BSOD Driver Power State Failure
ScrollLock
6
Hi,
Just got my new Samsung ATIV SMART PC, preinstalled with Windows 8. After a few days, it begins to crash a lot, with mainly driver_power_state_failure as the cause. Could you nice ladies and gentlemen help me find the solution for this problem? Attached here is my diagnostic files using SF Tool. Thanks before...
usasma
Mr. Cranky Pants
5,139
I'm late for work, please start with this stuff. I'll post more after work....
The memory dumps blame a lot of different things - I'd suggest starting by updating all drivers to the latest Win8 compatible drivers from the manufacturer's website.
Un-install Norton and install Microsoft Security Essentials (it's free with a web search). Test to see if that stops the BSOD's.
odFips.sys Tue Mar 25 11:03:56 2008 (47E9145C)
odFips.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
odFips2.sys Mon Apr 7 12:31:36 2008 (47FA4C68)
odFips2.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
jnprvamgr.sys Tue Feb 10 21:09:25 2009 (49923355)
jnprvamgr.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
jnprna.sys Wed May 6 12:50:31 2009 (4A01BFD7)
jnprna.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
SRTSPX.SYS Tue Nov 15 17:27:18 2011 (4EC2E746)
Norton/Symantec AutoProtect
http://www.carrona.org/drivers/driver.php?id=SRTSPX.SYS
Analysis:
[font=lucida console]**************************Sat Dec  8 16:15:51.965 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120912-15421-01.dmp]
Windows 8 Kernel Version 9200 MP (4 procs) Free x86 compatible
Built by: [B]9200[/B].16442.x86fre.win8_gdr.121023-1503
System Uptime:[B]0 days 22:14:10.803[/B]
Probably caused by :[B]ACPI.sys[/B]
BugCheck [B]9F, {3, 86b8e398, 8039db40, 86ae9008}[/B]
Arguments:
Arg1: 00000003, A device object has been blocking an Irp for too long a time
Arg2: 86b8e398, Physical Device Object of the stack
Arg3: 8039db40, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: 86ae9008, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]0x9F_3_IMAGE_ACPI.sys[/B]
CPUID:        "Intel(R) Atom(TM) CPU Z2760  @ 1.80GHz"
MaxSpeed:     1800
CurrentSpeed: [B]1797[/B]
  BIOS Version                  P05AAI.228.121119.SH
  BIOS Release Date             11/19/2012
  Manufacturer                  SAMSUNG ELECTRONICS CO., LTD.
  Product Name                  500T
**************************Thu Dec  6 16:13:55.845 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120712-17890-01.dmp]
System Uptime:[B]0 days 12:54:23.608[/B]
BugCheck [B]9F, {3, 853a7400, 803d4b40, 85e5fe28}[/B]
Arguments:
Arg2: 853a7400, Physical Device Object of the stack
Arg3: 803d4b40, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: 85e5fe28, The blocked IRP
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]0x9F_3_inteli2c_IMAGE_ACPI.sys[/B]
MaxSpeed:     1800
  Product Name                  500T
**************************Thu Dec  6 03:15:59.858 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120612-15015-01.dmp]
System Uptime:[B]0 days 16:26:01.697[/B]
*** ERROR: Module load completed but symbols could not be loaded for SpbCx.sys
BugCheck [B]9F, {3, 851f87b0, 8199db40, 85c07e28}[/B]
Arguments:
Arg2: 851f87b0, Physical Device Object of the stack
Arg3: 8199db40, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: 85c07e28, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1800
  Product Name                  500T
**************************Wed Dec  5 04:39:44.302 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120512-15453-01.dmp]
System Uptime:[B]0 days 5:57:06.126[/B]
*** ERROR: Module load completed but symbols could not be loaded for sdbus.sys
Probably caused by :[B]sdbus.sys[/B]
BugCheck [B]9F, {3, 8693c948, 8039db40, 8687b910}[/B]
Arguments:
