (505AB31A)
fffff880`03e16000 fffff880`040e1000   dump_iaStorA dump_iaStorA.sys Sat Sep 01 21:01:24 2012 (5042AFE4)
fffff880`05600000 fffff880`0560d000   dump_storport dump_storport.sys Wed Jul 25 22:29:58 2012 (5010ABA6)
fffff880`04217000 fffff880`04380000   dxgkrnl  dxgkrnl.sys  Sat Apr 13 01:09:52 2013 (5168E8A0)
fffff880`04391000 fffff880`043df000   dxgmms1  dxgmms1.sys  Tue Jan 08 22:58:58 2013 (50ECEB02)
fffff880`05969000 fffff880`059a0000   fastfat  fastfat.SYS  Wed Jul 25 22:30:23 2012 (5010ABBF)
fffff880`015ac000 fffff880`015c0000   fileinfo fileinfo.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`01200000 fffff880`01260000   fltmgr   fltmgr.sys   Wed Jul 25 22:30:09 2012 (5010ABB1)
fffff880`01a7c000 fffff880`01a86000   Fs_Rec   Fs_Rec.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`01c1f000 fffff880`01c95000   fvevol   fvevol.sys   Thu Sep 20 02:08:15 2012 (505AB2CF)
fffff880`01f36000 fffff880`01f9e000   fwpkclnt fwpkclnt.sys Thu Feb 28 23:55:54 2013 (513034DA)
fffff800`c8207000 fffff800`c8273000   hal      hal.dll      Tue Oct 23 23:03:21 2012 (50875A79)
fffff880`064fb000 fffff880`06511000   HDAudBus HDAudBus.sys Thu Sep 20 02:08:43 2012 (505AB2EB)
fffff880`065a0000 fffff880`065b3000   HECIx64  HECIx64.sys  Mon Dec 17 14:32:21 2012 (50CF7345)
fffff880`04f67000 fffff880`04f82000   HIDCLASS HIDCLASS.SYS Mon Apr 08 22:34:48 2013 (51637E48)
fffff880`04f82000 fffff880`04f8a000   HIDPARSE HIDPARSE.SYS Wed Jul 25 22:30:15 2012 (5010ABB7)
fffff880`069d0000 fffff880`069dd000   hidusb   hidusb.sys   Mon Apr 08 22:34:41 2013 (51637E41)
fffff880`0a046000 fffff880`0a125000   HTTP     HTTP.sys     Thu Mar 14 20:17:15 2013 (5142688B)
fffff880`03b6b000 fffff880`03b75000   HWiNFO64A HWiNFO64A.SYS Wed Nov 14 06:15:59 2012 (50A37D6F)
fffff880`04e51000 fffff880`04e71000   i8042prt i8042prt.sys Wed Jul 25 22:28:50 2012 (5010AB62)
fffff880`01272000 fffff880`0153d000   iaStorA  iaStorA.sys  Sat Sep 01 21:01:24 2012 (5042AFE4)
fffff880`04f38000 fffff880`04f54000   intelppm intelppm.sys Mon Nov 05 22:55:02 2012 (50988A16)
fffff880`04f07000 fffff880`04f16000   kbdclass kbdclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff880`069eb000 fffff880`069f8000   kbdhid   kbdhid.sys   Wed Jul 25 22:28:49 2012 (5010AB61)
fffff880`04eff000 fffff880`04f07000   kbfiltr  kbfiltr.sys  Wed Aug 01 23:22:22 2012 (5019F26E)
fffff800`c7234000 fffff800`c723d000   kdcom    kdcom.dll    Wed Jul 25 22:30:34 2012 (5010ABCA)
fffff880`0474a000 fffff880`04755000   kdnic    kdnic.sys    Wed Jul 25 22:27:41 2012 (5010AB1D)
fffff880`046fb000 fffff880`0474a000   ks       ks.sys       Sat Feb 02 02:25:50 2013 (510CBF7E)
fffff880`01a50000 fffff880`01a6b000   ksecdd   ksecdd.sys   Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`01800000 fffff880`0182f000   ksecpkg  ksecpkg.sys  Thu Oct 11 01:16:46 2012 (5076563E)
fffff880`03e10000 fffff880`03e15380   ksthunk  ksthunk.sys  Wed Jul 25 22:28:58 2012 (5010AB6A)
