Solved BSOD Driver Power State Failure when waking from sleep
yojoey12
New build i7 asrock motherboard W8 Pro. when waking from sleep everytime I get driver_power_state_failure BSOD.
Looking for some help on where to start. Updated the bios and everything else works great.
Thanks for any advice
    new build
    Intel i7 3770k
    Asrock extreme6 1155
    Vengeance Series 16GB DDR3-1600
    intel 4000 Hd
usasma
Mr. Cranky Pants
5,139
You have 3 hard drives - what is the make/model/wattage and age of your Power Supply?
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
10 Nov 2012 - I'm seeing an upswing in SSD errors - but most appear due to older storage controller drivers. I strongly suggest NOT using storage controller drivers that don't date from 2012 (if none are available, don't connect an SSD to that controller)
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: https://www.eightforums.com/bsod-cr...-pc-reboots-when-waking-sleep.html#post169956
AsRock XFastLAN and XFastUSB have been known to cause BSOD's in some systems. Please uninstall them to test.
If overclocking, please stop while we're testing. Feel free to resume the overclock once the system has become stable.
Memory dumps point at your Intel Storage drivers. Please visit Intel Download Center to get the latest version of the Intel Rapid Storage Technology (RST) drivers. Then uninstall the current drivers (which may also be the latest version) BEFORE installing the freshly downloaded drivers. Then monitor for further BSOD's.
As a precaution (since this involves the storage sub-system) please run these free diagnostics on all of your hard drives: Hard Drive Diagnostic Procedure and run the manufacturer's tools on your SSD.
A previous BSOD blames k57nd60a.sys - a networking driver. This is either a second problem, or it's a sign of a low-level driver/hardware problem (they tend to spit out random errors).
MBfilt64.sys Thu Jul 30 23:40:32 2009 (4A7267B0)
Realtek HiDefinition Audio driver (file labelled as Creative Audio Driver)
http://www.carrona.org/drivers/driver.php?id=MBfilt64.sys
cfosspeed6.sys Mon Jul 4 09:18:51 2011 (4E11BDBB)
cFosSpeed - The Internet Accelerator
http://www.carrona.org/drivers/driver.php?id=cfosspeed6.sys
Analysis:
[font=lucida console]**************************Wed Jan  9 09:00:35.490 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010913-258156-01.dmp]
Windows 8 Kernel Version 9200 MP (8 procs) Free x64
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]0 days 9:52:11.140[/B]
*** ERROR: Module load completed but symbols could not be loaded for partmgr.sys
*** WARNING: Unable to verify timestamp for iaStorA.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStorA.sys
Probably caused by :[B]iaStorA.sys[/B]
BugCheck [B]9F, {3, fffffa800cda8060, fffff8019edcc7e0, fffffa800df91c60}[/B]
Arguments:
Arg2: fffffa800cda8060, Physical Device Object of the stack
Arg3: fffff8019edcc7e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800df91c60, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]0x9F_3_IMAGE_iaStorA.sys[/B]
**************************Tue Jan  8 20:02:16.489 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010813-252406-01.dmp]
System Uptime:[B]0 days 23:24:30.334[/B]
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {3, fffffa800cba9060, fffff88000fe07e0, fffffa801d714e10}[/B]
Arguments:
Arg2: fffffa800cba9060, Physical Device Object of the stack
Arg3: fffff88000fe07e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa801d714e10, The blocked IRP
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]0x9F_3_iaStorA_IMAGE_pci.sys[/B]
CPUID:        "Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz"
MaxSpeed:     3500
CurrentSpeed: [B]3500[/B]
  BIOS Version                  P2.40
  BIOS Release Date             11/28/2012
  Manufacturer                  To Be Filled By O.E.M.
  Product Name                  To Be Filled By O.E.M.