Arg2: 8693c948, Physical Device Object of the stack
Arg4: 8687b910, The blocked IRP
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]0x9F_3_bcmdhd63_IMAGE_sdbus.sys[/B]
MaxSpeed:     1800
  Product Name                  500T
**************************Mon Dec  3 00:33:09.921 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120312-16203-01.dmp]
System Uptime:[B]0 days 2:23:58.760[/B]
Probably caused by :[B]ntkrpamp.exe ( nt! ?? ::FNODOBFM::`string'+23710 )[/B]
BugCheck [B]7A, {c04cf220, c00000b5, 8a17820, 99e44020}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000007A]KERNEL_DATA_INPAGE_ERROR (7a)[/url]
Arguments:
Arg1: c04cf220, lock type that was held (value 1,2,3, or PTE address)
Arg2: c00000b5, error status (normally i/o status code)
Arg3: 08a17820, current process (virtual address for lock type 3, or PTE)
Arg4: 99e44020, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
BUGCHECK_STR:  0x7a_c00000b5
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]0x7a_c00000b5_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     1800
  Product Name                  500T
**************************Sun Dec  2 15:04:05.609 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120312-15000-01.dmp]
System Uptime:[B]0 days 5:55:02.432[/B]
BugCheck [B]9F, {3, 85f48948, 819d4b40, e28e6428}[/B]
Arguments:
Arg2: 85f48948, Physical Device Object of the stack
Arg3: 819d4b40, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: e28e6428, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1800
  Product Name                  500T
**************************Sun Dec  2 04:29:56.536 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120212-14890-01.dmp]
System Uptime:[B]0 days 5:45:56.373[/B]
BugCheck [B]9F, {3, 86c00948, 823fcb40, d2e3edb8}[/B]
Arguments:
Arg2: 86c00948, Physical Device Object of the stack
Arg3: 823fcb40, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: d2e3edb8, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1800
  Product Name                  500T
**************************Wed Nov 28 17:49:05.692 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\112912-124828-01.dmp]
System Uptime:[B]0 days 4:53:48.530[/B]
*** WARNING: Unable to verify timestamp for sdbus.sys
BugCheck [B]9F, {3, 867dd030, 803d4b40, bd7e1ad8}[/B]
Arguments:
Arg2: 867dd030, Physical Device Object of the stack
Arg4: bd7e1ad8, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1800
  Product Name                  500T
[/font]
3rd Party Drivers:
[COLOR=RED][B]odFips.sys                  Tue Mar 25 11:03:56 2008 (47E9145C)[/B][/COLOR]
[COLOR=RED][B]odFips2.sys                 Mon Apr  7 12:31:36 2008 (47FA4C68)[/B][/COLOR]
[COLOR=RED][B]jnprvamgr.sys               Tue Feb 10 21:09:25 2009 (49923355)[/B][/COLOR]
[COLOR=RED][B]jnprna.sys                  Wed May  6 12:50:31 2009 (4A01BFD7)[/B][/COLOR]
tap0901.sys                 Fri Jul 20 07:48:36 2012 (50094594)
wmbclass.sys                Wed Jul 25 22:31:01 2012 (5010ABE5)
intelppm.sys                Wed Jul 25 22:34:02 2012 (5010AC9A)
ChaabiDriver.sys            Sun Aug 12 09:33:47 2012 (5027B0BB)
MBI.sys                     Wed Aug 22 01:25:38 2012 (50346D52)
clvpep.sys                  Thu Aug 23 14:37:47 2012 (5036787B)
BcmGnssBus.sys              Wed Aug 29 13:53:28 2012 (503E5718)
DptfDevGen.sys              Thu Aug 30 12:24:25 2012 (503F93B9)
DptfDevProc.sys             Thu Aug 30 12:24:27 2012 (503F93BB)
DptfManager.sys             Thu Aug 30 12:24:32 2012 (503F93C0)
DptfDevDisplay.sys          Thu Aug 30 12:24:34 2012 (503F93C2)
bcmfn2.sys                  Thu Aug 30 23:43:16 2012 (504032D4)
rtii2sac.sys                Fri Sep  7 01:46:29 2012 (50498A35)
BtwSerialBus.sys            Fri Sep  7 13:50:08 2012 (504A33D0)