fffff880`04e33000 fffff880`04e51000   L1C63x64 L1C63x64.sys Wed Jul 18 22:54:44 2012 (500776F4)
fffff880`0567a000 fffff880`0568e000   lltdio   lltdio.sys   Wed Jul 25 22:24:02 2012 (5010AA42)
fffff880`0562f000 fffff880`05657000   luafv    luafv.sys    Wed Jul 25 22:29:13 2012 (5010AB79)
fffff880`05657000 fffff880`05661000   mbam     mbam.sys     Thu Feb 28 15:33:07 2013 (512FBF03)
fffff880`00cba000 fffff880`00d19000   mcupdate mcupdate.dll Wed Jul 25 22:30:12 2012 (5010ABB4)
fffff880`05621000 fffff880`0562f000   monitor  monitor.sys  Thu Feb 28 23:56:18 2013 (513034F2)
fffff880`04ef0000 fffff880`04eff000   mouclass mouclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff880`06600000 fffff880`0660c000   mouhid   mouhid.sys   Fri Mar 01 21:15:53 2013 (513160D9)
fffff880`011ce000 fffff880`011e8000   mountmgr mountmgr.sys Wed Jul 25 22:29:33 2012 (5010AB8D)
fffff880`0a145000 fffff880`0a15c000   mpsdrv   mpsdrv.sys   Thu Oct 11 01:15:15 2012 (507655E3)
fffff880`0a15c000 fffff880`0a1bf000   mrxsmb   mrxsmb.sys   Tue Feb 05 17:29:08 2013 (511187B4)
fffff880`0a417000 fffff880`0a462000   mrxsmb10 mrxsmb10.sys Wed Jul 25 22:23:06 2012 (5010AA0A)
fffff880`0a462000 fffff880`0a49d000   mrxsmb20 mrxsmb20.sys Tue Feb 05 17:28:36 2013 (51118794)
fffff880`043f0000 fffff880`043fc000   Msfs     Msfs.SYS     Wed Jul 25 22:30:24 2012 (5010ABC0)
fffff880`00f82000 fffff880`00f8c000   msisadrv msisadrv.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`010e9000 fffff880`0114c000   msrpc    msrpc.sys    Wed Jul 25 22:28:37 2012 (5010AB55)
fffff880`03b5f000 fffff880`03b6b000   mssmbios mssmbios.sys Wed Jul 25 22:29:19 2012 (5010AB7F)
fffff880`015c0000 fffff880`015d7000   mup      mup.sys      Wed Jul 25 22:30:00 2012 (5010ABA8)
fffff880`01a86000 fffff880`01b7f000   ndis     ndis.sys     Sat Feb 02 02:23:49 2013 (510CBF05)
fffff880`03a00000 fffff880`03a0c000   ndistapi ndistapi.sys Thu Sep 20 02:09:19 2012 (505AB30F)
fffff880`0568e000 fffff880`056a2000   ndisuio  ndisuio.sys  Wed Jul 25 22:26:21 2012 (5010AACD)
fffff880`016c3000 fffff880`016f2000   ndiswan  ndiswan.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`04a0b000 fffff880`04a1f000   NDProxy  NDProxy.SYS  Mon Apr 08 22:33:41 2013 (51637E05)
fffff880`0b917000 fffff880`0b933000   Ndu      Ndu.sys      Wed Jul 25 22:23:41 2012 (5010AA2D)
fffff880`03e00000 fffff880`03e10000   netbios  netbios.sys  Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`0177e000 fffff880`017d6000   netbt    netbt.sys    Wed Jul 25 22:24:26 2012 (5010AA5A)
fffff880`01b7f000 fffff880`01bee000   NETIO    NETIO.SYS    Thu Oct 11 01:16:20 2012 (50765624)
fffff880`04200000 fffff880`04212000   Npfs     Npfs.SYS     Wed Jul 25 22:30:26 2012 (5010ABC2)
fffff880`03b53000 fffff880`03b5f000   npsvctrig npsvctrig.sys Wed Jul 25 22:27:33 2012 (5010AB15)
fffff880`03b45000 fffff880`03b53000   nsiproxy nsiproxy.sys Wed Jul 25 22:25:00 2012 (5010AA7C)