**************************Mon Jan  7 08:54:56.493 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010713-252625-01.dmp]
System Uptime:[B]0 days 12:45:24.141[/B]
BugCheck [B]9F, {3, fffffa800cd65060, fffff802775747e0, fffffa800df6bc60}[/B]
Arguments:
Arg2: fffffa800cd65060, Physical Device Object of the stack
Arg3: fffff802775747e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800df6bc60, The blocked IRP
BUGCHECK_STR:  0x9F
**************************Sun Jan  6 10:30:16.496 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010613-251562-01.dmp]
System Uptime:[B]0 days 14:46:49.144[/B]
BugCheck [B]9F, {3, fffffa800cd62060, fffff8019de697e0, fffffa800df76c60}[/B]
Arguments:
Arg2: fffffa800cd62060, Physical Device Object of the stack
Arg3: fffff8019de697e0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800df76c60, The blocked IRP
BUGCHECK_STR:  0x9F
**************************Fri Jan  4 15:23:31.017 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010413-17468-01.dmp]
System Uptime:[B]0 days 1:27:26.148[/B]
*** WARNING: Unable to verify timestamp for k57nd60a.sys
*** ERROR: Module load completed but symbols could not be loaded for k57nd60a.sys
Probably caused by :[B]k57nd60a.sys ( k57nd60a+f90f )[/B]
BugCheck [B]D1, {fffffae18310e734, 2, 0, fffff88004cd690f}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: fffffae18310e734, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88004cd690f, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_k57nd60a+f90f[/B]
**************************Wed Jan  2 08:19:04.102 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010213-10093-01.dmp]
Built by: [B]9200[/B].16384.amd64fre.win8_rtm.120725-1247
System Uptime:[B]0 days 0:11:12.750[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExpScanGeneralLookasideList+60 )[/B]
BugCheck [B]A, {ffffffffffffffd8, 2, 0, fffff8007897186f}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: ffffffffffffffd8, memory referenced
Arg3: 0000000000000000, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8007897186f, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nt!ExpScanGeneralLookasideList[/B]
MaxSpeed:     3500
  BIOS Version                  P1.90
  BIOS Release Date             07/13/2012
[/font]
3rd Party Drivers:
[COLOR=RED][B]MBfilt64.sys                Thu Jul 30 23:40:32 2009 (4A7267B0)[/B][/COLOR]
[COLOR=RED][B]cfosspeed6.sys              Mon Jul  4 09:18:51 2011 (4E11BDBB)[/B][/COLOR]
AsrRamDisk.sys              Thu Jan 12 23:52:38 2012 (4F0FB896)
FNETURPX.SYS                Wed May 30 23:00:47 2012 (4FC6DEDF)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
RTKVHD64.sys                Tue Aug  7 06:49:39 2012 (5020F2C3)
k57nd60a.sys                Sun Aug 26 00:58:34 2012 (5039ACFA)
dump_iaStorA.sys            Sat Sep  1 21:01:24 2012 (5042AFE4)
hiber_iaStorA.sys           Sat Sep  1 21:01:24 2012 (5042AFE4)
igdkmd64.sys                Wed Sep 26 15:49:04 2012 (50635C30)
EtronXHCI.sys               Tue Jul  3 07:00:15 2012 (4FF2D0BF)
EtronHub3.sys               Tue Jul  3 07:00:21 2012 (4FF2D0C5)
EpfwLWF.sys                 Wed Mar  7 09:28:51 2012 (4F5770A3)
epfw.sys                    Wed Mar  7 09:28:53 2012 (4F5770A5)
ehdrv.sys                   Wed Mar  7 09:33:42 2012 (4F5771C6)
epfwwfp.sys                 Thu Nov 15 08:58:27 2012 (50A4F503)
eamonm.sys                  Thu Nov 15 09:01:54 2012 (50A4F5D2)
intelppm.sys                Wed Jul 25 22:26:48 2012 (5010AAE8)
VirtuWDDM.sys               Wed Oct  3 14:47:55 2012 (506C885B)
[/font]
http://www.carrona.org/drivers/driver.php?id=AsrRamDisk.sys
http://www.carrona.org/drivers/driver.php?id=FNETURPX.SYS
http://www.carrona.org/drivers/driver.php?id=k57nd60a.sys
hiber_iaStorA.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=EtronXHCI.sys
http://www.carrona.org/drivers/driver.php?id=EtronHub3.sys
http://www.carrona.org/drivers/driver.php?id=EpfwLWF.sys
http://www.carrona.org/drivers/driver.php?id=epfw.sys
http://www.carrona.org/drivers/driver.php?id=ehdrv.sys
http://www.carrona.org/drivers/driver.php?id=epfwwfp.sys
http://www.carrona.org/drivers/driver.php?id=eamonm.sys
http://www.carrona.org/drivers/driver.php?id=VirtuWDDM.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
yojoey12
Thank you so much for the time you have already invested!
The power supply is a new Thermaltake [email protected] 600 watt.
uninstalled xfastlan and xfastusb for testing.
went on Intel's download page for rapid storage technology drivers. my current version is 11.6.0.1030 the newest version is 11.7.0.1013 however if you look at the know issues some are worse then I'm experiencing. the only time I get BSOD is when waking up from sleep other wise very stable. Intel® Rapid Storage Technology Do you think I should still update to 11.7.0.1013? also look at resolved issues #4160677 maybe applies to me?
I will update both MBfilt64.sys and cfosspeed6.sys this weekend and swap out my SSD drive for a standard drive. I have also installed intel's ssd tool kit and the firmware is up to date and drives check out good.I will also download the other hard drive program you suggested and check the drives.
Still some work to do. I will report back soon with my progress.
Thanks again for your help
    new build
    Intel i7 3770k
    intel 4000 Hd
usasma
Mr. Cranky Pants
5,139
I always suggest updating - but you may want to hold out if you're concerned about it.
But, IMO the updates are usually aimed at stability - so I'd think it'd be OK.
When/if you do install the RST update, make sure that you have made an System Restore point (and maybe even a disk image) so that you can go back to the old version (if you want/need to).
Good luck!
    Samsung/NP780
    800x600
yojoey12
Great news!!!
after removing xfastlan and xfastusb my computer sleeps and wakes up with NO Bsod,
I have updated my old drivers to improve stability.(will wait until tomorrow for the Intel RTS driver)
Thank you very much for the help and advice!
    new build
    Intel i7 3770k
    intel 4000 Hd
usasma
Mr. Cranky Pants
5,139
Glad to hear it! Thanks for letting us know.
    Samsung/NP780
    800x600