mxtBootBridge.sys           Tue Sep 11 16:18:06 2012 (504F9C7E)
inteli2c.sys                Mon Sep 17 10:31:52 2012 (50573458)
LNWIPC.sys                  Mon Sep 17 10:31:57 2012 (5057345D)
spi.sys                     Mon Sep 17 10:32:04 2012 (50573464)
MSICReg.sys                 Mon Sep 17 10:32:09 2012 (50573469)
Uart16550pc.sys             Mon Sep 17 10:32:20 2012 (50573474)
GPIOCLV.sys                 Mon Sep 17 10:34:48 2012 (50573508)
ov2720.sys                  Mon Sep 17 14:06:04 2012 (5057668C)
ov8830.sys                  Mon Sep 17 14:06:13 2012 (50576695)
lm3554.sys                  Mon Sep 17 14:06:16 2012 (50576698)
camera.sys                  Mon Sep 17 14:07:39 2012 (505766EB)
wacomrouterfilter.sys       Tue Sep 18 12:37:28 2012 (5058A348)
wachidrouter.sys            Tue Sep 18 19:19:31 2012 (50590183)
cnghwassist.sys             Thu Sep 20 01:30:24 2012 (505AA9F0)
HalExtIntcUartDma.dll       Thu Sep 20 01:32:33 2012 (505AAA71)
HalExtIntcLpioDma.dll       Thu Sep 20 01:32:34 2012 (505AAA72)
isstrtc.sys                 Wed Sep 26 00:51:13 2012 (506289C1)
bcmdhd63.sys                Fri Sep 28 06:34:49 2012 (50657D49)
igddim32.sys                Thu Oct  4 06:55:51 2012 (506D6B37)
igdkmd32.sys                Thu Oct  4 06:56:54 2012 (506D6B76)
dump_dumpsd.sys             Sun Oct 14 22:40:30 2012 (507B779E)
ETD.sys                     Thu Oct  4 23:47:45 2012 (506E5861)
btwavdt.sys                 Wed Jul 25 17:45:46 2012 (5010690A)
btwrchid.sys                Wed Jul 25 17:48:38 2012 (501069B6)
BthLEEnum.sys               Wed Jul 25 22:32:00 2012 (5010AC20)
btwl2cap.sys                Thu Jul 26 11:14:35 2012 (50115EDB)
btwaudio.sys                Wed Aug 29 14:53:08 2012 (503E6514)
btwampfl.sys                Fri Aug 31 17:06:12 2012 (50412744)
BTHMINI.sys                 Thu Oct 11 00:39:13 2012 (50764D71)
[COLOR=RED][B]SRTSPX.SYS                  Tue Nov 15 17:27:18 2011 (4EC2E746)[/B][/COLOR]
SYMNETS.SYS                 Tue May  8 04:48:42 2012 (4FA8DDEA)
SYMEFA.SYS                  Fri May 18 21:29:24 2012 (4FB6F774)
Ironx86.SYS                 Wed May 23 13:13:57 2012 (4FBD1AD5)
SYMEVENT.SYS                Wed May 23 20:51:53 2012 (4FBD8629)
SYMDS.SYS                   Wed May 23 21:11:13 2012 (4FBD8AB1)
SRTSP.SYS                   Thu May 24 02:27:18 2012 (4FBDD4C6)
ccSetx86.sys                Fri May 25 15:32:05 2012 (4FBFDE35)
EraserUtilDrv11220.sys      Tue Jul 31 19:33:30 2012 (50186B4A)
eeCtrl.sys                  Tue Jul 31 19:33:30 2012 (50186B4A)
IDSvix86.sys                Tue Aug 28 22:48:13 2012 (503D82ED)
NAVEX15.SYS                 Wed Sep  5 17:43:39 2012 (5047C78B)
NAVENG.SYS                  Wed Sep  5 17:45:35 2012 (5047C7FF)
BHDrvx86.sys                Thu Oct 18 23:10:05 2012 (5080C48D)
dump_dumpsd.sys             Thu Oct 11 00:40:28 2012 (50764DBC)
[/font]
http://www.carrona.org/drivers/driver.php?id=tap0901.sys
wmbclass.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ChaabiDriver.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
MBI.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
clvpep.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
BcmGnssBus.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevGen.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevProc.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfManager.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
DptfDevDisplay.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
bcmfn2.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
rtii2sac.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
BtwSerialBus.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
mxtBootBridge.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
inteli2c.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