fffff800`c8273000 fffff800`c89bf000   nt       ntkrnlmp.exe Wed Apr 10 18:18:57 2013 (5165E551)
fffff880`0186d000 fffff880`01a50000   Ntfs     Ntfs.sys     Sat Feb 02 02:25:09 2013 (510CBF55)
fffff880`04129000 fffff880`04132000   Null     Null.SYS     Wed Jul 25 22:30:16 2012 (5010ABB8)
fffff880`04a1f000 fffff880`04a52000   nvhda64v nvhda64v.sys Mon Feb 25 00:27:35 2013 (512AF647)
fffff880`05a1a000 fffff880`064fb000   nvlddmkm nvlddmkm.sys Sun May 12 15:09:45 2013 (518FE8F9)
fffff880`05553000 fffff880`055c1000   nwifi    nwifi.sys    Wed Jul 25 22:25:11 2012 (5010AA87)
fffff880`041bb000 fffff880`041e5000   pacer    pacer.sys    Wed Jul 25 22:23:05 2012 (5010AA09)
fffff880`00e00000 fffff880`00e1a000   partmgr  partmgr.sys  Tue Jan 08 23:01:42 2013 (50ECEBA6)
fffff880`00f8c000 fffff880`00fc9000   pci      pci.sys      Wed Jul 25 22:27:43 2012 (5010AB1F)
fffff880`01a6b000 fffff880`01a7c000   pcw      pcw.sys      Wed Jul 25 22:28:44 2012 (5010AB5C)
fffff880`00fd6000 fffff880`00fed000   pdc      pdc.sys      Thu Feb 28 23:58:34 2013 (5130357A)
fffff880`0b200000 fffff880`0b2cc000   peauth   peauth.sys   Mon Apr 08 22:32:01 2013 (51637DA1)
fffff880`0467e000 fffff880`046c9000   portcls  portcls.sys  Thu Oct 11 01:16:51 2012 (50765643)
fffff880`00d98000 fffff880`00dad000   PSHED    PSHED.dll    Thu Jul 26 00:53:53 2012 (5010CD61)
fffff880`04fab000 fffff880`04fd0000   rasl2tp  rasl2tp.sys  Wed Jul 25 22:23:16 2012 (5010AA14)
fffff880`04fd0000 fffff880`04fea000   raspppoe raspppoe.sys Wed Jul 25 22:24:55 2012 (5010AA77)
fffff880`04f8a000 fffff880`04fab000   raspptp  raspptp.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`017d6000 fffff880`017f4000   rassstp  rassstp.sys  Wed Jul 25 22:23:59 2012 (5010AA3F)
fffff880`03a28000 fffff880`03a9a000   rdbss    rdbss.sys    Wed Jul 25 22:25:57 2012 (5010AAB5)
fffff880`04a00000 fffff880`04a0b000   rdpbus   rdpbus.sys   Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`0182f000 fffff880`0186a000   rdyboost rdyboost.sys Wed Jul 25 22:28:34 2012 (5010AB52)
fffff880`0586c000 fffff880`05897000   rfcomm   rfcomm.sys   Thu Feb 28 23:56:33 2013 (51303501)
fffff880`0b2ce000 fffff880`0b917000   rikvm_38F51D56 rikvm_38F51D56.sys Mon Nov 19 04:45:43 2012 (50A9FFC7)
fffff880`056a2000 fffff880`056ba000   rspndr   rspndr.sys   Wed Jul 25 22:24:06 2012 (5010AA46)
fffff880`0665f000 fffff880`0697f800   RTKVHD64 RTKVHD64.sys Tue Jan 08 08:25:20 2013 (50EC1E40)
fffff880`0b940000 fffff880`0b94b000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`03bf6000 fffff880`03bff000   serscan  serscan.sys  Wed Oct 10 23:51:49 2012 (50764255)
fffff880`04f16000 fffff880`04f25000   Smb_driver_Intel Smb_driver_Intel.sys Mon Sep 17 12:58:22 2012 (505756AE)
fffff880`069dd000 fffff880`069eb000   SnakeEyes SnakeEyes.sys Wed Sep 05 01:31:26 2012 (5046E3AE)
fffff880`00e1a000 fffff880`00e63000   spaceport spaceport.sys Mon Apr 08 22:34:53 2013 (51637E4D)