LNWIPC.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spi.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
MSICReg.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Uart16550pc.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
GPIOCLV.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ov2720.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ov8830.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
lm3554.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
camera.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=wacomrouterfilter.sys
http://www.carrona.org/drivers/driver.php?id=wachidrouter.sys
cnghwassist.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
HalExtIntcUartDma.dll - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
HalExtIntcLpioDma.dll - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
isstrtc.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
bcmdhd63.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
igddim32.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=igdkmd32.sys
dump_dumpsd.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=ETD.sys
http://www.carrona.org/drivers/driver.php?id=btwavdt.sys
http://www.carrona.org/drivers/driver.php?id=btwrchid.sys
BthLEEnum.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=btwl2cap.sys
http://www.carrona.org/drivers/driver.php?id=btwaudio.sys
http://www.carrona.org/drivers/driver.php?id=btwampfl.sys
BTHMINI.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS
http://www.carrona.org/drivers/driver.php?id=SYMEFA.SYS
http://www.carrona.org/drivers/driver.php?id=Ironx86.SYS
http://www.carrona.org/drivers/driver.php?id=SYMEVENT.SYS
http://www.carrona.org/drivers/driver.php?id=SYMDS.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSP.SYS
http://www.carrona.org/drivers/driver.php?id=ccSetx86.sys
http://www.carrona.org/drivers/driver.php?id=EraserUtilDrv11220.sys
http://www.carrona.org/drivers/driver.php?id=eeCtrl.sys
http://www.carrona.org/drivers/driver.php?id=IDSvix86.sys
http://www.carrona.org/drivers/driver.php?id=NAVEX15.SYS
http://www.carrona.org/drivers/driver.php?id=NAVENG.SYS
http://www.carrona.org/drivers/driver.php?id=BHDrvx86.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
6
Usasma, thanks for the reply. I already uninstalled Norton Internet Security, and now using the Windows Defender and Win Firewall combination. And i can't find SRTSPX.SYS anymore in my harddisk. Maybe it was deleted by the time I uninstalled Norton. And for the other 4 drivers in red, it seems it came from one app, the Odyssey Access Client from Juniper Network. I need this app to connect to my office network, because strangely, my windows 8 didn't come built in with CISCO PEAP, so i need another supplicant software. But i'll try to uninstall this app and see if the BSOD still come up. I'll let you know the result.
usasma
Mr. Cranky Pants
5,139
Memory dump appears corrupted.
Please check in C:\Windows to see if you have a MEMORY.dmp file that's got the same date/time stamp
If so, please zip it up and upload it to a free file-hosting service and post a link to it here.
Beyond that, try running Driver Verifier according to these directions: Driver Verifier Settings
    Samsung/NP780
    800x600
6
#8
Usasma, i decided to do a fresh install, set a restore point after each system change (e.g windows updates, driver install) and so far this thing doesn't crash at all. I also didn't install norton internet security and juniper odyssey, and it's pretty stable right now. Thanks for your help.
usasma
Mr. Cranky Pants
5,139
#9
Make sure you set a restore point before trying the Juniper again - it seemed to be the most likely problem to me.
Good luck!
    Samsung/NP780
    800x600