fffff880`0a53e000 fffff880`0a5cb000   srv      srv.sys      Wed Jul 25 22:25:28 2012 (5010AA98)
fffff880`0a49d000 fffff880`0a53e000   srv2     srv2.sys     Mon Apr 08 22:33:02 2013 (51637DDE)
fffff880`0b94b000 fffff880`0b98f000   srvnet   srvnet.sys   Mon Apr 08 22:31:13 2013 (51637D71)
fffff880`0153d000 fffff880`01592000   storport storport.sys Thu Feb 28 23:58:51 2013 (5130358B)
fffff880`04fea000 fffff880`04feb480   swenum   swenum.sys   Wed Jul 25 22:28:53 2012 (5010AB65)
fffff880`04e71000 fffff880`04ee5000   SynTP    SynTP.sys    Mon Sep 17 12:56:39 2012 (50575647)
fffff880`01cfe000 fffff880`01f36000   tcpip    tcpip.sys    Thu Feb 28 23:57:45 2013 (51303549)
fffff880`0b98f000 fffff880`0b9a1000   tcpipreg tcpipreg.sys Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`041ad000 fffff880`041bb000   TDI      TDI.SYS      Wed Jul 25 22:27:59 2012 (5010AB2F)
fffff880`0418b000 fffff880`041ad000   tdx      tdx.sys      Wed Jul 25 22:24:58 2012 (5010AA7A)
fffff880`00d75000 fffff880`00d98000   tm       tm.sys       Wed Jul 25 22:29:01 2012 (5010AB6D)
fffff960`00777000 fffff960`00780000   TSDDD    TSDDD.dll    Wed Jul 25 22:30:25 2012 (5010ABC1)
fffff880`00c7f000 fffff880`00cab000   tunnel   tunnel.sys   Wed Jul 25 22:23:04 2012 (5010AA08)
fffff880`06568000 fffff880`065a0000   ucx01000 ucx01000.sys Thu Sep 20 02:07:54 2012 (505AB2BA)
fffff880`059a0000 fffff880`059f4000   udfs     udfs.sys     Wed Jul 25 22:30:18 2012 (5010ABBA)
fffff880`04755000 fffff880`04767000   umbus    umbus.sys    Wed Jul 25 22:27:39 2012 (5010AB1B)
fffff880`058cb000 fffff880`058e8c00   usbaudio usbaudio.sys Wed Jul 25 22:26:27 2012 (5010AAD3)
fffff880`0699f000 fffff880`069c2000   usbccgp  usbccgp.sys  Wed Jul 25 22:27:06 2012 (5010AAFA)
fffff880`04ee5000 fffff880`04ef0000   USBD     USBD.SYS     Thu Sep 20 02:10:20 2012 (505AB34C)
fffff880`065b3000 fffff880`065c9000   usbehci  usbehci.sys  Thu Sep 20 02:09:27 2012 (505AB317)
fffff880`04600000 fffff880`0467e000   usbhub   usbhub.sys   Sat Feb 02 02:25:14 2013 (510CBF5A)
fffff880`0543f000 fffff880`054b2000   UsbHub3  UsbHub3.sys  Sat Feb 02 02:23:36 2013 (510CBEF8)
fffff880`04767000 fffff880`047e2000   USBPORT  USBPORT.SYS  Thu Sep 20 02:09:39 2012 (505AB323)
fffff880`06980000 fffff880`0699f000   USBSTOR  USBSTOR.SYS  Wed Jul 25 22:27:04 2012 (5010AAF8)
fffff880`05801000 fffff880`05834580   usbvideo usbvideo.sys Thu Sep 20 02:07:45 2012 (505AB2B1)
fffff880`06511000 fffff880`06568000   USBXHCI  USBXHCI.SYS  Fri Mar 01 21:16:03 2013 (513160E3)
fffff880`00fc9000 fffff880`00fd6000   vdrvroot vdrvroot.sys Wed Jul 25 22:27:29 2012 (5010AB11)
fffff880`00e63000 fffff880`00e7b000   volmgr   volmgr.sys   Wed Jul 25 22:29:22 2012 (5010AB82)
fffff880`00e7b000 fffff880`00edb000   volmgrx  volmgrx.sys  Wed Jul 25 22:29:59 2012 (5010ABA7)
fffff880`01ca8000 fffff880`01cfd000   volsnap  volsnap.sys  Wed Jul 25 22:30:26 2012 (5010ABC2)
fffff880`04e26000 fffff880`04e33000   vwifibus vwifibus.sys Wed Jul 25 22:27:54 2012 (5010AB2A)
fffff880`041e5000 fffff880`041fb000   vwififlt vwififlt.sys Wed Jul 25 22:26:39 2012 (5010AADF)
fffff880`056c2000 fffff880`056cc000   vwifimp  vwifimp.sys  Wed Jul 25 22:26:39 2012 (5010AADF)
fffff880`03b2b000 fffff880`03b45000   wanarp   wanarp.sys   Mon Apr 08 22:31:00 2013 (51637D64)
fffff880`04380000 fffff880`04391000   watchdog watchdog.sys Wed Jul 25 22:29:05 2012 (5010AB71)
fffff880`01000000 fffff880`010c2000   Wdf01000 Wdf01000.sys Tue Jan 08 22:59:00 2013 (50ECEB04)
fffff880`010c2000 fffff880`010d2000   WDFLDR   WDFLDR.SYS   Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`01f9e000 fffff880`01fb9000   wfplwfs  wfplwfs.sys  Wed Jul 25 22:23:58 2012 (5010AA3E)
fffff960`000fd000 fffff960`004ee000   win32k   win32k.sys   Mon Apr 08 22:34:32 2013 (51637E38)
fffff880`04f54000 fffff880`04f5e000   wmiacpi  wmiacpi.sys  Wed Jul 25 22:29:53 2012 (5010ABA1)
fffff880`011c4000 fffff880`011ce000   WMILIB   WMILIB.SYS   Wed Jul 25 22:30:04 2012 (5010ABAC)
fffff880`0b9d7000 fffff880`0b9e2000   WpdUpFltr WpdUpFltr.sys Wed Jul 25 22:27:29 2012 (5010AB11)
fffff880`0114c000 fffff880`01157000   WppRecorder WppRecorder.sys Wed Jul 25 22:29:07 2012 (5010AB73)
fffff880`05661000 fffff880`0567a000   WudfPf   WudfPf.sys   Wed Jul 25 22:26:45 2012 (5010AAE5)
fffff880`0b9a1000 fffff880`0b9d7000   WUDFRd   WUDFRd.sys   Wed Jul 25 22:26:06 2012 (5010AABE)
Unloaded modules:
fffff880`01771000 fffff880`0177e000   dump_storpor
    Timestamp: unavailable (00000000)
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`03e19000 fffff880`040e4000   dump_iaStorA
    Checksum:  00000000
    ImageSize:  002CB000
fffff880`040e4000 fffff880`040f8000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00014000
fffff880`01592000 fffff880`015ac000   EhStorClass.
    Checksum:  00000000
    ImageSize:  0001A000
fffff880`03ba7000 fffff880`03bb9000   dam.sys
    Checksum:  00000000
    ImageSize:  00012000
fffff880`00f79000 fffff880`00f82000   avgboota.sys
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01ff1000 fffff880`01ffd000   hwpolicy.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`00cad000 fffff880`00cba000   ApiSetSchema
    Checksum:  00000000
    ImageSize:  0000D000
    Samsung/NP780
    800x600
Jbmccuaig
5
Hi,
Decided to do a complete reset of windows using the function in windows 8 settings and reinstall everything.
I have updated all my drivers, including the wifi to the latest version available for my wifi (atheros AR9485WB-EG, driver is 10.0.0.234 dated 11/03/2013).
Did not install AVG and are using Windows Defender and Firewall instead and Malwarebytes anti-malware.
I am hoping that it was some sort of driver conflict and this will have sorted things out with any luck.
I thank you for all the assistance you have provided.
Kind regards
Jamie
    ASUS G75VX
    Intel i7 3630QM
    GTX G70MX
    AVG
